高手请进,USART配置问题
3768|10
 楼主| chunfeng12 发表于 2008-4-11 08:08 | 显示全部楼层 |阅读模式
STM32F103的串口2配置
* Function Name  : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
void RCC_Configuration(void)
  // RCC system reset(for debug purpose)
  RCC_DeInit();
  // Enable HSE
  RCC_HSEConfig(RCC_HSE_ON);
  // Wait till HSE is ready
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    // HCLK = SYSCLK
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    // PCLK2 = HCLK
    RCC_PCLK2Config(RCC_HCLK_Div1);
    // PCLK1 = HCLK/2
    RCC_PCLK1Config(RCC_HCLK_Div2);
    // ADCCLK = PCLK2/4
    RCC_ADCCLKConfig(RCC_PCLK2_Div4);
    // Flash 2 wait state
    FLASH_SetLatency(FLASH_Latency_2);
    // Enable Prefetch Buffer
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    // PLLCLK = 8MHz * 9 = 72 MHz
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    // Enable PLL
    RCC_PLLCmd(ENABLE);
    // Wait till PLL is ready
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    // Select PLL as system clock source
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    // Wait till PLL is used as system clock source
    while(RCC_GetSYSCLKSource() != 0x08)
/* Enable peripheral clocks --------------------------------------------------*/
  // I2C1 Periph clock enable
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE);
  // Enable DMA clock
  RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA, ENABLE);
  // TIM3  TIM4  I2C1  I2C2  USART  clock enable
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM3 | RCC_APB1Periph_TIM4 | RCC_APB1Periph_I2C1 | RCC_APB1Periph_I2C2
                          | RCC_APB1Periph_USART2, ENABLE);
  // GPIOA  B  C  D  E  AFIO clock enable
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC
                         | RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE | RCC_APB2Periph_AFIO, ENABLE);
  //USART1  ADC1  clock enable
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_USART1 | RCC_APB2Periph_ADC1, ENABLE);
* Function Name  : NVIC_Configuration
* Description    : Configures Vector Table base location.
* Input          : None
* Output         : None
* Return         : None
void NVIC_Configuration(void)
  NVIC_InitTypeDef NVIC_InitStructure;
#ifdef  VECT_TAB_RAM
  // Set the Vector Table base location at 0x20000000
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  // VECT_TAB_FLASH
  // Set the Vector Table base location at 0x08000000
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
  // Configure 1 bits for preemption priority
  NVIC_PriorityGroupConfig(NVIC_PriorityGroup_1);
  // Enable the USART2 Interrupt
  NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
* Function Name  : GPIO_Configuration
* Description    : Configure the GPIOD Pins.
* Input          : None
* Output         : None
* Return         : None
void GPIO_Configuration(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  // GPIOA AF Configuration
  // PIN_2 for 485-2T   PIN_7 for OutLeft   Pin_9 for 485-1T   Pin_12 for CANT
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_7 | GPIO_Pin_9 | GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  // GPIOB AF Configuration
  // Pin_7 for OutRight
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_7;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  // Enable the I2C1 Pins Software Remapping
  GPIO_PinRemapConfig(GPIO_Remap_I2C1, ENABLE);
  // GPIOB AFOD Configuration
  // Pin_8.9 for I2C1 SCL.SDA    Pin_10.11 for I2C2 SCL.SDA
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8 | GPIO_Pin_9 | GPIO_Pin_10 | GPIO_Pin_11;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_OD;
  // GPIOA Out Configuration
  // Pin_0 for 5620Load   Pin_1 for 485-2RTS   Pin_5 for 5620DATA   Pin_8 for 485-1TRS
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_5 | GPIO_Pin_8;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  // GPIOB Out Configuration
  // Pin_0 for 165-2CLK   Pin_12 for 165-1CLK   Pin_14 for 165-1EN   Pin_15 for 5620CLK
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_12 | GPIO_Pin_14 | GPIO_Pin_15;
  // GPIOC OutConfiguration
  // Pin_5 for 165-2EN   Pin_6.7.8 for 595-1CLK.SCLK.EN   Pin_10.11.12 for 595-2CLK.SCLK.EN
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_10 | GPIO_Pin_11 | GPIO_Pin_12;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  // GPIOD Out Configuration
  // Pin_2 for BELL
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  // GPIOA INFLOATING Configuration
