[其他ST产品] **的V6400左右可以买到
12860|25
 楼主| nbdonar 发表于 2008-8-15 23:51 | 显示全部楼层
报告结果.现已可以使用JLINK
升级IAR 4.22至5.11版,JLINK调试正常.(4.22用重装后用原装的JLINK也不行)
原因可能是STR755FR2只有16K RAM,4.22的JLINK驱动占用的RAM比较大而导致的烧写失败.
grant_jx 发表于 2008-8-16 19:03 | 显示全部楼层
这不是原因,我用的是IAR 4,11A,打补丁方式
刚刚我试了一下连上ST官方的STR750-EVAL,跑了个GPIO例程,单步 、全速没有任何问题。
也许是你的JLink驱动问题?在http://www.segger.com上可以更新JLink驱动。
 楼主| nbdonar 发表于 2008-8-16 23:48 | 显示全部楼层
JLink驱动我也更新过,也是没用的.
还有现在又有复位问题了.(另开了一贴)不知道你们遇到过没有.
 楼主| nbdonar 发表于 2008-8-17 13:36 | 显示全部楼层
完全确认,是PCB板上有跟线虚断.复位也正常了.
lindream 发表于 2009-8-14 11:01 | 显示全部楼层
IAR + IAR j-link download出错!
Sun Apr 29 15:51:45 2007: J-Link firmware: V1.20 (J-Link compiled Mar 22 2007 16:08:22 ARM Rev.5)
Sun Apr 29 15:51:45 2007: JTAG speed is initially set to: 32 kHz
Sun Apr 29 15:51:45 2007: Resetting target using RESET pin
Sun Apr 29 15:51:45 2007: HARDWARE reset with strategy 0 was performed
Sun Apr 29 15:51:45 2007: Initial reset was performed
Sun Apr 29 15:51:45 2007: J-Link found 1 JTAG DEVICE. ARM core Id: 3F0F0F0F(ARM7)
Sun Apr 29 15:51:45 2007: DEVICE at TAP0 selected
Sun Apr 29 15:51:45 2007: Auto JTAG speed: 8000 kHz
Sun Apr 29 15:51:46 2007: 688 bytes downloaded and verified (1.13 Kbytes/sec)
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x000080C8
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x000080CC
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x000080D0
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x000080D2
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x000080E8
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008128
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x0000812C
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008130
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008132
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008150
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008158
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x0000815A
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008160
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x0000817D
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008180
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008182
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x000081A4
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008242
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008001
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008004
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008038
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008244
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008248
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x0000824E
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x000082A4
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x0000825C
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008268
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008281
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00000020
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008042
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x0000806C
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008078
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008080
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008094
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x000080A4
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x000080B8
Sun Apr 29 15:51:46 2007: Warning: Target inconsistency detected at MEMORY address 0x00008298
Sun Apr 29 15:51:46 2007: There were warnings during download, see Log Window
