[DemoCode下载] NUC505上实现USB KEYBOARD及MOUSE
3162|9
 楼主| a_ziliu 发表于 2015-9-9 16:33 | 显示全部楼层 |阅读模式
官网上的只有USB MOUSE,现在把USB KEYBOARD结合在一起。
BSP_NUC505_v3.00.003 HID MOUSE KEYBOARD.zip (354.12 KB, 下载次数: 58)
稳稳の幸福 发表于 2015-9-9 17:56 | 显示全部楼层
键盘和鼠标,一起搞了。
捉虫天师 发表于 2015-9-9 19:35 | 显示全部楼层
这个貌似前段已经有人发过了
天灵灵地灵灵 发表于 2015-9-9 19:55 | 显示全部楼层
* @file     main.c
* @version  V1.00
* $Date: 14/05/30 6:07p $
* @brief    Simulate an USB mouse and draws circle on the screen
* @note
* Copyright (C) 2014 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "NUC505Series.h"
#include "hid_mouse.h"
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable  XTAL */
    CLK->PWRCTL |= CLK_PWRCTL_HXTEN_Msk;
    CLK_SetCoreClock(96000000);
    /* Set PCLK divider */
    CLK_SetModuleClock(PCLK_MODULE, NULL, 1);
    /* Update System Core Clock */
    SystemCoreClockUpdate();
    /* Enable IP clock */
    CLK_EnableModuleClock(UART0_MODULE);
    /* Select IP clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_UART0_SRC_EXT, 0);
    /* Enable USB IP clock */
    CLK_EnableModuleClock(USBD_MODULE);
    /* Select USB IP clock source */
    CLK_SetModuleClock(USBD_MODULE, CLK_USBD_SRC_EXT, 0);
    /* Init I/O Multi-function        */
    /* Configure multi-function pins for UART0 RXD and TXD */
    SYS->GPB_MFPL  = (SYS->GPB_MFPL & (~SYS_GPB_MFPL_PB0MFP_Msk) ) | SYS_GPB_MFPL_PB0MFP_UART0_TXD;
    SYS->GPB_MFPL  = (SYS->GPB_MFPL & (~SYS_GPB_MFPL_PB1MFP_Msk) ) | SYS_GPB_MFPL_PB1MFP_UART0_RXD;
void UART0_Init()
    /* Init UART        */
    /* Reset UART module */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 baud rate */
    UART_Open(UART0, 115200);
/*  Main Function        */
int32_t main (void)
    /* Init System, IP clock and multi-function I/O
       In the end of SYS_Init() will issue SYS_LockReg()
       to lock protected register. If user want to write
       protected register, please issue SYS_UnlockReg()
       to unlock protected register if necessary */
    SYS_Init();
    /* Init UART to 115200-8n1 for print message */
    UART0_Init();
    printf("\nNUC505 USB HID\n");
    USBD_Open(&gsInfo, HID_ClassRequest, NULL);
    /* Endpoint configuration */
    HID_Init();
    /* Enable USBD interrupt */
    NVIC_EnableIRQ(USBD_IRQn);
    /* Start transaction */
    USBD_Start();
    GPIO_SetMode(PB, BIT11, GPIO_MODE_INPUT);
    while(1) {
        HID_UpdateKeyboardData();
                          HID_UpdateMouseData();
/*** (C) COPYRIGHT 2013 Nuvoton Technology Corp. ***/
643757107 发表于 2015-9-9 20:17 | 显示全部楼层
NVIC_EnableIRQ(USBD_IRQn);这个好像还可以带LCD。
wahahaheihei 发表于 2015-9-9 20:32 | 显示全部楼层
* @file     hid_mouse.c
* @version  V1.00
* $Date: 14/11/17 5:36p $
* @brief    NUC505 USBD driver Sample file
* @note
* Copyright (C) 2013 Nuvoton Technology Corp. All rights reserved.
