数学建模必备
15844|179
 楼主| gaoyang9992006 发表于 2015-8-19 20:21 | 显示全部楼层 |阅读模式
这个资料太好了,都是源码,必须的回复看。
游客,如果您要查看本帖隐藏内容请回复
是源程序,帮助很大  发表于 2018-11-20 09:38
 楼主| gaoyang9992006 发表于 2015-8-19 20:22 | 显示全部楼层
随便贴几个给大家看看。
  1. %空间曲线图
  2. % PLOT3(x,y,z,s)其中x,y,z为向量,每一组分量代表一个数据点。
  3. %                    s为表示颜色、连线和标记选择的字符串
  4. %例如 曲线x=exp(-0.2*z)*cos(0.5*pi*z),y=exp(-0.2*z)*sin(0.5*pi*z), 0<z<20。
  5. %
  6. %  clear;close;z=0:0.1:20;r=exp(-0.2*z);th=0.5*pi*z;
  7. %  x=r.*cos(th);y=r.*sin(th);plot3(x,y,z,'r');
  8. %
  9. %PLOT3  Plot lines and points in 3-D space.
  10. %   PLOT3() is a three-dimensional analogue of PLOT().
  11. %
  12. %   PLOT3(x,y,z), where x, y and z are three vectors of the same length,
  13. %   plots a line in 3-space through the points whose coordinates are the
  14. %   elements of x, y and z.
  15. %
  16. %   PLOT3(X,Y,Z), where X, Y and Z are three matrices of the same size,
  17. %   plots several lines obtained from the columns of X, Y and Z.
  18. %
  19. %   Various line types, plot symbols and colors may be obtained with
  20. %   PLOT3(X,Y,Z,s) where s is a 1, 2 or 3 character string made from
  21. %   the characters listed under the PLOT command.
  22. %
  23. %   PLOT3(x1,y1,z1,s1,x2,y2,z2,s2,x3,y3,z3,s3,...) combines the plots
  24. %   defined by the (x,y,z,s) fourtuples, where the x's, y's and z's are
  25. %   vectors or matrices and the s's are strings.
  26. %
  27. %   Example: A helix:
  28. %
  29. %       t = 0:pi/50:10*pi;
  30. %       plot3(sin(t),cos(t),t);
  31. %
  32. %   PLOT3 returns a column vector of handles to LINE objects, one
  33. %   handle per line. The X,Y,Z triples, or X,Y,Z,S quads, can be
  34. %   followed by parameter/value pairs to specify additional
  35. %   properties of the lines.
  36. %
  37. %   See also PLOT, LINE, AXIS, VIEW, MESH, SURF.
  38. %-------------------------------
  39. %   Additional details:
  40. %
  41. %
  42. %   If the NextPlot axis property is REPLACE (HOLD is off), PLOT3 resets
  43. %   all axis properties, except Position, to their default values, and
  44. %   deletes all axis children (line, patch, text, surface, and
  45. %   image objects).
  46. %   Copyright (c) 1984-98 by The MathWorks, Inc.
  47. %   $Revision: 5.3 $  $Date: 1997/11/21 23:34:01 $
  48. %   Built-in function.
  1. %二维图(一元函数图)
  2. %用法 plot(x,y,s) 其中x,y为向量,每一对分量代表一个数据点。
  4. %图形的线型,标记,颜色均可设定,常用有
  5. %       颜色           |                线型                        标记
  6. % ---------------------      -------------------  -------------------
  7. %   b          蓝(默认)               -      实线(默认)        无(默认)
  8. %   g           绿             --     虚线         *          星
  9. %   r           红             :      粗点线       .          点
  10. %   y           黄             -.     点划线       o          圈
  11. %   m           洋红                               x          叉
  12. %   c           青                                 +          十字
  13. %   w           白                                 s          方块
  14. %   k           黑                                 d          菱形
  15. %                                                  v          下三角形
  16. %                                                  ^          上三角形
  17. %                                                  <          左三角形
  18. %                                                  >          右三角形
  19. %                                                  h          六角形
  20. %                                                  p          五角形
  21. %例如
  22. %    x=0:0.2:2*pi;y=sin(x);
  23. %    plot(x,y,'r*')
  24. %
  25. %PLOT   Linear plot.
  26. %   PLOT(X,Y) plots vector Y versus vector X. If X or Y is a matrix,
  27. %   then the vector is plotted versus the rows or columns of the matrix,
  28. %   whichever line up.
  29. %
  30. %   PLOT(Y) plots the columns of Y versus their index.
  31. %   If Y is complex, PLOT(Y) is equivalent to PLOT(real(Y),imag(Y)).
  32. %   In all other uses of PLOT, the imaginary part is ignored.
