[开发工具] IAR520+J-LINK6调试STM32F103C8T6遇到问题
4760|3
 楼主| athlon64fx 发表于 2008-10-7 14:27 | 显示全部楼层 |阅读模式
请看下图.有没有办法解决?难道调试这个型号的mcu只能用4.22了吗?4.22是可以的.
kgp0213 发表于 2008-10-7 14:41 | 显示全部楼层
这个提示告诉你,你用的stm32芯片有可能是工程版的
仿真可能会有问题,在4.42下没有问题是因为iar4.42没有检测你的arm芯片。换块103c8t6吧
 楼主| athlon64fx 发表于 2008-10-7 14:50 | 显示全部楼层
多谢回复
看了一下tn0067: http://www.st.com/stonline/products/literature/tn/14898.pdf,很明显我买到的芯片是B或Z版本而不是最新的Y
Appendix A  Questions and answers: IAR EWARM V5.20 and STM32F101xx/STM32F103xx
medium-density devices
Q1: How many revisions of the medium-density devices are there?
A1: Three revisions have been delivered to customers: Rev. B, Rev. Z and Rev. Y
in chronological order (Rev B -> Rev Z -> Rev Y).
Q2: Which revisions have compatibility issues with IAR EWARM V5.20?
A2: The compatibility issue is with Rev. B and Rev. Z of medium-density devices.
Q3: How can I tell which revision I am using?
A3: The revision letter is on the package. Its location is explained in the product errata sheet.
Q4: Is there any problem with my application developed with the previous
version of IAR and previous versions of STM32F101xx/STM32F103xx
medium-density devices?
A4: No, systems already developed, validated and delivered to the field with previous silicon
revisions are not affected.
Q5: Can I still use IAR EWARM V5.20 with Rev. Z or Rev. B of an
STM32F101xx/STM32F103xx medium-density device if everything works fine?
A5: No, we advise to use only Rev Y with IAR EWARM V5.20.
Q6: What are the STM32F101xx/STM32F103xx medium-density parts currently available?
A6: Today, ST produces only Rev. Y devices, which correspond to the latest silicon revision.
Some distributors may still have stocks of previous revisions, but they are smoothly being
replaced by Rev. Y devices.
Q7: How am I sure to get only Rev. Y?
A7: The e-sampling process is explained at the beginning of the present document
(TN0067).
香水城 发表于 2008-10-7 15:14 | 显示全部楼层
版本B、Z和Y都是量产芯片,不是样片
不同之处在于逐步更正了一些芯片的局限性,正因为如此在新的版本(Y)出来后旧的版本(B和Z)就停产了。关于版本B、Z和Y的具体不同之处,请参考STM32芯片局限性的相关文档。
