STM32很奇怪啊(adc i2c问题)
6813|10
 楼主| brotherwen 发表于 2009-6-3 16:47 | 显示全部楼层 |阅读模式
void SetADC(void)
    GPIO_InitTypeDef GPIO_InitStructure;
    DMA_InitTypeDef DMA_InitStructure;
    ADC_InitTypeDef ADC_InitStructure;
    /* Enable GPIOC  ADC1 clock */
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC|RCC_APB2Periph_ADC1, ENABLE);
    /* Enable DMA clock*/
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_DMA1, ENABLE);
    /* Configure PC 0,1,2 (ADC Channel1) as analog input */
    GPIO_InitStructure.GPIO_Pin  = GPIO_Pin_0|GPIO_Pin_1|GPIO_Pin_2;
    GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AIN;
    GPIO_Init(GPIOC, &GPIO_InitStructure);
    /* DMA Channel1 Configuration ----------------------------------------------*/
    DMA_DeInit(DMA1_Channel1);
    DMA_InitStructure.DMA_PeripheralBaseAddr = ADC1_DR_Address;
    DMA_InitStructure.DMA_MemoryBaseAddr     = (u32)&ADC_ConvertedValue;
    DMA_InitStructure.DMA_DIR                = DMA_DIR_PeripheralSRC;
    DMA_InitStructure.DMA_BufferSize         = 3;
    DMA_InitStructure.DMA_PeripheralInc      = DMA_PeripheralInc_Disable;
    DMA_InitStructure.DMA_MemoryInc          = DMA_MemoryInc_Enable;
    DMA_InitStructure.DMA_PeripheralDataSize = DMA_PeripheralDataSize_HalfWord;
    DMA_InitStructure.DMA_MemoryDataSize     = DMA_MemoryDataSize_HalfWord;
    DMA_InitStructure.DMA_Mode               = DMA_Mode_Circular;
    DMA_InitStructure.DMA_Priority           = DMA_Priority_Low;
    DMA_InitStructure.DMA_M2M                = DMA_M2M_Disable;
    DMA_Init(DMA1_Channel1, &DMA_InitStructure);
    //DMA_ITConfig(DMA1_Channel1,DMA_IT_TC,ENABLE);
    //NVIC->ISER[0]|=1<<11;  //enable DMA1_channel1 interrupt
     /* Enable DMA Channel1  */
    DMA_Cmd(DMA1_Channel1, ENABLE);
    // ADC1 Configuration (ADC1CLK = 18 MHz) -----------------------------------
    ADC_InitStructure.ADC_Mode               = ADC_Mode_Independent;
    ADC_InitStructure.ADC_ScanConvMode       = ENABLE;
    ADC_InitStructure.ADC_ContinuousConvMode = DISABLE;
    ADC_InitStructure.ADC_ExternalTrigConv   = ADC_ExternalTrigConv_None;
    ADC_InitStructure.ADC_DataAlign          = ADC_DataAlign_Right;
    ADC_InitStructure.ADC_NbrOfChannel       = 3;
    ADC_Init(ADC1, &ADC_InitStructure);
    // ADC1 Regular Channel1 Configuration
    ADC_RegularChannelConfig(ADC1, ADC_Channel_10, 1, ADC_SampleTime_55Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_11, 2, ADC_SampleTime_55Cycles5);
    ADC_RegularChannelConfig(ADC1, ADC_Channel_12, 3, ADC_SampleTime_55Cycles5);
    ADC_StartCalibration(ADC1);
    ADC_DMACmd(ADC1, ENABLE);
    ADC_Cmd(ADC1, ENABLE);
    //ADC_SoftwareStartConvCmd(ADC1,ENABLE);
之后读写i2c 总线时就死掉了
香水城 发表于 2009-6-3 18:17 | 显示全部楼层
如何操作I2C总线的?哪个I2C端口?
 楼主| brotherwen 发表于 2009-6-3 21:22 | 显示全部楼层
初始化部分
#define I2C_REMMAP
/*------------------- I 2 C   I N I T --------------------
【功能】:i2c接口初始化
【参数】:****
【返回】:****
【说明】:****
--------------作者:88888   2009年5月25日14:33:44-------------------------*/
void I2cInit(void)
    I2C_InitTypeDef  I2C_InitStructure;
    /* Enable I2C1 and GPIOB clocks */
#ifndef  I2C_REMMAP
    RCC_AHBPeriphClockCmd(RCC_AHBPeriph_FSMC, DISABLE);
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB, ENABLE);
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1, ENABLE);
    /* Configure I2C1 pins: SCL and SDA */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_6|GPIO_Pin_7;
    GPIO_InitStructure.GPIO_Speed=GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode=GPIO_Mode_AF_OD;
    GPIO_Init(GPIOB, &GPIO_InitStructure);
