[应用相关] ucos 一个函数 谁能帮忙解决一下
3203|2
 楼主| jackbao 发表于 2008-4-17 09:53 | 显示全部楼层 |阅读模式
static  void  AppTaskStart (void *p_arg)
    CPU_INT32U  i;
    CPU_INT32U  j;
    (void)p_arg;
    BSP_Init();                                                 /* Initialize BSP functions                                 */
#if (OS_TASK_STAT_EN > 0)
    OSStatInit();                                               /* Determine CPU capacity                                   */
#endif
#if (uC_PROBE_COM_MODULE > 0)
    ProbeCom_Init();                                            /* Initialize the uC/Probe communications module            */
    ProbeRS232_Init(115200);
    ProbeRS232_RxIntEn();
#endif
#if (uC_PROBE_OS_PLUGIN > 0)
#if (uC_PROBE_COM_MODULE   > 0) &&
    (PROBE_COM_STAT_EN     > 0)
    Probe_RS232RxSpd       = 0;
    Probe_RS232TxSpd       = 0;
    Probe_ComRxPktSpd      = 0;
    Probe_ComTxPktSpd      = 0;
    Probe_ComTxSymSpd      = 0;
    Probe_ComTxSymByteSpd  = 0;
    Probe_RS232RxLast      = 0;
    Probe_RS232TxLast      = 0;
    Probe_ComRxPktLast     = 0;
    Probe_ComTxPktLast     = 0;
    Probe_ComTxSymLast     = 0;
    Probe_ComTxSymByteLast = 0;
    Probe_ComCtrLast       = 0;
#endif
    OSProbe_Init();
    OSProbe_SetCallback(AppProbeCallback);
    OSProbe_SetDelay(50);
#endif
    AppUserIFMbox = OSMboxCreate((void *)0);                    /* Create MBOX for communication between Kbd and UserIF     */
    AppTaskCreate();                                            /* Create application tasks                                 */
    while (DEF_TRUE) {                                          /* Task body, always written as an infinite loop.           */
        for (j = 0; j < 4; j++) {
            for (i = 1; i <= 4; i++) {
                LED_On(i);
                OSTimeDlyHMSM(0, 0, 1, 50);
                LED_Off(i);
            for (i = 3; i >= 2; i--) {
                LED_On(i);
                LED_Off(i);
                OSTimeDlyHMSM(0, 0, 2, 50);
        for (i = 0; i < 4; i++) {
            LED_On(0);
            OSTimeDlyHMSM(0, 0, 0, 200);
            LED_Off(0);
 楼主| jackbao 发表于 2008-4-17 09:54 | 显示全部楼层
谁能帮忙解释一下
每个语句的功能
dld2 发表于 2008-4-17 10:11 | 显示全部楼层
AppTaskStart 就不是ucos的函数
Os开头的才是
