[嵌入式linux] insmod 模块后显示 Kiled,这是为什么
822|1
 楼主| lin19890716 发表于 2015-8-24 15:45 | 显示全部楼层 |阅读模式
LED, ev, ST, RS, FIR
#include<linux/module.h>
#include<linux/init.h>
#include<linux/fs.h>
#include<linux/kdev_t.h>
#include<linux/cdev.h>
#include<asm/uaccess.h>
#define FTIRST_DRIVE 111
struct cdev_first{
        struct cdev f_dev;
struct cdev_first *devp;
static ssize_t first_read (struct file *filp, char __user *buf, size_t len, loff_t *ppos)
         char k_buf[20] = "jqwdaddda aeee!!";
         if(copy_to_user(buf,&k_buf,sizeof(k_buf)))
                 return -1;
                 return sizeof(k_buf);
static ssize_t first_write (struct file *filp, const char __user *buf, size_t len, loff_t *ppos)
        printk(KERN_WARNING  "do noting");
        return 0;
static const struct file_operations first_fops = {
        .owner = THIS_MODULE,
        .read = first_read,
        .write = first_write,
static void first_setup_cdev(struct cdev_first *dev, int index)
        int error;
        dev_t devno = MKDEV(FTIRST_DRIVE,0);
        cdev_init(&dev->f_dev, &first_fops);
        dev->f_dev.owner = THIS_MODULE;
        error = cdev_add (&dev->f_dev, devno, 1);
        if(error)
                printk(KERN_WARNING "add dev error");
static int __init first_init(void)
        int error;
        dev_t devn;
        devn = MKDEV(FTIRST_DRIVE,0);
        if(1){
                error = register_chrdev_region(devn,1,"first");
        else{
                error = alloc_chrdev_region(&devn,0,1,"first");
        if(error < 0)
                goto deal_error;
        first_setup_cdev(devp,0);
        return 0;
        deal_error:
                unregister_chrdev_region(devn,1);
                printk(KERN_WARNING "register error!");
                return -1;
static void __exit first_exit(void)
        int devno = MKDEV(FTIRST_DRIVE,0);
        cdev_del(&devp->f_dev);
        unregister_chrdev_region(devno,1);
module_init(first_init);
module_exit(first_exit);
MODULE_AUTHOR("LIN");
MODULE_LICENSE("GPL");
以上是代码,是不是初始化哪里出错了,求指点
 楼主| lin19890716 发表于 2015-8-24 17:28 | 显示全部楼层
调出来了 是first_setup_cdev函数的问题
