[其他ST产品] STR710的STANDBY模式进不去
3161|0
 楼主| xshtz 发表于 2008-4-21 13:44 | 显示全部楼层 |阅读模式
程序如下:
/* Includes ------------------------------------------------------------------*/
#include "71x_lib.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Define the RTC prescaler 0x7FFF to have 1 second basic clock */
#define RTC_Prescaler 0x7FFF
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
void SYS_INIT(void);
void GPIO_PinToggle(u8 GPIO_PIN, u32 DELAY);
void EIC_Configuration(void);
void Delay(u32 nCount);
* Function Name  : main
* Description    : main program.
* Input          : None.
* Return         : None.
int main (void)
  #ifdef DEBUG
    debug();
  #endif
  /* System clocks configuration ---------------------------------------------*/
  SYS_INIT();
  /* MCLK = PCLK1 = PCLK2 = 24MHz*/
  /* Configure PCLK1 = RCLK / 1 */
  RCCU_PCLK1Config (RCCU_DEFAULT);
  /* Configure PCLK2 = RCLK / 1 */
  RCCU_PCLK2Config (RCCU_DEFAULT);
  /* Configure MCLK clock for the CPU, RCCU_DEFAULT = RCLK /1 */
  RCCU_MCLKConfig (RCCU_DEFAULT);
  /* Configure the PLL1 ( * 12 , / 4 ) */
  RCCU_PLL1Config (RCCU_PLL1_Mul_12, RCCU_Div_4) ;
  while(RCCU_FlagStatus(RCCU_PLL1_LOCK) == RESET)
    /* Wait PLL to lock */
  /* Select PLL1_Output as RCLK clock */
   RCCU_RCLKSourceConfig (RCCU_PLL1_Output) ;
  /* Enable RTC and EIC clocks on APB2 */
  APB_ClockConfig (APB2, ENABLE, RTC_Periph | EIC_Periph | GPIO0_Periph);
  /* Enable the CKOUT clock for debug purpose*/
  APB_ClockConfig (APB2, ENABLE, CKOUT_Periph);
  /* RTC configuration -------------------------------------------------------*/
  /*  Configure RTC prescaler */
  RTC_PrescalerConfig(RTC_Prescaler);
  /*  Clear Pending Flags */
  RTC_FlagClear(RTC_OWIR);
  RTC_FlagClear(RTC_AIR);
  RTC_FlagClear(RTC_SIR);
  RTC_FlagClear(RTC_GIR);
  /*  Enable Alarm Interrupt */
  RTC_ITConfig( RTC_AIT, ENABLE );
  RTC_ITConfig( RTC_GIT, ENABLE );
  /* Configure the first RTC Alarm */
  RTC_AlarmConfig(RTC_CounterValue() + 5);
  EIC_Configuration();
  /*  Configure Port 0 pins */
  //GPIO_Config(GPIO0, 0xFFFF, GPIO_OUT_PP);
  //GPIO0->PD = 0x0000;
   /* Toggle the P0.0 pin */
  //GPIO_PinToggle(0,0x2FFFF);
  /* System goes into standby mode */
  PCU_STANDBY();
* Function Name  : EIC_Configuration
* Description    : Configures the interrupt controller.
* Input          : None
* Output         : None
* Return         : None
 /* Congigure the EIC to acknowledg XTI interrupt */
  EIC_IRQChannelPriorityConfig(RTC_IRQChannel,1);
  EIC_IRQChannelConfig(RTC_IRQChannel,ENABLE);
  /* Enable the IRQ */
//  EIC_IRQConfig(ENABLE);
* Function Name  : GPIO_PinToggle
* Description    : P0.0 toggling
* Input          : None
* Output         : None
* Return         : None
  u8 counter = 20;
  while(counter)
    GPIO_BitWrite (GPIO0, GPIO_PIN, 1);
    Delay(DELAY);
    GPIO_BitWrite (GPIO0, GPIO_PIN, 0);
    Delay(DELAY);
    counter--;
* Function Name  : SYS_INIT
* Description    : Initialize the system clock and IOs
* Input          : Delay value
* Output         : None
* Return         : None
void SYS_INIT(void)
 /* Set the PRCCU registers to theire reset values (This is for debug purpose) */
  RCCU->CCR = 0;
  RCCU->CFR = 0x00008008;
  RCCU->PLL1CR = 0x00000007;
  PCU->PWRCR = 0x8000;
  /* Disable all peripheral on APB1 */
  APB_ClockConfig (APB1, DISABLE,  APB1_ALL_Periph);
  /* Disable all peripheral on APB2 */
  APB_ClockConfig (APB2, DISABLE, APB2_ALL_Periph);
  /* Stop the PLL2 */
  RCCU_PLL2Disable();
  /* Stop unused periph clocks in PRCCU_PER register for low power consumption */
  RCCU->PER &= 0xfffe0014;      // save ~2mA
* Function Name  : Delay
* Description    : Inserts a delay time.
* Input          : nCount: specifies the delay time length.
* Output         : None
* Return         : None
  for(; nCount!= 0;nCount--);
/******************* (C) COPYRIGHT 2007 STMicroelectronics *****END OF FILE****/
