TIM2定时器的时钟到底是多少?
3646|3
 楼主| 三井寿 发表于 2008-10-26 10:24 | 显示全部楼层 |阅读模式
这是官方网站上下载的TIMER例程片段:
void RCC_Configuration(void)
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if (HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/4 */
    RCC_PCLK1Config(RCC_HCLK_Div4);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while (RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while (RCC_GetSYSCLKSource() != 0x08)
  /* TIM2 clock enable */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_TIM2, ENABLE);
  /* GPIOC clock enable */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC, ENABLE);
可以看出现在的主频是
PCLK2 = HCLK = 8*9 = 72MHz
PCLK1 = HCLK/4 = 72/4 = 18MHz
TIM2使用PCLK1也就是18MHz,可是在定时器数据计算的时候,例程却是这样的
    TIM2 Configuration: Output Compare Timing Mode:
    TIM2CLK = 36 MHz, Prescaler = 4, TIM2 counter clock = 7.2 MHz
    CC1 update rate = TIM2 counter clock / CCR1_Val = 146.48 Hz
    CC2 update rate = TIM2 counter clock / CCR2_Val = 219.7 Hz
    CC3 update rate = TIM2 counter clock / CCR3_Val = 439.4 Hz
    CC4 update rate = TIM2 counter clock / CCR4_Val =  878.9 Hz
  /* Time base configuration */
  TIM_TimeBaseStructure.TIM_Period = 65535;
  TIM_TimeBaseStructure.TIM_Prescaler = 0;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM2, &TIM_TimeBaseStructure);
  /* Prescaler configuration */
  TIM_PrescalerConfig(TIM2, 4, TIM_PSCReloadMode_Immediate);
  /* Output Compare Timing Mode configuration: Channel1 */
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = CCR1_Val;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
  TIM_OC1Init(TIM2, &TIM_OCInitStructure);
  TIM_OC1PreloadConfig(TIM2, TIM_OCPreload_Disable);
  /* Output Compare Timing Mode configuration: Channel2 */
  TIM_OCInitStructure.TIM_Pulse = CCR2_Val;
  TIM_OC2Init(TIM2, &TIM_OCInitStructure);
  TIM_OC2PreloadConfig(TIM2, TIM_OCPreload_Disable);
  /* Output Compare Timing Mode configuration: Channel3 */
  TIM_OCInitStructure.TIM_Pulse = CCR3_Val;
  TIM_OC3Init(TIM2, &TIM_OCInitStructure);
  TIM_OC3PreloadConfig(TIM2, TIM_OCPreload_Disable);
  /* Output Compare Timing Mode configuration: Channel4 */
  TIM_OCInitStructure.TIM_Pulse = CCR4_Val;
  TIM_OC4Init(TIM2, &TIM_OCInitStructure);
  TIM_OC4PreloadConfig(TIM2, TIM_OCPreload_Disable);
  /* TIM IT enable */
  TIM_ITConfig(TIM2, TIM_IT_CC1 | TIM_IT_CC2 | TIM_IT_CC3 | TIM_IT_CC4, ENABLE);
  /* TIM2 enable counter */
  TIM_Cmd(TIM2, ENABLE);
我实在搞不懂这里的36MHz是怎么样的来的,麻烦高人指点指点
zyok 发表于 2008-10-26 10:36 | 显示全部楼层
re:TIM2定时器的时钟到底是多少?
1. if the APB prescaler is 1, the timer clock frequencies are set to the same frequency as that of the APB domain to which the timers are connected.
2. otherwise, they are set to twice (x2) the frequency of the APB domain to which the timers are connected.
PCLK1是4分频后得到18MHz,所以timer clock=18x2
 楼主| 三井寿 发表于 2008-10-26 12:37 | 显示全部楼层
非常感谢zyok
是我自己没有仔细的阅读手册上RCC的图,谢谢!
hjiongh 发表于 2008-11-24 11:06 | 显示全部楼层
我也在玩这个例程
那因为psc的复位值是0,所以如果不设置下面的代码,应该TIM2_CLK默认是36MHz, 如果设置Prescaler=1,那TIM2_CLK就是18MHz?
  TIM_TimeBaseStructure.TIM_Prescaler = 1;
