[开发工具] ADS+h-jtag+wiggler能否实现STR712在Flash中调试?
3704|3
 楼主| mcuatmel 发表于 2007-8-24 10:16 | 显示全部楼层 |阅读模式
如可以,该如何修改文件?
grant_jx 发表于 2007-8-24 22:41 | 显示全部楼层
楼上的,实在不知该说什么好。我没有用过ADS
如果你确实认真看过http://www.stmcu.com网站上给出的ST ARM的资料,应该是可以找到你需要的啊?
http://www.stmcu.com/modules.php?name=mcu&file=familiesdocs&FAM=86#Application%20Note
STR71x Standard Software Library
http://www.st.com/stonline/products/support/micro/files/str71xlibstd.zip
STR71x Standard Software Library User Manual
http://www.st.com/stonline/products/literature/um/10780.pdf
请到下列的路径寻找scf文件:
STR71x Standard Software Library.zip emplatesstandalone
你可以看到有三个分散加载(scf)的配置文件,分别用于RAM、Flash、Ext Flash三种不同存储方式的调试模式。请你打开readme文件,这里我将它复制你看看:
*** This README.TXT file comes with the STR71x Software Library ***
THE PRESENT SOFTWARE WHICH IS FOR GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS WITH
CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
AS A RESULT, STMICROELECTRONICS SHALL NOT BE HELD LIABLE FOR ANY DIRECT, INDIRECT
OR CONSEQUENTIAL DAMAGES WITH RESPECT TO ANY CLAIMS ARISING FROM THE CONTENT
OF SUCH SOFTWARE AND/OR THE USE MADE BY CUSTOMERS OF THE CODING INFORMATION
CONTAINED HEREIN IN CONNECTION WITH THEIR PRODUCTS.
Template description
This template directory contains all the files needed to start a new standalone project,
i.e. with no external source dependencies.
Directory contents
new.prj      RealView project file on DebugRel mode
71x_armr.scf
71x_armf.scf
71x_arme.scf
71x_conf.h   Library Configuration file
71x_it.c     Interrupt handlers
main.c       Main program
How to use it
- open the new.prj project
- edit and change the main.c and 71x_it.c files according to your application
- edit and change the 71x_conf.h file to include all needed header files
- specify the scatter file, to be used in your application, in the
"Project->Project properties->BUILD->Link_Advanced->Scatter file".
The 71x_armr.scf is selected by default.
- compile and run.
Scatter files description
71x_armf.scf file will place the application code in the internal FLASH and the
application data in the internal RAM.
71x_arme.scf file will place the application code in the external memory BANK0
and the application data in the internal RAM.
71x_armr.scf file will place the application code and data in the internal RAM.
How to use the example code
To run the example, RAM should be mapped to address 0x00000000, then compile
and run it. This example use the 71x_armr.scf file.
(C) COPYRIGHT 2003 STMicroelectronics
不需要还要跟你解释了吧。NXP是把每个配子都建了工程给你,难道非要这样才知道如何用吗?脱离了项目工程模板就不可以自己建吗?那ZLG罪过了。
用一种东西要学会的是举一反三,而不是对照照搬使用,其实很多资料在网上都是可以找到的。如果你一定要用ADS,建议你可以去ARM的网站下载RealView的中文说明书,一共有十多本,其中有一本用户手册很详细的介绍了SCF的文件结构和格式,可供参考。
 楼主| mcuatmel 发表于 2007-8-25 10:45 | 显示全部楼层
我手上的ADS的例程中没有SCF文件,所以我不知道怎么改。
我试着改了一下编译设置,一直不是好用。
 楼主| mcuatmel 发表于 2007-8-27 08:37 | 显示全部楼层
我用IAR 的32K版成功了
好在我的代码现在不是很大。
ADS下的例程没能试成功。