  33. %
  34. %   Various line types, plot symbols and colors may be obtained with
  35. %   PLOT(X,Y,S) where S is a character string made from one element
  36. %   from any or all the following 3 colunms:
  37. %
  38. %          y     yellow        .     point              -     solid
  39. %          m     magenta       o     circle             :     dotted
  40. %          c     cyan          x     x-mark             -.    dashdot
  41. %          r     red           +     plus               --    dashed
  42. %          g     green         *     star
  43. %          b     blue          s     square
  44. %          w     white         d     diamond
  45. %          k     black         v     triangle (down)
  46. %                              ^     triangle (up)
  47. %                              <     triangle (left)
  48. %                              >     triangle (right)
  49. %                              p     pentagram
  50. %                              h     hexagram
  51. %
  52. %   For example, PLOT(X,Y,'c+:') plots a cyan dotted line with a plus
  53. %   at each data point; PLOT(X,Y,'bd') plots blue diamond at each data
  54. %   point but does not draw any line.
  55. %
  56. %   PLOT(X1,Y1,S1,X2,Y2,S2,X3,Y3,S3,...) combines the plots defined by
  57. %   the (X,Y,S) triples, where the X's and Y's are vectors or matrices
  58. %   and the S's are strings.
  59. %
  60. %   For example, PLOT(X,Y,'y-',X,Y,'go') plots the data twice, with a
  61. %   solid yellow line interpolating green circles at the data points.
  62. %
  63. %   The PLOT command, if no color is specified, makes automatic use of
  64. %   the colors specified by the axes ColorOrder property.  The default
  65. %   ColorOrder is listed in the table above for color systems where the
  66. %   default is yellow for one line, and for multiple lines, to cycle
  67. %   through the first six colors in the table.  For monochrome systems,
  68. %   PLOT cycles over the axes LineStyleOrder property.
  69. %
  70. %   PLOT returns a column vector of handles to LINE objects, one
  71. %   handle per line.
  72. %
  73. %   The X,Y pairs, or X,Y,S triples, can be followed by
  74. %   parameter/value pairs to specify additional properties
  75. %   of the lines.
  76. %
  77. %   See also SEMILOGX, SEMILOGY, LOGLOG, GRID, CLF, CLC, TITLE,
  78. %   XLABEL, YLABEL, AXIS, AXES, HOLD, COLORDEF, and SUBPLOT.
  79. %   If the NextPlot axes property is "replace" (HOLD is off), PLOT resets
  80. %   all axes properties, except Position, to their default values,
  81. %   deletes all axes children (line, patch, text, surface, and
  82. %   image objects), and sets the View property to [0 90].
  83. %   Copyright (c) 1984-98 by The MathWorks, Inc.
  84. %   $Revision: 5.7 $  $Date: 1997/11/21 23:33:07 $
  85. %   Built-in function.
 楼主| gaoyang9992006 发表于 2015-8-19 20:23 | 显示全部楼层
  1. function h = mesh(x,y,z,c)
  2. %空间曲面图
  3. %  mesh(x,y,z)其中x,y,z为同阶矩阵,每一组对应元素代表一个网格点。
  4. %
  5. %例如 曲面 z=x.*exp(-x^2-y^2),-2<x<2,-2<y<2。
  6. %
  7. %     clear;close;xa=-2:.2:2;ya=xa;
  8. %     [x,y]=meshgrid(xa,ya);z=x.*exp(-x.^2-y.^2);
  9. %     mesh(x,y,z);%网格图
  10. %
  11. %MESH   3-D mesh surface.
  12. %   MESH(X,Y,Z,C) plots the colored parametric mesh defined by
  13. %   four matrix arguments.  The view point is specified by VIEW.
  14. %   The axis labels are determined by the range of X, Y and Z,
  15. %   or by the current setting of AXIS.  The color scaling is determined
  16. %   by the range of C, or by the current setting of CAXIS.  The scaled
  17. %   color values are used as indices into the current COLORMAP.
  18. %
  19. %   MESH(X,Y,Z) uses C = Z, so color is proportional to mesh height.
  20. %
  21. %   MESH(x,y,Z) and MESH(x,y,Z,C), with two vector arguments replacing
  22. %   the first two matrix arguments, must have length(x) = n and
  23. %   length(y) = m where [m,n] = size(Z).  In this case, the vertices
  24. %   of the mesh lines are the triples (x(j), y(i), Z(i,j)).
  25. %   Note that x corresponds to the columns of Z and y corresponds to
  26. %   the rows.
  27. %
  28. %   MESH(Z) and MESH(Z,C) use x = 1:n and y = 1:m.  In this case,
  29. %   the height, Z, is a single-valued function, defined over a
  30. %   geometrically rectangular grid.
