STM32F101系列 串口发送中断进不来是为什么
3595|2
 楼主| jie841010 发表于 2008-12-18 22:43 | 显示全部楼层 |阅读模式
  在IAR环境下,基于STM32F101 Cotex-M3系列芯片开发时,遇到串口发送中断进不来,接收中断是正常的,但发送中断就是进不来,很奇怪,我都配好了,就是在发送一个字节时,进不了中断,不知道为什么,有没有哪个大哥遇到类似情况,给小弟解下困惑。
香水城 发表于 2008-12-19 09:43 | 显示全部楼层
你用的是什么中断?是否使能了相应的中断?
mwm8412 发表于 2008-12-19 16:53 | 显示全部楼层
void USART1_IRQHandler(void)//串口中断
  if(USART_GetITStatus(USART1, USART_IT_TXE) != RESET)
    /* Write one byte to the transmit data register */
    if(TxCounter1 < NbrOfDataToTransfer1)
    USART_SendData(USART1, TxBuffer1[TxCounter1++]);
    /* Clear the USART1 transmit interrupt */
    USART_ClearITPendingBit(USART1, USART_IT_TXE);
    if(TxCounter1 == NbrOfDataToTransfer1)
      /* Disable the USART1 Transmit interrupt */
      USART_ITConfig(USART1, USART_IT_TXE, DISABLE);
  else
    /* Read one byte from the receive data register */
    RxBuffer1[RxCounter1++] = USART_ReceiveData(USART1);
   /* Clear the USART1 Receive interrupt */
   USART_ClearITPendingBit(USART1, USART_IT_RXNE);
    if(RxCounter1 == NbrOfDataToRead1)
      /* Disable the USART1 Receive interrupt */
      USART_ITConfig(USART1, USART_IT_RXNE, DISABLE);
//**********串口基本配置***********************************/
  USART_InitStructure.USART_BaudRate = 9600;
  USART_InitStructure.USART_WordLength = USART_WordLength_8b;
  USART_InitStructure.USART_StopBits = USART_StopBits_1;
  USART_InitStructure.USART_Parity = USART_Parity_No;
  USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
  USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;
  USART_InitStructure.USART_Clock = USART_Clock_Disable;
  USART_InitStructure.USART_CPOL = USART_CPOL_Low;
  USART_InitStructure.USART_CPHA = USART_CPHA_2Edge;
  USART_InitStructure.USART_LastBit = USART_LastBit_Disable;
  /* Configure USART1 */
  USART_Init(USART1, &USART_InitStructure);
  /* Configure USART2 */
  USART_Init(USART2, &USART_InitStructure);
  /* Enable USART1 Receive and Transmit interrupt */
  USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
  USART_ITConfig(USART1, USART_IT_TXE, ENABLE);
  /* Enable USART2 Receive and Transmit interrupt */
  USART_ITConfig(USART2, USART_IT_RXNE, ENABLE);
  USART_ITConfig(USART2, USART_IT_TXE, ENABLE);
  /* Enable the USART1 */
  USART_Cmd(USART1, ENABLE);
  /* Enable the USART2 */
  USART_Cmd(USART2, ENABLE);
//**********中断配置***********************************/
  /* Enable the USART1 Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
  /* Enable the USART2 Interrupt */
  NVIC_InitStructure.NVIC_IRQChannel = USART2_IRQChannel;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 2;
