到数据
2692|6
missyou198|  楼主 | 2008-11-12 11:18 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
会就是会不会就是不会,如果你会那你就把问题解决,别整天什么贴膏药,什么程序有问题净装B
missyou198|  楼主 | 2008-11-12 11:31 | 只看该作者
贴药膏什么意思
正常来说如果
USART_SendData(USART1, TxBuffer[TxCounter++]);
那么在stm32芯片的pin_9脚上应该有电压输出是吗?
missyou198|  楼主 | 2008-11-13 13:59 | 只看该作者
论坛里没人会
晕呀
香水城| | 2008-11-13 14:06 | 只看该作者
你要做什么都不说清楚,谁能够会?
missyou198|  楼主 | 2008-11-13 14:54 | 只看该作者
请香主帮忙
问题已解决
香水城| | 2008-11-13 15:07 | 只看该作者
请参考STM32固件库中提供的例程
那里有很多关于USART的例程
  DMA_Interrupt: Provide a basic communication between USART1 and USART2 using DMA capability, flags and interrupts.
  DMA_Polling: Provide a basic communication between USART1 and USART2 using DMA capability.
  HalfDuplex: Provide a basic communication between USART1 and USART2 in Half-Duplex mode using flags.
  HyperTerminal_HwFlowControl:  Use the USART with hardware flow control and communicate with the Hyperterminal.
  HyperTerminal_Interrupt: Use the USART1 interrupts to communicate with the hyperterminal.
  Interrupt: Provide a basic communication between USART1 and USART2 using interrupts.
  IrDA: Use IrDA mode. Two projects are provided: one for IrDA transmitter and the second for IrDA receiver
  MultiProcessor: Use the USART in multi-processor mode.
  Polling: Provide a basic communication between USART1 and USART2 using flags.
  Printf: Retarget the C library printf function to the USART.
  Smartcard: Use the USART in Smart Card mode.
  Synchronous: Provide a basic communication between USART1 (Synchronous mode) and SPI1 using flags.
对不起,我没有那么多时间帮你看程序,你自己对照例子研究一下吧。
missyou198|  楼主 | 2008-11-13 16:51 | 只看该作者
我只是想知道这种现象的原因
