[开发工具] IAR EWARM怎么用命令行生成ELF文件??
6482|2
 楼主| ATmega32L 发表于 2008-3-9 14:32 | 显示全部楼层 |阅读模式
提示:
Error[e81]: Unknown flag in extended format option -Oelf,(CODE)=.elf
Available modifiers for this format:
  a   Format suitable for debuggers from ARM Ltd (also sets -p flag)
  c   Use address_class attributes for pointer types
  f   Suppress DWARF Call Frame Information
  m   Output types in each compilation unit, instead of once for all
  n   Suppress DWARF debug output
  o   Use non-factored CFA offsets in DWARF Call Frame Information
  p   Multiple Elf program sections
  r   Produce a relocatable executable ELF file
  s   Ref_addr (global refs) use .debug_info (not file) offsets
  v   Use variant use_location semantics for member pointers
  w   Do not emit any .debug_aranges section
  x   Strip source file paths, leaving only the file name and extension
  z   Merge consecutive output segments of the same kind
Several modifiers can be used at the same time, by specifying
more than one character after the "-y". For example, -yac turns on
both modifier a and modifier c.
grant_jx 发表于 2008-3-9 23:56 | 显示全部楼层
Option->Linker->Output不是可以设置吗
简单设置一下,为何要使用命令行?
 楼主| ATmega32L 发表于 2008-3-10 09:29 | 显示全部楼层
-Oelf,as=.elf
-Oelf,as=.elf
