用定时器1的时基模式触发AD,为什么不行啊?
2989|2
 楼主| jinjing999 发表于 2009-4-20 17:37 | 显示全部楼层 |阅读模式
 /* TIM1 configuration ------------------------------------------------------*/
  // Time Base configuration
   TIM_TimeBaseStructInit(&TIM_TimeBaseStructure);
  TIM_TimeBaseStructure.TIM_Period = 0xFFFF;
  TIM_TimeBaseStructure.TIM_Prescaler = 0x0;
  TIM_TimeBaseStructure.TIM_ClockDivision = 0x0;
  TIM_TimeBaseStructure.TIM_CounterMode = TIM_CounterMode_Up;
  TIM_TimeBaseInit(TIM1, &TIM_TimeBaseStructure);
  //TIM1 channel1 configuration in PWM mode
  TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_Timing;
  TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
  TIM_OCInitStructure.TIM_Pulse = 7500;
  TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_Low;
  TIM_OC1Init(TIM1, &TIM_OCInitStructure);
  TIM_OC1PreloadConfig(TIM1, TIM_OCPreload_Disable);
  /* DMA1 Channel1 Configuration ----------------------------------------------*/
  DMA_DeInit(DMA1_Channel1);
  DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
  DMA_InitStructure.DMA_MemoryBaseAddr = (u32)ADC_RegularConvertedValueTab;
  DMA_InitStructure.DMA_DIR = DMA_DIR_PeripheralSRC;
  DMA_InitStructure.DMA_BufferSize = 32;
  DMA_InitStructure.DMA_PeripheralInc = DMA_PeripheralInc_Disable;
  DMA_InitStructure.DMA_MemoryInc = DMA_MemoryInc_Enable;
  DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
  DMA_InitStructure.DMA_MemoryDataSize = DMA_MemoryDataSize_HalfWord;
  DMA_InitStructure.DMA_Mode = DMA_Mode_Circular;
  DMA_InitStructure.DMA_Priority = DMA_Priority_High;
  DMA_InitStructure.DMA_M2M = DMA_M2M_Disable;
  DMA_Init(DMA1_Channel1, &DMA_InitStructure);
  /* Enable DMA1 channel1 */
  DMA_Cmd(DMA1_Channel1, ENABLE);
  /* ADC1 configuration ------------------------------------------------------*/
  ADC_InitStructure.ADC_Mode = ADC_Mode_Independent;
  ADC_InitStructure.ADC_ScanConvMode = ENABLE;//DISABLE;
  ADC_InitStructure.ADC_ContinuousConvMode =ENABLE; //DISABLE;
  ADC_InitStructure.ADC_ExternalTrigConv = ADC_ExternalTrigConv_T1_CC1;
  ADC_InitStructure.ADC_DataAlign = ADC_DataAlign_Right;
  ADC_InitStructure.ADC_NbrOfChannel = 1;
  ADC_Init(ADC1, &ADC_InitStructure);
  /* ADC1 regular channel14 configuration */
  ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_1Cycles5);
  /* Set injected sequencer length */
  ADC_InjectedSequencerLengthConfig(ADC1, 1);
  /* ADC1 injected channel Configuration */
  ADC_InjectedChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_1Cycles5);
  /* ADC1 injected external trigger configuration */
  ADC_ExternalTrigInjectedConvConfig(ADC1, ADC_ExternalTrigInjecConv_None);
  /* Enable automatic injected conversion start after regular one */
  ADC_AutoInjectedConvCmd(ADC1, ENABLE);
  /* Enable ADC1 DMA */
  ADC_DMACmd(ADC1, ENABLE);
  /* Enable ADC1 external trigger */
  ADC_ExternalTrigConvCmd(ADC1, ENABLE);
  /* Enable JEOC interupt */
  ADC_ITConfig(ADC1, ADC_IT_JEOC, ENABLE);
  /* Enable ADC1 */
  ADC_Cmd(ADC1, ENABLE);
  /* Enable ADC1 reset calibaration register */
  ADC_ResetCalibration(ADC1);
  /* Check the end of ADC1 reset calibration register */
  while(ADC_GetResetCalibrationStatus(ADC1));
  /* Start ADC1 calibaration */
  ADC_StartCalibration(ADC1);
  /* Check the end of ADC1 calibration */
  while(ADC_GetCalibrationStatus(ADC1));
  /* TIM1 counter enable */
  TIM_Cmd(TIM1, ENABLE);
  /* TIM1 main Output Enable */
  //TIM_CtrlPWMOutputs(TIM1, ENABLE);
  /* Test on channel1 transfer complete flag */
  while(!DMA_GetFlagStatus(DMA1_FLAG_TC1));//程序死在这
  /* Clear channel1 transfer complete flag */
  DMA_ClearFlag(DMA1_FLAG_TC1);
上边DMA应该没有问题,问题是在定时器用。
结果死在:
colaring 发表于 2009-4-21 15:40 | 显示全部楼层
错了吧
我隐约记得只有TIM3才能触发AD1采样吧!!
但是是好久以前了,LZ好好看看user manual
 楼主| jinjing999 发表于 2009-4-22 15:55 | 显示全部楼层
定时器1有3个CCR可以触发
还有定时器2也能触发
现在用给的例子,PWM触发数据,现在不知道触发频率怎么算