#else
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOB|RCC_APB2Periph_AFIO, ENABLE);
    GPIO_PinRemapConfig(GPIO_Remap_I2C1, ENABLE);
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_8|GPIO_Pin_9;
#endif
    I2C_DeInit(I2C1);
     /* I2C configuration */
    I2C_InitStructure.I2C_Mode = I2C_Mode_I2C;
    I2C_InitStructure.I2C_DutyCycle = I2C_DutyCycle_2;
    I2C_InitStructure.I2C_OwnAddress1 = I2C1_SLAVE_ADDRESS7;
    I2C_InitStructure.I2C_Ack = I2C_Ack_Disable;
    I2C_InitStructure.I2C_AcknowledgedAddress = I2C_AcknowledgedAddress_7bit;
    I2C_InitStructure.I2C_ClockSpeed = I2C_Speed;
    /* Apply I2C configuration after enabling it */
    I2C_Init(I2C1,&I2C_InitStructure);
    I2C_Cmd(I2C1,ENABLE);
 楼主| brotherwen 发表于 2009-6-3 21:26 | 显示全部楼层
写部分,
/*------------------- R E A D   A   T 2 4   C 2 5 6 --------------------
【功能】:****
【参数】:****
【返回】:****
【说明】:****
--------------作者:****   2009年5月15日12:51:22-------------------------*/
void ReadAT24C256(u32 addr, u8 *ptr, u32 len)
//    int i;
#ifndef  I2C_REMMAP
    I2cInit();
#endif
    I2C_AcknowledgePolling();
    I2C_GenerateSTART(I2C1,ENABLE);
    while(I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_MODE_SELECT)!=SUCCESS);
    I2C_Send7bitAddress(I2C1,AT24_DEVICE_ADDR,I2C_Direction_Transmitter);
    while(I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_TRANSMITTER_MODE_SELECTED)!=SUCCESS);
    I2C_SendData(I2C1,(addr>>8));
    while(I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_TRANSMITTED)!=SUCCESS);
    I2C_SendData(I2C1,(addr&0xff));
    I2C_Send7bitAddress(I2C1,AT24_DEVICE_ADDR,I2C_Direction_Receiver);
    while(I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_RECEIVER_MODE_SELECTED)!=SUCCESS);
    for ( ; len!=1; len--)
        I2C_AcknowledgeConfig(I2C1,ENABLE);
        while(I2C_CheckEvent(I2C1,I2C_EVENT_MASTER_BYTE_RECEIVED)!=SUCCESS);
        *(ptr++) = I2C_ReceiveData(I2C1);
    I2C_AcknowledgeConfig(I2C1,DISABLE);
    *(ptr++)=I2C_ReceiveData(I2C1);
    I2C_GenerateSTOP(I2C1,ENABLE);
#if 0
    if(len>=1){
        for(i=0;i<len-1;i++){
            *ptr=I2C_ReceiveData(I2C1);
            ptr++;
#endif
#ifndef  I2C_REMMAP
    I2C_Cmd(I2C1,DISABLE);
    RCC_APB1PeriphClockCmd(RCC_APB1Periph_I2C1,DISABLE);
    FSMC_SRAM_Init();
#endif
望香主能明示
香水城 发表于 2009-6-3 22:36 | 显示全部楼层
STM32 I2C 封装库
STM32的I2C模块,如果自己写驱动经常会有问题,而且STM32固件库中的I2C例子也不是很好,所以我们自己写了一个高层次的封装库(见下面的帖子链接),目前用起来效果不错,你可以试试。
关于你写的程序,不经实际调试很难静态地看出毛病,实际调试我也没有这个时间,恕不能帮忙,见谅。
相关链接:https://bbs.21ic.com/club/bbs/list.asp?boardid=49&page=1&t=3194196&tp=STM32%20I2C%20%u5C01%u88C5%u5E93%uFF08%u67E5%u8BE2%u65B9%u5F0F+29%u697C%u4E2D%u65AD%u65B9%u5F0F+32%u697CDMA%u65B9%u5F0F%uFF09
 楼主| brotherwen 发表于 2009-6-4 09:30 | 显示全部楼层
有点汗啊
我觉得首先的问题是我的程序是否有所纰漏。
其实我的操作步骤是否得当。
因为许多片子也是这样玩的啊,也没有问题啊
难道用stm32的i2c一定得官方最好的封装库???
香水城 发表于 2009-6-4 10:24 | 显示全部楼层
发布封装好的库,就是为了方便大家的使用
因为我们的人力有限,肯定没有精力帮助所有用户检查程序的纰漏;否则我们也没有必要发布封装好的库了,敬请谅解。
 楼主| brotherwen 发表于 2009-6-4 16:19 | 显示全部楼层
结贴,自己搞定
本质问题是st公司和其它所有公司i2c设计思路有出入。
stm32的i2c总线接受异常情况相当脆弱
香水城 发表于 2009-6-4 17:04 | 显示全部楼层
同意10楼这样的评价
ST的I2C设计思路与其它公司有出入——每个设计师都可以有自己的思路。
10楼的第2个评价是:STM32的I2C模块接受异常情况相当脆弱。我有条件地同意这个评价,条件是如果通过软件可以处理,就属正常。
关于这个问题,我的理解是:为了减小功耗、减小硬件设计的复杂度、降低硬件的成本,应该设计一个功能简单的硬件,在通过与软件的配合完成需要的功能前提下,只要软件能够实现的功能,就不用通过硬件实现。CPU设计上RISC概念的出现,正是体现了这个精神。
我们知道复杂的系统调试和Debug是一件困难的事情,比较在时间和金钱上的花费,调试和Debug硬件要比调试和Debug软件需要几十至上百倍的时间和成本,所以我们必须降低硬件的复杂度。
另一方面讲,硬件的复杂度增加意味着硬件成本的增加,这个增加的成本是出现在每一个终端产品中,不会因为终端产品生产数量的增加而减少。而软件的开发成本却可以平摊到每一个终端产品中,每个产品中包含的软件成本会随着产品生产数量的增加而下降。因此把产品的成本从硬件转嫁软件对控制终端产品的成本是有效的。
正因为这样的设计,增加了软件的复杂度,所以更需要我们用封装库的形式帮助客户减轻负担。
