关于ram在线调试的问题
1214|0
 楼主| Hoganliao 发表于 2015-9-11 16:44 | 显示全部楼层 |阅读模式
ram在线调试的时候,运行过程中,仿真器经常自动断开连接,并显示如下信息,有哪位大神知道可能是什么原因吗?
C28xx: Error: (Error -1041 @ 0xFFFFFF8E) The emulator reported an error. Confirm emulator configuration and connections, reset the emulator, and retry the operation. (Emulation package 5.1.232.0)
C28xx: Unable to determine target status after 20 attempts
C28xx: Failed to remove the debug state from the target before disconnecting.  There may still be breakpoint op-codes embedded in program memory.  It is recommended that you reset the emulator before you connect and reload your program before you continue debugging
