STR911 SPI做主收不到数据
4276|7
 楼主| john78 发表于 2007-11-5 21:32 | 显示全部楼层 |阅读模式
ST, spi, IO, gp, GPIO
  GPIO_StructInit(&GPIO_InitStruct);
  GPIO_InitStruct.GPIO_Direction = GPIO_PinInput;
  GPIO_InitStruct.GPIO_Pin = GPIO_Pin_6;
  GPIO_InitStruct.GPIO_Type = GPIO_Type_PushPull ;
  GPIO_InitStruct.GPIO_IPConnected = GPIO_IPConnected_Enable;
  GPIO_InitStruct.GPIO_Alternate = GPIO_InputAlt1  ;
  GPIO_Init(GPIO5,&GPIO_InitStruct);
  GPIO_InitStruct.GPIO_Pin        =  GPIO_Pin_4|GPIO_Pin_5;//|GPIO_Pin_7;
  GPIO_InitStruct.GPIO_Direction  =  GPIO_PinOutput;
  GPIO_InitStruct.GPIO_Alternate  =  GPIO_OutputAlt2;
  GPIO_InitStruct.GPIO_IPConnected=  GPIO_IPConnected_Disable;
  GPIO_InitStruct.GPIO_Pin =  GPIO_Pin_7;         //这个引脚自己控制
  GPIO_InitStruct.GPIO_Alternate = GPIO_OutputAlt1;
  SSP_DeInit(SSP0);
  SSP_InitStructure.SSP_FrameFormat = SSP_FrameFormat_Motorola;
  SSP_InitStructure.SSP_Mode        = SSP_Mode_Master;
  SSP_InitStructure.SSP_CPOL        = SSP_CPOL_Low;
  SSP_InitStructure.SSP_CPHA        = SSP_CPHA_1Edge;
  SSP_InitStructure.SSP_DataSize    = SSP_DataSize_8b;
  SSP_InitStructure.SSP_ClockRate   = 10;
  SSP_InitStructure.SSP_ClockPrescaler = 96;
  SSP_Init(SSP0, &SSP_InitStructure);
  SSP_Cmd(SSP0, ENABLE);
发送接收
U8 enc28j60ReadOp(U8 op, U8 address)
  U8 da;
  GPIO_WriteBit(GPIO5,GPIO_Pin_7,Bit_RESET)
  SSP_SendData(0x19);
  while(SSP_GetFlagStatus(SSP0, SSP_FLAG_Busy)==SET);  //接收数据
  SSP_SendData(SSP0,0X00);  //发送一个无效数据=接收
  while(SSP_GetFlagStatus(SSP0, SSP_FLAG_RxFifoNotEmpty)==RESET);
  da = SSP_ReceiveData(SSP0);
  GPIO_WriteBit(GPIO5,GPIO_Pin_7,Bit_SET);
  return(da);
用逻辑分析仪观察,有数据回应,但发送接收返回的始终是0
不知道那里有错.
一览 发表于 2007-11-6 08:59 | 显示全部楼层
参考
u8 SSP_SendByte(SSP_TypeDef* SSPx,u8 byte)
  /* Send byte through the SSP0 peripheral */
  SSPx->DR = byte;
  /* Loop while Transmit FIFO is full */
  while(SSP_GetFlagStatus(SSPx, SSP_FLAG_TxFifoEmpty) == RESET);
  /* Loop while Receive FIFO is empty */
  while(SSP_GetFlagStatus(SSPx, SSP_FLAG_RxFifoNotEmpty) == RESET);
  /* Return the byte read from the SSP bus */
  return(SSPx->DR);
SSP_SendData(0x19); (发送命令后需要把缓冲区读空)
 楼主| john78 发表于 2007-11-6 23:08 | 显示全部楼层
还是不行
谢谢 一览
代码已经改成
static U8 SSP_SendByte(U8 byte)
  SSP0->DR = byte;     // same as SSP_SendData
  while(SSP_GetFlagStatus(SSP0, SSP_FLAG_TxFifoEmpty) == RESET);
  while(SSP_GetFlagStatus(SSP0, SSP_FLAG_RxFifoNotEmpty) == RESET);
  return(SSP0->DR); // same as SSP_ReceiveData
U8 ReadOp(U8 op, U8 address)
da = SSP_SendByte(0x19);
da = SSP_SendByte(0xA5);
return da;
返回的值还是0X00
用逻辑分析仪观察返回的是0X58
不知道还有哪里没有设置好.
 楼主| john78 发表于 2007-11-6 23:17 | 显示全部楼层
逻辑
STF 发表于 2007-11-7 10:13 | 显示全部楼层
STR9-Eval SSP 例子
你好,
ST 评估版上有一个 spi flash, 这个程序会先写数据然后读这个外部存储。你可以比较一下。
Regards,
Stephane
相关链接:https://bbs.21ic.com/upfiles/img/200711/200711710835260.zip
一览 发表于 2007-11-7 11:51 | 显示全部楼层
参考
注意CPOL 与CPHA的配置要适合slave接口要求。
 楼主| john78 发表于 2007-11-7 12:59 | 显示全部楼层
CPHA=0,CPOL=0
器件要求:CPHA=0,CPOL=0
这个设置应该每错吧
唐靖丰 发表于 2007-11-10 21:31 | 显示全部楼层
还是看看,你的配置
我也遇到过类似的问题,我曾经用一个SPI端口联了多个设备,但每个设备的配置就不太相同,所以,经常需要切换配置后才能顺利的读写设备。当时也遇到过你说的问题,大都是配置或者重复配置出的问题,
另外,有一次,我忘了在CONFIG.H中将SSP选中,结果似乎也出过问题。
91X还不错,我用得很好。
