ITStatus USART_GetITStatus(USART_TypeDef* USARTx, uint16_t USART_IT) { uint32_t bitpos = 0x00, itmask = 0x00, usartreg = 0x00; ITStatus bitstatus = RESET; /* Check the parameters */ assert_param(IS_USART_ALL_PERIPH(USARTx)); assert_param(IS_USART_GET_IT(USART_IT)); assert_param(IS_USART_PERIPH_IT(USARTx, USART_IT)); /* The CTS interrupt is not available for UART4 and UART5 */ /* Get the USART register index */ usartreg = (((uint8_t)USART_IT) >> 0x05); /* Get the interrupt position */ itmask = USART_IT & IT_Mask; itmask = (uint32_t)0x01 << itmask; if (usartreg == 0x01) /* The IT is in CR1 register */ { itmask &= USARTx->CR1; } else if (usartreg == 0x02) /* The IT is in CR2 register */ { itmask &= USARTx->CR2; } else /* The IT is in CR3 register */ { itmask &= USARTx->CR3; } bitpos = USART_IT >> 0x08; bitpos = (uint32_t)0x01 << bitpos; bitpos &= USARTx->SR; <<< if ((itmask != (uint16_t)RESET)&&(bitpos != (uint16_t)RESET)) { bitstatus = SET; } else { bitstatus = RESET; } return bitstatus; }
