如此设置,怎么不能进入系统时钟中断??
3190|0
 楼主| zoe2003 发表于 2008-6-23 18:05 | 显示全部楼层 |阅读模式
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x_lib.h"
#include "stdio.h"
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
u8 USART2_Counter=0;
u8 USART2_Send_Flage=0;
/* Private function prototypes -----------------------------------------------*/
void RCC_Configuration(void);     /* 系统时钟设置 */
void GPIO_Configuration(void);     /* 端口设置 */
void NVIC_Configuration(void);     /* NVIC中断向量设置 */
/* Private functions ---------------------------------------------------------*/
* Function Name  : main
* Description    : Main program
* Input          : None
* Output         : None
* Return         : None
int main(void)
  /* 系统时钟设置 */
  RCC_Configuration();
  /* NVIC中断向量设置 */
  NVIC_Configuration();
  /* 端口设置 */
  GPIO_Configuration();
  /*系统时钟设置 HCLK=36MKZ,SysTick=4.5MKZ,Reload=49500,每11ms 产生一个中断,开系统时钟中断*/
  SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK_Div8);
  SysTick_SetReload(49500);
  SysTick_ITConfig(ENABLE);
  SysTick_CounterCmd(SysTick_Counter_Enable);
  while(1)
     if(USART2_Send_Flage==1)
       GPIO_WriteBit(GPIOA, GPIO_Pin_0,(BitAction)~GPIO_ReadOutputDataBit(GPIOA, GPIO_Pin_0));
* Function Name  : RCC_Configuration
* Description    : 配置不同的系统时钟.
* Input          : None
* Output         : None
* Return         : None
  ErrorStatus HSEStartUpStatus;
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* HCLK = SYSCLK =36MHZ*/
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK=36MHZ */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 =18MHZ*/
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /*系统时钟36MK PLLCLK = 4MHz * 9 = 36MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div2, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
  /* 开  GPIOA时钟 36MHZ*/
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA , ENABLE);
* Function Name  : GPIO_Configuration
* Description    : 配置不同的GPIO引脚.
* Input          : None
* Output         : None
* Return         : None
  GPIO_InitTypeDef GPIO_InitStructure;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
* Function Name  : NVIC_Configuration
* Description    : Configures Vector Table base location.
* Input          : None
* Output         : None
* Return         : None
#ifdef  VECT_TAB_RAM
  /* Set the Vector Table base location at 0x20000000 */
  NVIC_SetVectorTable(NVIC_VectTab_RAM, 0x0);
#else  /* VECT_TAB_FLASH  */
  /* Set the Vector Table base location at 0x08000000 */
  NVIC_SetVectorTable(NVIC_VectTab_FLASH, 0x0);
#endif
#ifdef  DEBUG
* Function Name  : assert_failed
* Description    : Reports the name of the source file and the source line number
*                  where the assert error has occurred.
* Input          : - file: pointer to the source file name
*                  - line: assert error line source number
* Output         : None
* Return         : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d ", file, line) */
  /* Infinite loop */
  while (1)
#endif
中断处理/*******************************************************************************
* Function Name  : SysTickHandler
* Description    : This function handles SysTick Handler.
* Input          : None
* Output         : None
* Return         : None
void SysTickHandler(void)
  extern u8 USART2_Counter;
  extern u8 USART2_Send_Flage;
  USART2_Counter++;
  if(USART2_Counter==300)  // 系统时钟每11ms产生一个中断,则3.3s则产生300次中断。3.3s GPIOA的引脚翻转一次,所接的LCD指示灯应该闪烁一次。
    USART2_Send_Flage=1;
    USART2_Counter=0;
  但是我所设置的指示灯一直都没有亮过,我把设置GPIO翻转写在中断里也是同样的情况,我怀疑没有进入系统时钟中断。我主要的目的是实现用系统时钟定时,指示灯只是一个测试的单元。
  为什么会出现这种情况,请高手指点!!谢谢!!
