butterfly-application 什么意思?????
3820|6
 楼主| zhaoweige 发表于 2009-5-15 22:33 | 显示全部楼层 |阅读模式
butterfly-application&nbsp;什么意思?????<br />在atmel网站上看到的&nbsp;avr&nbsp;butterfly-application<br />在电子行业是什么意思
 楼主| zhaoweige 发表于 2009-5-16 21:57 | 显示全部楼层
不会吧,这么翻译??<br />有谁知道确切的意思???<br />
一级菜鸟 发表于 2009-5-15 22:50 | 显示全部楼层
可以翻译为:AVR的牛B应用
dxpol432 发表于 2009-5-16 20:36 | 显示全部楼层
果然&nbsp;牛&nbsp;,呵呵
mxh0506 发表于 2009-5-17 22:14 | 显示全部楼层
Butterfly is an AVR evaluation kit
The&nbsp;AVR&nbsp;Butterfly&nbsp;is&nbsp;a&nbsp;self-contained,&nbsp;battery-powered&nbsp;demonstration&nbsp;board&nbsp;running&nbsp;the&nbsp;ATMEL&nbsp;AVR&nbsp;ATmega169PV&nbsp;Microcontroller.&nbsp;The&nbsp;board&nbsp;includes&nbsp;a&nbsp;liquid&nbsp;crystal&nbsp;display&nbsp;(LCD),&nbsp;joystick,&nbsp;speaker,&nbsp;serial&nbsp;port,&nbsp;real-time&nbsp;clock&nbsp;(RTC),&nbsp;internal&nbsp;flash&nbsp;memory,&nbsp;and&nbsp;sensors&nbsp;for&nbsp;temperature&nbsp;and&nbsp;voltage.&nbsp;The&nbsp;board&nbsp;is&nbsp;the&nbsp;size&nbsp;of&nbsp;a&nbsp;name&nbsp;tag&nbsp;and&nbsp;with&nbsp;the&nbsp;pin&nbsp;on&nbsp;back&nbsp;it&nbsp;can&nbsp;be&nbsp;worn&nbsp;as&nbsp;such&nbsp;after&nbsp;the&nbsp;user&nbsp;enters&nbsp;their&nbsp;name&nbsp;onto&nbsp;the&nbsp;LCD.<br /><br />The&nbsp;AVR&nbsp;Butterfly&nbsp;comes&nbsp;preloaded&nbsp;with&nbsp;software&nbsp;that&nbsp;demonstrates&nbsp;many&nbsp;of&nbsp;the&nbsp;capabilities&nbsp;of&nbsp;the&nbsp;AVR&nbsp;microcontrollers.&nbsp;Factory&nbsp;firmware&nbsp;can&nbsp;scroll&nbsp;your&nbsp;name,&nbsp;display&nbsp;the&nbsp;sensor&nbsp;readings,&nbsp;and&nbsp;show&nbsp;the&nbsp;time.&nbsp;The&nbsp;AVR&nbsp;Butterfly&nbsp;also&nbsp;has&nbsp;a&nbsp;piezo&nbsp;speaker&nbsp;that&nbsp;can&nbsp;reproduce&nbsp;sounds&nbsp;and&nbsp;music.<br />
iC921 发表于 2009-5-18 05:44 | 显示全部楼层
从这句看,推测它就是简明应用的意思
意思是使用了它,可以解决一些平时不很方便解决的问题。这确实是个比较牛B的广告式产品介绍,因而,一级菜鸟说可以翻译为“AVR的牛B应用”可不是开玩笑的!<br /><br />在中文中,译作“<b>傻瓜应用</b>”我看非常得当,只是自己不要越用越傻就得了。哈哈,我不会AVR,瞎掺乎一下~<br /><br /><B>break&nbsp;a&nbsp;butterfly&nbsp;on&nbsp;the&nbsp;wheel&nbsp;杀**用牛刀,&nbsp;小题大作</B><br /><br />*-------<br />butterfly-application&nbsp;什么意思?????<br />在atmel网站上看到的&nbsp;avr&nbsp;butterfly-application<br />在电子行业是什么意思<br /><br />
andyany 发表于 2010-12-24 10:52 | 显示全部楼层
butterfly的意思是蝶形封装,就是引脚从两侧边伸出。
双列直插大家应该很熟悉了。对照想一下,就明白了。
