串行通讯USART3?
3623|5
 楼主| kfawj 发表于 2008-7-7 11:21 | 显示全部楼层 |阅读模式
#include "stm32f10x_lib.h"
#include "Test01.h"
#include "lcd.h"
#define _test
int main()
//   u16 i,j;
#ifdef DEBUG
  debug();
#endif
  RCC_Configuration();
  GPIO_Config();
  UART_Init();
  LcdShow_Init();
  LAMP_ON
  /* Configure HCLK clock as SysTick clock source */
  SysTick_CLKSourceConfig(SysTick_CLKSource_HCLK);
  /* SysTick interrupt each 100 Hz with HCLK equal to 72MHz */
  SysTick_SetReload(720000);
  /* Enable the SysTick Interrupt */
  SysTick_ITConfig(ENABLE);
  /* Enable the SysTick Counter */
  SysTick_CounterCmd(SysTick_Counter_Enable);
  while(1){
    GPIO_SetBits(GPIOB, GPIO_Pin_2);
    USART_SendData(USART3, 0x55);
    GPIO_ResetBits(GPIOA, GPIO_Pin_0);
    Delay_T(1000);
    GPIO_SetBits(GPIOA, GPIO_Pin_0);
    GPIO_ResetBits(GPIOA, GPIO_Pin_1);
    Delay_T(1000);
    GPIO_SetBits(GPIOA, GPIO_Pin_1);
    GPIO_ResetBits(GPIOA, GPIO_Pin_4);
    Delay_T(1000);
    GPIO_SetBits(GPIOA, GPIO_Pin_4);
    GPIO_ResetBits(GPIOA, GPIO_Pin_5);
    //LAMP_OFF
    Delay_T(1000);
    GPIO_SetBits(GPIOA, GPIO_Pin_5);
    GPIO_ResetBits(GPIOA, GPIO_Pin_6);
    Delay_T(1000);
    GPIO_SetBits(GPIOA, GPIO_Pin_6);
     GPIO_ResetBits(GPIOA, GPIO_Pin_7);
     Delay_T(1000);
     GPIO_SetBits(GPIOA, GPIO_Pin_7);
  //return 1;
#ifdef  DEBUG
* Function Name  : assert_failed
* Description    : Reports the name of the source file and the source line number
*                  where the assert error has occurred.
* Input          : - file: pointer to the source file name
*                  - line: assert error line source number
* Output         : None
* Return         : None
void assert_failed(u8* file, u32 line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d ", file, line) */
  /* Infinite loop */
  while (1)
#endif
* Function Name  : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
void RCC_Configuration(void)
  ErrorStatus HSEStartUpStatus;
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus=ERROR;
  while(HSEStartUpStatus==ERROR)
    HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* ADCCLK = PCLK2/6 */
    RCC_ADCCLKConfig(RCC_PCLK2_Div6);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    RCC_USBCLKConfig(RCC_USBCLKSource_PLLCLK_1Div5);
    /* PLLCLK = 4MHz * 9 = 36 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_12);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
  /* Enable GPIOA, GPIOB, GPIOC, GPIOD, GPIOE and AFIO clocks */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |RCC_APB2Periph_GPIOC
         | RCC_APB2Periph_GPIOD | RCC_APB2Periph_GPIOE | RCC_APB2Periph_AFIO, ENABLE);
  /* TIM2 clocks enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  /* CAN Periph clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN, ENABLE);
void GPIO_Config(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_4|GPIO_Pin_5
                               |GPIO_Pin_6|GPIO_Pin_7|GPIO_Pin_8|GPIO_Pin_11
                               |GPIO_Pin_12|GPIO_Pin_13|GPIO_Pin_14;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOA, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_All;
  GPIO_Init(GPIOC, &GPIO_InitStructure);
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_15;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2|GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_3|GPIO_Pin_10;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_11;
  //GPIO_PinRemapConfig(GPIO_Remap_SWJ_JTAGDisable,ENABLE);
void LcdShow_Init(void)
  NVIC_InitTypeDef NVIC_InitStructure;
  TIM_TimeBaseInitTypeDef  TIM_TimeBaseStructure;
  TIM_OCInitTypeDef  TIM_OCInitStructure;
  NVIC_InitStructure.NVIC_IRQChannel=TIM2_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 8000;
  TIM_TimeBaseStructure.TIM_Prescaler = 17;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  TIM_ARRPreloadConfig(TIM2,DISABLE);
  /* only counter overflow/underflow generate U interrupt */
  TIM_UpdateRequestConfig(TIM2,TIM_UpdateSource_Regular);
  /* Output Compare Timing Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing;
  TIM_OCInitStructure.TIM_Channel = TIM_Channel_1;
  TIM_OCInitStructure.TIM_Pulse = 4000;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OCInit(TIM2, &TIM_OCInitStructure);
  TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Disable);
  /* TIM IT enable */
  TIM_ITConfig(TIM2, TIM_IT_CC1 | TIM_IT_Update, ENABLE);
  /* TIM2 enable counter */
  TIM_Cmd(TIM2, ENABLE);
void UART_Init(void)
  USART_InitStructure.USART_BaudRate = 9600;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_Even;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  USART_InitStructure.USART_Clock = USART_Clock_Disable;
  USART_InitStructure.USART_CPOL = USART_CPOL_Low;
  USART_InitStructure.USART_CPHA = USART_CPHA_2Edge;
  USART_InitStructure.USART_LastBit = USART_LastBit_Disable;
  USART_Init(USART3,&USART_InitStructure);
  USART_Cmd(USART3,ENABLE);
  //USART_ITConfig(USART3, USART_IT_RXNE,ENABLE);
void Delay_T(u16 D_T)
  Delay_Time = D_T;
  while(Delay_Time);
 楼主| kfawj 发表于 2008-7-7 11:24 | 显示全部楼层
这个程序大部分是抄的
例程
但,不知道为什么就是总不能正确的发数据?
这样把虽然整个程序贴上来有点不好,但我只是想有我写的东东拿出来,以便分析!
谢谢啦
 楼主| kfawj 发表于 2008-7-7 15:04 | 显示全部楼层
问题已经解决啦!
问题找到啦?且已经解决。
缺少:
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_USART3, ENABLE);
 楼主| kfawj 发表于 2008-7-8 14:56 | 显示全部楼层
新问题,中断进不去
  USART_InitStructure.USART_WordLength = USART_WordLength_9b;
  USART_ITConfig(USART3, USART_IT_TXE,ENABLE);
  USART_ITConfig(USART3, USART_IT_TC,ENABLE);
//中断进不去,这样设置对吗?(现在只是发数)
//主程中用“   USART_SendData(USART3, 0x55);”向外发数据
香水城 发表于 2008-7-8 17:26 | 显示全部楼层
初始化NVIC了吗?
 楼主| kfawj 发表于 2008-7-10 16:27 | 显示全部楼层
噢!
知道了。没有初始化!
但我的Time2可以顺利的进入中断呀!
不知道为什么?