/*!<Includes */
#include <string.h>
signed char mouse_table[] = {-16, -16, -16, 0, 16, 16, 16, 0};
uint8_t mouse_idx = 0;
uint8_t move_len, mouse_mode=1;
uint8_t volatile g_u8EPAReady = 0;
uint8_t volatile g_u8EPBReady = 0;
void USBD_IRQHandler(void)
    __IO uint32_t IrqStL, IrqSt;
    IrqStL = USBD->GINTSTS & USBD->GINTEN;    /* get interrupt status */
    if (!IrqStL)    return;
    /* USB interrupt */
    if (IrqStL & USBD_GINTSTS_USBIF_Msk) {
        IrqSt = USBD->BUSINTSTS & USBD->BUSINTEN;
        if (IrqSt & USBD_BUSINTSTS_SOFIF_Msk)
            USBD_CLR_BUS_INT_FLAG(USBD_BUSINTSTS_SOFIF_Msk);
        if (IrqSt & USBD_BUSINTSTS_RSTIF_Msk) {
            USBD_SwReset();
            USBD_ResetDMA();
            USBD->EP[EPA].EPRSPCTL = USBD_EPRSPCTL_FLUSH_Msk;
            USBD->EP[EPB].EPRSPCTL = USBD_EPRSPCTL_FLUSH_Msk;
            if (USBD->OPER & 0x04)  /* high speed */
                HID_InitForHighSpeed();
            else                    /* full speed */
                HID_InitForFullSpeed();
            USBD_ENABLE_CEP_INT(USBD_CEPINTEN_SETUPPKIEN_Msk);
            USBD_SET_ADDR(0);
            USBD_ENABLE_BUS_INT(USBD_BUSINTEN_RSTIEN_Msk|USBD_BUSINTEN_RESUMEIEN_Msk|USBD_BUSINTEN_SUSPENDIEN_Msk);
            USBD_CLR_BUS_INT_FLAG(USBD_BUSINTSTS_RSTIF_Msk);
            USBD_CLR_CEP_INT_FLAG(0x1ffc);
        if (IrqSt & USBD_BUSINTSTS_RESUMEIF_Msk) {
            USBD_ENABLE_BUS_INT(USBD_BUSINTEN_RSTIEN_Msk|USBD_BUSINTEN_SUSPENDIEN_Msk);
            USBD_CLR_BUS_INT_FLAG(USBD_BUSINTSTS_RESUMEIF_Msk);
        if (IrqSt & USBD_BUSINTSTS_SUSPENDIF_Msk) {
            USBD_ENABLE_BUS_INT(USBD_BUSINTEN_RSTIEN_Msk | USBD_BUSINTEN_RESUMEIEN_Msk);
            USBD_CLR_BUS_INT_FLAG(USBD_BUSINTSTS_SUSPENDIF_Msk);
        if (IrqSt & USBD_BUSINTSTS_HISPDIF_Msk) {
            USBD_CLR_BUS_INT_FLAG(USBD_BUSINTSTS_HISPDIF_Msk);
        if (IrqSt & USBD_BUSINTSTS_DMADONEIF_Msk) {
            g_usbd_DmaDone = 1;
            USBD_CLR_BUS_INT_FLAG(USBD_BUSINTSTS_DMADONEIF_Msk);
            if (USBD->DMACTL & USBD_DMACTL_DMARD_Msk) {
                if (g_usbd_ShortPacket == 1) {
                    USBD->EP[EPA].EPRSPCTL = USBD->EP[EPA].EPRSPCTL & 0x10 | USB_EP_RSPCTL_SHORTTXEN;    // packet end
                    g_usbd_ShortPacket = 0;
        if (IrqSt & USBD_BUSINTSTS_PHYCLKVLDIF_Msk)
            USBD_CLR_BUS_INT_FLAG(USBD_BUSINTSTS_PHYCLKVLDIF_Msk);
        if (IrqSt & USBD_BUSINTSTS_VBUSDETIF_Msk) {
