RTC的例程复位后死循环
2787|0
 楼主| LBZZYH 发表于 2008-5-16 10:51 | 显示全部楼层 |阅读模式
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* System Clocks Configuration */
  RCC_Configuration();
  /* NVIC configuration */
  NVIC_Configuration();
  /* Configure the GPIOs */
  GPIO_Configuration();
  /* Configure the USART1 */
  USART_Configuration();
  if(BKP_ReadBackupRegister(BKP_DR1) != 0xA5A5)
    /* Backup data register value is not correct or not yet programmed (when
       the first time the program is executed) */
    printf("  RTC not yet configured....");
    /* RTC Configuration */
    RTC_Configuration();
     printf("  RTC configured....");
    /* Adjust time by values entred by the user on the hyperterminal */
    Time_Adjust();
    BKP_WriteBackupRegister(BKP_DR1, 0xA5A5);
  else
    /* Check if the Power On Reset flag is set */
    if(RCC_GetFlagStatus(RCC_FLAG_PORRST) != RESET)
      printf("  Power On Reset occurred....");
    /* Check if the Pin Reset flag is set */
    else if(RCC_GetFlagStatus(RCC_FLAG_PINRST) != RESET)
      printf("  External Reset occurred....");
    printf("  No need to configure RTC....");
    /* Wait for RTC registers synchronization */
    RTC_WaitForSynchro();---------------------------------->复位后在这个函数中出不来
    /* Enable the RTC Second */
    RTC_ITConfig(RTC_IT_SEC, ENABLE);
    /* Wait until last write operation on RTC registers has finished */
    RTC_WaitForLastTask();
  /* Clear reset flags */
  RCC_ClearFlag();
  /* Display time in infinte loop */
  Time_Show();
