The MCU will clock out just the payload data at a suitable rate (ex. 10kbps).<br />句子中的clock out怎么翻译?<br />To enable the demodulator to re-generate the clock, the preamble must be 8 bits toggling hi-low, starting with low if the first data bit low.<br />句子中preamble和preamble怎么翻译?<br />谢谢!<br /> |