            if (USBD_IS_ATTACHED()) {
                /* USB Plug In */
                USBD_ENABLE_USB();
            } else {
                /* USB Un-plug */
                USBD_DISABLE_USB();
            USBD_CLR_BUS_INT_FLAG(USBD_BUSINTSTS_VBUSDETIF_Msk);
    if (IrqStL & USBD_GINTSTS_CEPIF_Msk) {
        IrqSt = USBD->CEPINTSTS & USBD->CEPINTEN;
        if (IrqSt & USBD_CEPINTSTS_SETUPTKIF_Msk) {
            USBD_CLR_CEP_INT_FLAG(USBD_CEPINTSTS_SETUPTKIF_Msk);
            return;
        if (IrqSt & USBD_CEPINTSTS_SETUPPKIF_Msk) {
            USBD_CLR_CEP_INT_FLAG(USBD_CEPINTSTS_SETUPPKIF_Msk);
            USBD_ProcessSetupPacket();
            return;
        if (IrqSt & USBD_CEPINTSTS_OUTTKIF_Msk) {
            USBD_CLR_CEP_INT_FLAG(USBD_CEPINTSTS_OUTTKIF_Msk);
            USBD_ENABLE_CEP_INT(USBD_CEPINTEN_STSDONEIEN_Msk);
            return;
        if (IrqSt & USBD_CEPINTSTS_INTKIF_Msk) {
            USBD_CLR_CEP_INT_FLAG(USBD_CEPINTSTS_INTKIF_Msk);
            if (!(IrqSt & USBD_CEPINTSTS_STSDONEIF_Msk)) {
                USBD_CLR_CEP_INT_FLAG(USBD_CEPINTSTS_TXPKIF_Msk);
                USBD_ENABLE_CEP_INT(USBD_CEPINTEN_TXPKIEN_Msk);
                USBD_CtrlIn();
            } else {
                USBD_ENABLE_CEP_INT(USBD_CEPINTEN_TXPKIEN_Msk|USBD_CEPINTEN_STSDONEIEN_Msk);
            return;
        if (IrqSt & USBD_CEPINTSTS_PINGIF_Msk) {
            USBD_CLR_CEP_INT_FLAG(USBD_CEPINTSTS_PINGIF_Msk);
            return;
        if (IrqSt & USBD_CEPINTSTS_TXPKIF_Msk) {
            USBD_CLR_CEP_INT_FLAG(USBD_CEPINTSTS_STSDONEIF_Msk);
            USBD_SET_CEP_STATE(USB_CEPCTL_NAKCLR);
            if (g_usbd_CtrlInSize) {
                USBD_ENABLE_CEP_INT(USBD_CEPINTEN_INTKIEN_Msk);
            } else {
                USBD_ENABLE_CEP_INT(USBD_CEPINTEN_SETUPPKIEN_Msk|USBD_CEPINTEN_STSDONEIEN_Msk);
            return;
        if (IrqSt & USBD_CEPINTSTS_RXPKIF_Msk) {
            USBD_CLR_CEP_INT_FLAG(USBD_CEPINTSTS_RXPKIF_Msk);
            return;
        if (IrqSt & USBD_CEPINTSTS_NAKIF_Msk) {
            USBD_CLR_CEP_INT_FLAG(USBD_CEPINTSTS_NAKIF_Msk);
            return;
        if (IrqSt & USBD_CEPINTSTS_STALLIF_Msk) {
            USBD_CLR_CEP_INT_FLAG(USBD_CEPINTSTS_STALLIF_Msk);
            return;
        if (IrqSt & USBD_CEPINTSTS_ERRIF_Msk) {
            USBD_CLR_CEP_INT_FLAG(USBD_CEPINTSTS_ERRIF_Msk);
            return;
        if (IrqSt & USBD_CEPINTSTS_STSDONEIF_Msk) {
            USBD_UpdateDeviceState();