  // Pin_3 for 485-2R   Pin_4 for OCrossing   Pin_6 for LeftOCrossing   Pin_10 for 485-1R   Pin_11 for CANR
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_6 | GPIO_Pin_10 | GPIO_Pin_11;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  // GPIOB INFLOATING Configuration
  // Pin_1 for SIGNAL   Pin_6 for RightOCrossing   Pin_13 for 165-1Out
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1 | GPIO_Pin_6 | GPIO_Pin_13;
  // GPIOC INFLOATING Configuration
  // Pin_4 for 165-2Out   Pin_9 for Interrupt
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_4 | GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_13 | GPIO_Pin_14 | GPIO_Pin_15 | GPIO_Pin_11 | GPIO_Pin_10 | GPIO_Pin_12;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3 | GPIO_Pin_4 | GPIO_Pin_5 | GPIO_Pin_6 | GPIO_Pin_7 | GPIO_Pin_8 | GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;
    GPIO_Init(GPIOE, &GPIO_InitStructure);
  // GPIOC AIN Configuration
  // Pin_0.1.2.3 for ADC0.1.2.3
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0 | GPIO_Pin_1 | GPIO_Pin_2 | GPIO_Pin_3;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
* Function Name  : USART_Configuration
* Description    : Configures USART1 and USART2
* Input          : None
* Output         : None
* Return         : None
USART_InitStructure.USART_BaudRate = 9600;// bps.
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_2;
  USART_InitStructure.USART_Parity = USART_Parity_No ;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_RTS_CTS;//None
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  USART_InitStructure.USART_Clock = USART_Clock_Disable;
  USART_InitStructure.USART_CPOL = USART_CPOL_Low;
  USART_InitStructure.USART_CPHA = USART_CPHA_1Edge;
  USART_InitStructure.USART_LastBit = USART_LastBit_Enable;
  USART_Init(USART2, &USART_InitStructure);
    USART_ITConfig(USART2, USART_IT_TXE, ENABLE);
    //USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
  USART_Cmd(USART2, ENABLE);
* Function Name  : main
* Description    : Main program
* Input          : None
* Output         : None
* Return         : None
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* System clocks configuration ---------------------------------------------*/
  RCC_Configuration();
  /* NVIC configuration ------------------------------------------------------*/
  NVIC_Configuration();
  /* GPIO configuration */
  GPIO_Configuration();
  // Configure USART
  USART_Configuration();
    GPIO_WriteBit(GPIOA, GPIO_Pin_1, Bit_RESET);
  while(1)
  {int i;
     for(i=1;i<20;i++)
         Delay74595(500);Delay74595(500);Delay74595(500);
    USART_SendData(USART2,1);}
单片机的串口配置
void Set485asTransmitter()
{    P16=0;
void Set485asReceiver()
{    P16=1;
void Send(unsigned char com)
    SBUF=com;
    while(TI==0){;}
    TI=0;
void IniCPU110592Mhz(unsigned int baud_rate)
{//VB Setting  2400,n,8,1
     EX1=1;    //Enable Infra-Red Interruption
    IT1=1;    // Falling Edge Triger INT1 (Infra-red Interruption)
      PX1=1;    // INT1 (Infra-red) prioritary
     EX0=1;    // Zero-crossing Interruption Enabled
    IT0=1;    // -_ INT0 (Zero Interruption)
//      TMOD=0x21;/*Timer 0(ZERO_CROSSING): MODE 1, Timer 1:MODE 2 (AUTOCHARGING)
 // Timer0 for Zero_crossing    Timer1 for BAUD RATE for 4800     Timer2 for Infra_red
    PS=1;
    switch(baud_rate)
          case 1200: TH1=TL1=0xe8;PCON=0;TMOD=0x21;break;
          case 2400:  TH1=TL1=0xf4;PCON=0;TMOD=0x21;break;
          case 4800:  TH1=TL1=0xfa;PCON=0;TMOD=0x21;break;
          case 9600:  TH1=TL1=0xfd;PCON=0;TMOD=0x21;break;
          case 19200:  TH1=TL1=0xfd;PCON=0x80;TMOD=0x21;break;
    SCON=0x50;// 11 bit
    ES=1;
    TR1=1;    // Start TIMER 1 for BAUD RATE generation
    T2CON=0x00;    //TF2:0,EXF2:0, RCLK:1, TCLK:1, EXEN2:0, TR2:1,
    TR2=1;
    TH0=-(1000/256);
    TL0=-(1000%256);
    ET0=1;
    TR0=1;
    EA=1;
void SSIO(void) interrupt 4 using 1
   if(RI)
       RI=0;
       SerialRe[SerialReIndicator]=SBUF;
       {SerialReIndicator+=1;}
       if(SerialReIndicator==30)
           SerialReIndicator=0;
void main(void)
{uchar i;
    IniCPU110592Mhz(9600);
    while(1)
            for(i=1;i<21;i++)
            //Set485asTransmitter();Delay(90);
                     //Send(0x1);
                Delay(90);
            //Set485asReceiver();
通过以上配置后运行程序,STM32发送数据,单片机接收,单片机接收到的数据要么全是“0x01”,要么全是“0x64”,我查过是否是波特率的问题,经过验证,波特率都是9600.在配置上有什么问题吗?
