[其他ST产品] ST1027x加密例程
3509|2
 楼主| fanny.xu 发表于 2007-6-6 10:43 | 显示全部楼层 |阅读模式
加密保护的机制Datasheet上都有详细说明。
具体特定芯片的加密,需仔细阅读datasheet中Flash spec及相关保护寄存器的spec,结合下面历程灵活更改(补充了datasheet的例程)。
在做访问保护操作之前,先将永久(临时)解访问保护程序烧入IFlash.
Set (XPEN, ROMEN) @ SYSCON register as “1”
Set  XFLASHEN @XPERCON register as “1”
1)Write Protection, Enable Write Protection of sectors B0F4 of Bank 0 in I-Flash module.
FCR0H   |= 0x0100;           /* Set SPR in FCR0H*/
FARL      = 0xDFB4;         /*Load Add of register FNVWPIR in FARL*/
FARH     = 0x000E;          /*Load Add of register FNVWPIR in FARH*/
FDR0L   = 0xFFEF;                  /*Load Data in FDR0L*/
FDR0H   = 0xFFFF;                    /*Load Data in FDR0H*/
FCR0H   |= 0x8000;                   /* Operation start*/
2)Temporary un-write protection, B0F4 temporarily un-write protection and programmingB0F4
FCR0H |=0x0100;
FARL = 0xDFB4;
FARH = 0x000E;
FDR0L = 0xFFFF;                      /*Load Data in FDR0L*/
FDR0H = 0xFFFF;
FCR0H |= 0x8000;
FCR0H |=0x2080;                      /* Set WPG & SMOD in FCR0H*/
FARL  = 0x8000;                       /* Load B0F4 Add into FAR*/
FARH  = 0x0001;
FDR0L = 0xAAAA;                 /* Load Data in FDR*/
FDR0H = 0xFFFF;
FCR0H |=0x8000;                   /* Operation start*/
3)Access Protection
Temp = FNVAPR0;
Temp &= 0xFFFC;              /* Set DBGP, ACCP as “0” in FNVAPR0*/
FCR0H  |= 0x0100;              /* Set SPR in FCR0H */
FARL     = 0xDFB8;            /* Load Add of FNVAPR0 into FARL*/
FARH     = 0x000E;             /* Load Add of FNVAPR0 into FARH */
FDR0L   = Temp;                /* Load Data into FDR0L*/
Notes: 1) The Default value of FNVAPR0 is ACFF;
       2) Set both DBGP and ACCP in FNVAPR0 as “0” to disable Access protection permanently.
4)Disable in a permanent way Access Protection
FCR0H   |= 0x0100;
FARL    = 0xDFBC;                /* Load FNVAPR1 Add into FAR*/
FARH    = 0x000E;
FDR0L   = 0xFFFE;                /* Load Data into FDR*/
FDR0H   = 0xFFFF;
FCR0H   |= 0x8000;
Notes: 1) Disable access protection routines must be programmed into I-Flash before Access protection operation
5) Enable in a permanent way Access Protection
FCR0H   |= 0x0100;
FARH    = 0x000E;
FDR0H   = 0xFFFE;
FCR0H   |= 0x8000;
stephon1 发表于 2007-6-7 15:56 | 显示全部楼层
good
good
YeCM 发表于 2008-7-1 09:03 | 显示全部楼层
good
有空也研究下