            return;
        if (IrqSt & USBD_CEPINTSTS_BUFFULLIF_Msk) {
            USBD_CLR_CEP_INT_FLAG(USBD_CEPINTSTS_BUFFULLIF_Msk);
            return;
        if (IrqSt & USBD_CEPINTSTS_BUFEMPTYIF_Msk) {
            USBD_CLR_CEP_INT_FLAG(USBD_CEPINTSTS_BUFEMPTYIF_Msk);
            return;
    /* interrupt in */
    if (IrqStL & USBD_GINTSTS_EPAIF_Msk) {
        IrqSt = USBD->EP[EPA].EPINTSTS & USBD->EP[EPA].EPINTEN;
        USBD_ENABLE_EP_INT(EPA, 0);
        EPA_Handler();
        USBD_CLR_EP_INT_FLAG(EPA, IrqSt);
    /* interrupt out */
    if (IrqStL & USBD_GINTSTS_EPBIF_Msk) {
        IrqSt = USBD->EP[EPB].EPINTSTS & USBD->EP[EPB].EPINTEN;
        USBD_ENABLE_EP_INT(EPB, 0);
        EPB_Handler();
        USBD_CLR_EP_INT_FLAG(EPB, IrqSt);
    if (IrqStL & USBD_GINTSTS_EPCIF_Msk) {
        IrqSt = USBD->EP[EPC].EPINTSTS & USBD->EP[EPC].EPINTEN;
        USBD_CLR_EP_INT_FLAG(EPC, IrqSt);
    if (IrqStL & USBD_GINTSTS_EPDIF_Msk) {
        IrqSt = USBD->EP[EPD].EPINTSTS & USBD->EP[EPD].EPINTEN;
        USBD_CLR_EP_INT_FLAG(EPD, IrqSt);
    if (IrqStL & USBD_GINTSTS_EPEIF_Msk) {
        IrqSt = USBD->EP[EPE].EPINTSTS & USBD->EP[EPE].EPINTEN;
        USBD_CLR_EP_INT_FLAG(EPE, IrqSt);
    if (IrqStL & USBD_GINTSTS_EPFIF_Msk) {
        IrqSt = USBD->EP[EPF].EPINTSTS & USBD->EP[EPF].EPINTEN;
        USBD_CLR_EP_INT_FLAG(EPF, IrqSt);
    if (IrqStL & USBD_GINTSTS_EPGIF_Msk) {
        IrqSt = USBD->EP[EPG].EPINTSTS & USBD->EP[EPG].EPINTEN;
        USBD_CLR_EP_INT_FLAG(EPG, IrqSt);
    if (IrqStL & USBD_GINTSTS_EPHIF_Msk) {
        IrqSt = USBD->EP[EPH].EPINTSTS & USBD->EP[EPH].EPINTEN;
        USBD_CLR_EP_INT_FLAG(EPH, IrqSt);
    if (IrqStL & USBD_GINTSTS_EPIIF_Msk) {
        IrqSt = USBD->EP[EPI].EPINTSTS & USBD->EP[EPI].EPINTEN;
        USBD_CLR_EP_INT_FLAG(EPI, IrqSt);
    if (IrqStL & USBD_GINTSTS_EPJIF_Msk) {
        IrqSt = USBD->EP[EPJ].EPINTSTS & USBD->EP[EPJ].EPINTEN;
        USBD_CLR_EP_INT_FLAG(EPJ, IrqSt);
    if (IrqStL & USBD_GINTSTS_EPKIF_Msk) {
        IrqSt = USBD->EP[EPK].EPINTSTS & USBD->EP[EPK].EPINTEN;
        USBD_CLR_EP_INT_FLAG(EPK, IrqSt);
    if (IrqStL & USBD_GINTSTS_EPLIF_Msk) {
        IrqSt = USBD->EP[EPL].EPINTSTS & USBD->EP[EPL].EPINTEN;
        USBD_CLR_EP_INT_FLAG(EPL, IrqSt);
void EPA_Handler(void)  /* Interrupt IN handler */
    g_u8EPAReady = 1;
void EPB_Handler(void)  /* Interrupt IN handler */
    g_u8EPBReady = 1;
  * @brief  USBD Endpoint Config.
  * @param  None.
  * @retval None.