  31. %
  32. %   MESH returns a handle to a SURFACE object.
  33. %
  34. %   AXIS, CAXIS, COLORMAP, HOLD, SHADING and VIEW set figure, axes, and
  35. %   surface properties which affect the display of the mesh.
  36. %
  37. %   See also SURF, MESHC, MESHZ, WATERFALL.
  40. %
  41. %   MESH sets the FaceColor property to background color and the EdgeColor
  42. %   property to 'flat'.
  43. %
  44. %   If the NextPlot axis property is REPLACE (HOLD is off), MESH resets
  45. %   all axis properties, except Position, to their default values
  46. %   and deletes all axis children (line, patch, surf, image, and
  47. %   text objects).
  48. %   Copyright (c) 1984-98 by The MathWorks, Inc.
  49. %   $Revision: 5.7 $  $Date: 1997/11/21 23:33:57 $
  50. %   J.N. Little 1-5-92
  51. %   Modified 2-3-92, LS.
  52. user_view = 0;
  53. cax = newplot;
  54. fc = get(gca,'color');
  55. if strcmp(lower(fc),'none')
  56.     fc = get(gcf,'color');
  57. end
  58. if nargin == 1
  59.     hh = surface(x,'FaceColor',fc,'EdgeColor','flat', 'FaceLighting', 'none', 'EdgeLighting', 'flat');
  60. elseif nargin == 2
  61.         if isstr(y), error('Invalid argument.'); end
  62.     [my ny] = size(y);
  63.     [mx nx] = size(x);
  64.     if mx == my & nx == ny
  65.         hh = surface(x,y,'FaceColor',fc,'EdgeColor','flat', 'FaceLighting', 'none', 'EdgeLighting', 'flat');
  66.     else
  67.         if my*ny == 2 % must be [az el]
  68.             hh = surface(x,'FaceColor',fc,'EdgeColor','flat', 'FaceLighting', 'none', 'EdgeLighting', 'flat');
  69.             set(gca,'View',y);
  70.             user_view = 1;
  71.         else
  72.             error('Invalid input arguments.');
  73.         end
  74.     end
  75. elseif nargin == 3
  76.         if isstr(y) | isstr(z), error('Invalid argument.'); end
  77.     if min(size(y)) == 1 & min(size(z)) == 1 % old style
  78.         hh = surface(x,'FaceColor',fc,'EdgeColor','flat', 'FaceLighting', 'none', 'EdgeLighting', 'flat');
  79.         set(gca,'View',y);
  80.         user_view = 1;
  81.     else
  82.         hh = surface(x,y,z,'FaceColor',fc,'EdgeColor','flat', 'FaceLighting', 'none', 'EdgeLighting', 'flat');
  83.     end
  84. elseif nargin == 4
  85.     hh = surface(x,y,z,c,'FaceColor',fc,'EdgeColor','flat', 'FaceLighting', 'none', 'EdgeLighting', 'flat');
  86. else
  87.     error('Requires 1, 2, 3, or 4 input arguments.');
  88. end
  89. if ~ishold & ~user_view
  90.     view(3); grid on
  91. end
  92. if nargout == 1
  93.     h = hh;
  94. end
lvyunhua 发表于 2015-8-21 15:02 | 显示全部楼层
好东西,收下了。
limiao123 发表于 2015-9-8 17:11 | 显示全部楼层
论文中均需要模型分析
李元1992 发表于 2015-9-8 20:31 | 显示全部楼层
好好好激动
chenmo51 发表于 2015-9-12 17:50 | 显示全部楼层
谢谢!
西科小凡 发表于 2015-9-22 11:35 | 显示全部楼层
看看。。
快乐人生929 发表于 2015-10-5 16:16 | 显示全部楼层
学习学习
sibaidong 发表于 2015-10-23 17:25 | 显示全部楼层
jjl3 发表于 2015-10-23 17:38 来自手机 | 显示全部楼层
学习学习
Eric封 发表于 2015-11-16 22:01 | 显示全部楼层
 楼主| gaoyang9992006 发表于 2015-11-17 17:18 | 显示全部楼层
就不一一回复了,感谢各位支持。
wei12321cjlk 发表于 2015-11-19 10:35 | 显示全部楼层
好东西
shenliwuji 发表于 2015-12-10 12:46 | 显示全部楼层
看看啊
1234567li 发表于 2015-12-19 17:31 | 显示全部楼层
Vantica 发表于 2015-12-21 12:42 | 显示全部楼层
算法加源码简直就是我的最爱啊,多谢
dongshan 发表于 2016-1-28 13:06 | 显示全部楼层
什么东西,回复地看一下。
1R1X 发表于 2016-3-2 15:22 | 显示全部楼层
想好好学一下MATLAB!!!!
2081