 楼主| chunfeng12 发表于 2008-4-11 08:51 | 显示全部楼层
补充一下
如果使用单片机持续发送1~100,STM32来接收,接收到的数据可以保证100次无差错,单片机型号是AT89C55WD
 楼主| chunfeng12 发表于 2008-4-11 11:26 | 显示全部楼层
初步结果
在对STM32每发送一个数据后增加一个执行20000条空语句的延时后,单片机接收到的数据很稳定,可以保证100次无差错。这就是STM32与51速度上的差别吗?我观察了单片机每发送一个数据不加延时的波形,发现每次有100us左右的延时,再观察STM32每发送一个数据不加延时的波形,这时我的示波器已经捕获不到数据之间的延时。如果真的需要在每次发送一个数据STM32都要有个延时,这个延时的时间是不是太久了,资源上的浪费太大。如果改用STM32之间的通讯,成本上又增加了。期待折中的办法或更高明的结论。欢迎来讨论哈!!
迂腐只见,仅供参考!
香水城 发表于 2008-4-11 11:47 | 显示全部楼层
发送完一个字节后,你必须等发送缓冲器变空之后才能再发
否则后面的字节要把前面的未传输完成的数据破坏掉,可以用轮询或中断获知发送缓冲器变空。请参考ST提供的例子。
 楼主| chunfeng12 发表于 2008-4-11 12:46 | 显示全部楼层
香主的说法似乎不能解释这个问题
曾经尝试过用同样的程序在STM32之间进行串口的收发数据,即使不对USART_FLAG_TXE位进行判断,观察接收到的数据也是完全可靠的。当然,还是对USART_FLAG_TXE位进行判断比较可靠。
香水城 发表于 2008-4-11 13:13 | 显示全部楼层
如果是这样,你就需要用示波器看看字节与字节之间的间距
字节与字节之间的间距被拉长,你的接收方才能正确接收,这表示接收方太慢了,你要想办法改进,加快接收方的处理速度。
 楼主| chunfeng12 发表于 2008-4-11 14:21 | 显示全部楼层
这个问题我在3楼已经想到
字节与字节之间的间距确实被拉长,也就是您说的“接收方太慢了”
我是个菜鸟,对待这种问题没了主见,所以发帖到网上寻求帮助o(∩_∩)o
香水城 发表于 2008-4-11 14:30 | 显示全部楼层
哈哈,你已经不是菜鸟了
3楼的分析表示你经过了自己的思考,我认为会思考的人都不菜。
赶快看看优化一下你的接收方吧。
 楼主| chunfeng12 发表于 2008-4-11 16:48 | 显示全部楼层
还是迷糊
加了2条限制语句
    while(USART_GetFlagStatus(USART2, USART_FLAG_TC) == RESET);
         while(USART_GetFlagStatus(USART2, USART_FLAG_TXE) == RESET);
现在单片机的接收正常了,只是不明白这是为什么,这比延时程序的执行时间少多了,为什么把延时时间设置的比这个时间长,比3楼是说的那个短时,单片机的接收就不稳定了呢?
香水城 发表于 2008-4-11 17:09 | 显示全部楼层
通过示波器看看波形,应该可以找出差别
 楼主| chunfeng12 发表于 2008-4-11 18:18 | 显示全部楼层
弄了一天了
感谢香主的回应,不过还是没搞清楚具体的原因。真的菜了,都弄半导体4个月了!
