STM32的看门狗
3440|2
 楼主| cyxcpz 发表于 2008-9-2 16:08 | 显示全部楼层 |阅读模式
闲来无事,拿起STM32 的板子,实验一下看门狗程序,
结果发现 IWDG 和 WWDG  似乎均不起作用:
把程序贴上:
IWDG:
/* Private functions ---------------------------------------------------------*/
* Function Name  : main
* Description    : Main program.
* Input          : None
* Output         : None
* Return         : None
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* System Clocks Configuration ---------------------------------------------*/
  RCC_Configuration();
  /* GPIO configuration ------------------------------------------------------*/
  GPIO_Configuration();
  /* Check if the system has resumed from IWDG reset -------------------------*/
  if(RCC_GetFlagStatus(RCC_FLAG_IWDGRST) != RESET)
  {    /* IWDGRST flag set */
    /* Turn on led connected to PC.06 */
    GPIO_WriteBit(GPIOB, GPIO_Pin_6, Bit_SET);
    /* Clear reset flags */
    RCC_ClearFlag();
  else
  {    /* IWDGRST flag is not set */
    /* Turn off led connected to PC.06 */
    GPIO_WriteBit(GPIOB, GPIO_Pin_6, Bit_RESET);
  /* Configure EXTI Line9 to generate an interrupt on falling edge -----------*/
  EXTI_Configuration();
  /* NVIC configuration ------------------------------------------------------*/
  NVIC_Configuration();
  /* Configure SysTick to generate an interrupt each 250ms -------------------*/
  SysTick_Configuration();
  /* IWDG timeout equal to 350ms (the timeout may varies due to LSI frequency
     dispersion) -------------------------------------------------------------*/
  /* Enable write access to IWDG_PR and IWDG_RLR registers */
  IWDG_WriteAccessCmd(IWDG_WriteAccess_Enable);
  /* IWDG counter clock: 32KHz(LSI) / 32 = 1KHz */
  IWDG_SetPrescaler(IWDG_Prescaler_32);
  /* Set counter reload value to 349 */
  IWDG_SetReload(349);
  /* Reload IWDG counter */
  IWDG_ReloadCounter();
  /* Enable IWDG (the LSI oscillator will be enabled by hardware) */
  IWDG_Enable();
  while(1)
* Function Name  : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
void RCC_Configuration(void)
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK */
    RCC_PCLK1Config(RCC_HCLK_Div1);
    /* Flash 0 wait state */
    FLASH_SetLatency(FLASH_Latency_0);
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Select HSE as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_HSE);
    /* Wait till HSE is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x04)
  /* Enable GPIOC, GPIOB and AFIO clock */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB |
                         RCC_APB2Periph_AFIO, ENABLE);
* Function Name  : GPIO_Configuration
* Description    : Configures the different GPIO ports.
* Input          : None
* Output         : None
* Return         : None
void GPIO_Configuration(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  /* Configure PC.06 and PC.07 as Output push-pull */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6 | GPIO_Pin_7;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
  /* Configure PB9 as input floating (EXTI Line9) */
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
WWDG:
* Input          : None
* Output         : None
* Return         : None
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* Check if the system has resumed from WWDG reset -------------------------*/
  if(RCC_GetFlagStatus(RCC_FLAG_WWDGRST) != RESET)
  {    /* WWDGRST flag set */
    RCC_ClearFlag();
  else
  {    /* WWDGRST flag is not set */
/* WWDG configuration --------------------------------------------------------*/
  /* Enable WWDG clock */
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_WWDG, ENABLE);
  /* WWDG clock counter = (PCLK1/4096)/8 = 244 Hz (~4 ms)  */
  WWDG_SetPrescaler(WWDG_Prescaler_8);
  /* Set Window value to 0x41 */
  WWDG_SetWindowValue(0x41);
  /* Enable WWDG and set counter value to 0x7F, WWDG timeout = ~4 ms * 64 = 262 ms */
  WWDG_Enable(0x7F);
  /* Clear EWI flag */
  WWDG_ClearFlag();
  /* Enable EW interrupt */
  WWDG_EnableIT();
  while (1)
* Input          : None
* Output         : None
* Return         : None
  RCC_DeInit();
  /* Enable HSE */
    /* HCLK = SYSCLK */
    /* PCLK2 = HCLK */
    /* PCLK1 = HCLK */
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOB |
请大家看看。
winloop 发表于 2008-9-2 18:41 | 显示全部楼层
我在用IDWG,很好用
香水城 发表于 2008-9-2 20:43 | 显示全部楼层
看过STM32固件库中的例子吗?
