终于用PWM做成了DA
8886|7
 楼主| a_bb 发表于 2008-3-31 16:40 | 显示全部楼层 |阅读模式
PWM, TI, ST, se, IO
首先谢谢各位的建议与支持,感谢ing,当然也离不开自己的探索!
之前不能得到正确的波形,主要是混淆了PWM频率和信号的采样频率,错误地使用了用DAC做输出时的8K频率,导致滤波电路无法正常工作.
以下的程序我使用TIMER4 channel3作为PWM输出,并使用TIMER2做8K定时去更新PWM占空比,输出了1KHz的正弦波。
  TIM4 Configuration: Output Compare Inactive Mode:
  TIM4CLK = 72 MHz, Prescaler = 0, TIM2 counter clock = 72 KHz
  TIM4 frequency = TIM4CLK/(TIM1_Period + 1) = 70 KHz
void TIMER4_Configuration(void)
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  TIM_OCInitTypeDef  TIM_OCInitStructure;
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 1023;
  TIM_TimeBaseStructure.TIM_Prescaler = 0x00;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM4, &TIM_TimeBaseStructure);
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
  TIM_OCInitStructure.TIM_Channel = TIM_Channel_3;
  TIM_OCInitStructure.TIM_Pulse = 512;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OCInit(TIM4, &TIM_OCInitStructure);
  TIM_OC3PreloadConfig(TIM4, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM4, ENABLE);
  /* TIM4 enable counter */
  TIM_Cmd(TIM4, ENABLE);
void TIMER2_Configuration(void)
  TIM2 Configuration: Output Compare Inactive Mode:
  TIM2CLK = 72 MHz, Prescaler = 1000, TIM2 counter clock = 72 KHz
  TIM2 frequency = TIM2CLK/(TIM2_Period + 1) = 8KHz
  TIM_TimeBaseStructure.TIM_Period = 8;
  TIM_TimeBaseStructure.TIM_Prescaler = 1000-1;
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  /* Prescaler configuration */
//  TIM_PrescalerConfig(TIM2, 1000-1, TIM_PSCReloadMode_Immediate);
  /* Output Compare Active Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Inactive;
  TIM_OCInitStructure.TIM_Channel = TIM_Channel_1;
  TIM_OCInitStructure.TIM_Pulse = 8;
  TIM_OCInit(TIM2, &TIM_OCInitStructure);
  TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Enable);
  TIM_ARRPreloadConfig(TIM2, ENABLE);
  /* TIM IT enable */
  TIM_ITConfig(TIM2, TIM_IT_CC1, ENABLE);
  /* Set PC.06, PC.07, PC.08 and PC.09 pins */
  GPIO_SetBits(GPIOC, GPIO_Pin_6);
  /* TIM2 enable counter */
  TIM_Cmd(TIM2, ENABLE);
u16 SINDATA[8]=
    512,874,1024,874,
    512,149,0,149
* Function Name  : TIM2_IRQHandler
* Description    : This function handles TIM2 global interrupt request.
* Input          : None
* Output         : None
* Return         : None
void TIM2_IRQHandler(void)
    static u16 i=0;
    static u8 j=0;
    if (TIM_GetITStatus(TIM2, TIM_IT_CC1) != RESET)
    /* Clear TIM2 Capture Compare1 interrupt pending bit*/
    TIM_ClearITPendingBit(TIM2, TIM_IT_CC1);
    if(i==0)
         i = 1;
        GPIO_ResetBits(GPIOC, GPIO_Pin_6);
    else
         i = 0;
//  /* Set the Pulse value */
  TIM4->CCR3 = SINDATA[j++];
  if(j == 8)j = 0;
香水城 发表于 2008-4-2 10:32 | 显示全部楼层
用PWM做DA不是什么高深的问题,但是常见的问题。鼓励原创和
楼主如果能够把线路图贴出来就更好了。
short_long 发表于 2008-4-2 20:36 | 显示全部楼层
呵呵
楼主,图纸贴出来吧
 楼主| a_bb 发表于 2008-4-3 09:34 | 显示全部楼层
线路图
版权声明:
此电路图为深圳英蓓特公司STM32评估板STM103V100_EMSTMV1的一部分,版权归
深圳英蓓特公司所有。此处引用全属学习目的,并无商业用途。
如有不妥之处,请版主删贴,并表示对深圳英蓓特公司的歉意。
sunke9 发表于 2008-4-4 10:54 | 显示全部楼层
谢谢楼主共享!
ddb_21ic 发表于 2008-4-5 11:22 | 显示全部楼层
PWM输出做DAC
我觉得难点在于噪声和信号输出速度之间的矛盾
当然要求不高时就容易了
我在dsPIC上刚刚实验完,要想噪音低必然滤波就要狠一点
但是,滤波狠了输出速度就慢下来了
用四阶RC无源滤波,占空比分辨率为1/10000,仿真噪音要低于0.01%FS时
实际输出速度在10-20SPS
a7419942 发表于 2008-5-23 08:30 | 显示全部楼层
谢谢楼主共享!
 谢谢楼主共享!
dy008 发表于 2008-5-23 11:45 | 显示全部楼层
向LZ致敬!正好需要!
谢谢!
