有人用安捷伦Agilent示波器DSOX2000、X3000系列示波器吗
3572|1
 楼主| forthlab 发表于 2015-9-18 12:42 | 显示全部楼层 |阅读模式
最近有开始关注示波器,原来想搞个泰克的低档的,就3000多,上论坛发现安捷伦Agilent示波器DSOX2000/x3000系列的可以**,**后功能强大,所以来这里问问有人用这个示波器么?有人**么?据说官方默认**的
  据说**后,有内置的函数发生器、电压表、逻辑分析仪和解码模块啥的,感觉很超值,想搞一个
关于**的步骤:
How to hack the firmware
1. Unpack the firmware *.cab by 7zip   <--- WinRAR 也可以
2. Unpack infiniiVisionSetup.cab ( e.g. with WinCE CAB Manager 3.0)   <--- 我试过别的 CAB 管理软件不行,最好用这个
    Find \Secure\infiniiVision\infiniiVisionCore.dll
3. Change at location 0x277e50 in infiniiVisionCore.dll
    byte sequence 04 00 a0 e1 to byte sequence 00 00 a0 e3
4. Enable startup Overide by creating USB flash with following structure in root of USB drive (copy structure from Secure folder from point 2)
    Edit in Startup folder file infiniivision.lnk to contains following sequence "62#\usb\infiniiVision\infiniivisionLauncher.exe -l All -l SCPIPS"
    Replace in infiniiVision folder  infiniiVisionCore.dll with patched infiniiVisionCore.dll file
5. Create infiniivisionStartupOverride.txt file in root of USB flash drive containing "True"
6. Plug the USB drive to scope and turn it ON
7. There will be red  message in letf top corner "Unfinalized Software"  and "System Concerns detected: OS version is not correct. Please reload system firmware"
 楼主| forthlab 发表于 2015-9-23 14:05 | 显示全部楼层
电工们没有用这个的么?
顶一下!