void HID_InitForHighSpeed(void)
    /* EPA ==> Interrupt IN endpoint, address 1 */
    USBD_SetEpBufAddr(EPA, EPA_BUF_BASE, EPA_BUF_LEN);
    USBD_SET_MAX_PAYLOAD(EPA, EPA_MAX_PKT_SIZE);
    USBD_ConfigEp(EPA, INT_IN1_EP_NUM, USB_EP_CFG_TYPE_INT, USB_EP_CFG_DIR_IN);
           USBD_SetEpBufAddr(EPB, EPB_BUF_BASE, EPB_BUF_LEN);
    USBD_SET_MAX_PAYLOAD(EPB, EPB_MAX_PKT_SIZE);
    USBD_ConfigEp(EPB, INT_IN2_EP_NUM, USB_EP_CFG_TYPE_INT, USB_EP_CFG_DIR_IN);
//USBD_ENABLE_EP_INT(EPA, USBD_EPINTEN_TXPKIEN_Msk);
                //USBD_ENABLE_EP_INT(EPB, USBD_EPINTEN_RXPKIEN_Msk);
void HID_InitForFullSpeed(void)
    USBD_SET_MAX_PAYLOAD(EPA, EPA_OTHER_MAX_PKT_SIZE);
void HID_Init(void)
    /* Configure USB controller */
    /* Enable USB BUS, CEP and EPA global interrupt */
    USBD_ENABLE_USB_INT(USBD_GINTEN_USBIEN_Msk|USBD_GINTEN_CEPIEN_Msk|USBD_GINTEN_EPAIEN_Msk|USBD_GINTEN_EPBIEN_Msk);
    /* Enable BUS interrupt */
    USBD_ENABLE_BUS_INT(USBD_BUSINTEN_DMADONEIEN_Msk|USBD_BUSINTEN_RESUMEIEN_Msk|USBD_BUSINTEN_RSTIEN_Msk|USBD_BUSINTEN_VBUSDETIEN_Msk);
    /* Reset Address to 0 */
    USBD_SET_ADDR(0);
    /* Control endpoint */
    USBD_SetEpBufAddr(CEP, CEP_BUF_BASE, CEP_BUF_LEN);
    /* start to IN data */
    g_u8EPAReady = 1;
          g_u8EPBReady = 1;
void HID_ClassRequest(void)
    if (gUsbCmd.bmRequestType & 0x80) { /* request data transfer direction */
        // Device to host
        switch (gUsbCmd.bRequest) {
        case GET_REPORT:
//                 break;
        case GET_IDLE:
//                 break;
        case GET_PROTOCOL:
//                break;
        default: {
            /* Setup error, stall the device */
            USBD_SET_CEP_STATE(USBD_CEPCTL_STALLEN_Msk);
            break;
    } else {
        // Host to device
        case SET_REPORT: {
            if (((gUsbCmd.wValue >> 8) & 0xff) == 3) {
                /* Request Type = Feature */
            break;
        case SET_IDLE: {
            /* Status stage */
            break;
        case SET_PROTOCOL:
//                 break;
        default: {
            // Stall
            break;
void HID_VendorRequest(void)
        // Device to host
        default: {
            break;
    } else {
        // Host to device
        default: {
            // Stall
            break;
void HID_UpdateKeyboardData(void)
    uint8_t  buf[8];
    int  i;
    if (g_u8EPBReady) {
                          for(i = 0; i < 8; i++)
          buf = 0;
                                if(PB11_PIN!=1)
                                 buf[2] = 0x04;
        g_u8EPBReady = 0;
        /* Set transfer length and trigger IN transfer */
        for (i=0; i<8; i++)
            USBD->EP[EPB].EPDAT_BYTE = buf;
        USBD->EP[EPB].EPRSPCTL = USB_EP_RSPCTL_SHORTTXEN;
        USBD_ENABLE_EP_INT(EPB, USBD_EPINTEN_INTKIEN_Msk);
void HID_UpdateMouseData(void)
    uint8_t  buf[4];
    int  i;
    if (g_u8EPAReady) {
        mouse_mode ^= 1;
        if (mouse_mode) {
            if (move_len > 14) {
                /* Update new report data */
                buf[0] = 0x00;
                buf[1] = mouse_table[mouse_idx & 0x07];
                buf[2] = mouse_table[(mouse_idx + 2) & 0x07];
                buf[3] = 0x00;
                mouse_idx++;
                move_len = 0;
        } else {
            buf[0] = buf[1] = buf[2] = buf[3] = 0;
        move_len++;
        g_u8EPAReady = 0;
        for (i=0; i<4; i++)
            USBD->EP[EPA].EPDAT_BYTE = buf;
        USBD->EP[EPA].EPRSPCTL = USB_EP_RSPCTL_SHORTTXEN;
        USBD_ENABLE_EP_INT(EPA, USBD_EPINTEN_INTKIEN_Msk);
huangcunxiake 发表于 2015-9-9 20:40 | 显示全部楼层
不知道如何驱动电脑键盘。
hebeisongshuang 发表于 2015-9-22 11:17 | 显示全部楼层
下来学习学习
gejigeji521 发表于 2015-9-23 19:08 | 显示全部楼层
   USBD_Open(&gsInfo, HID_ClassRequest, NULL);   最后一个空是什么,第一个参数懂,就是通过指针传递一个结构体进去。
xinba0625 发表于 2015-10-29 14:46 | 显示全部楼层
点击链接加入群【Nuvoton NUC505】:http://jq.qq.com/?_wv=1027&k=fHUZLL
