如何在中断中改变PWM的周期?或者占空比?
4895|8
 楼主| LPcfANS 发表于 2009-1-7 13:39 | 显示全部楼层 |阅读模式
 TIM_TimeBaseInitTypeDef TIM_BaseInitStructure;
    TIM_OCInitTypeDef  TIM_OCInitStructure;
    TIM_BaseInitStructure.TIM_Period = 65535;
    TIM_BaseInitStructure.TIM_Prescaler = 17;
    TIM_BaseInitStructure.TIM_ClockDivision = 0;
    TIM_BaseInitStructure.TIM_CounterMode = TIM_CounterMode_Up;
    TIM_BaseInitStructure.TIM_RepetitionCounter = 0;
    TIM_TimeBaseInit(TIM3, &TIM_BaseInitStructure);
    TIM_ARRPreloadConfig(TIM3,DISABLE);
    //TIM_ARRPreloadConfig(TIM3, ENABLE);
    TIM_UpdateRequestConfig(TIM3,TIM_UpdateSource_Regular);
    TIM_OCInitStructure.TIM_OCMode = TIM_OCMode_PWM1;
    TIM_OCInitStructure.TIM_OutputState = TIM_OutputState_Enable;
    TIM_OCInitStructure.TIM_OutputNState = TIM_OutputNState_Enable;
    TIM_OCInitStructure.TIM_OCPolarity = TIM_OCPolarity_High;
    TIM_OCInitStructure.TIM_OCNPolarity = TIM_OCNPolarity_High;
    TIM_OCInitStructure.TIM_Pulse = CCR1_Val;
    TIM_OC1Init(TIM3, &TIM_OCInitStructure);
    TIM_OC1PreloadConfig(TIM3, TIM_OCPreload_Enable);
    TIM_OCInitStructure.TIM_Pulse = CCR2_Val;
    TIM_OC2Init(TIM3, &TIM_OCInitStructure);
    TIM_OC2PreloadConfig(TIM3, TIM_OCPreload_Enable);
    TIM_OCInitStructure.TIM_Pulse = CCR3_Val;
    TIM_OC3Init(TIM3, &TIM_OCInitStructure);
    TIM_OC3PreloadConfig(TIM3, TIM_OCPreload_Enable);
    TIM_OCInitStructure.TIM_Pulse = CCR4_Val;
    TIM_OC4Init(TIM3, &TIM_OCInitStructure);
    TIM_OC4PreloadConfig(TIM3, TIM_OCPreload_Enable);
    TIM_ITConfig(TIM3,TIM_IT_CC1 | TIM_IT_Update,ENABLE);
    TIM_Cmd(TIM3, ENABLE);
    TIM_CtrlPWMOutputs(TIM3, ENABLE);
中断函数:
void TIM3_IRQHandler(void)
  if (TIM_GetITStatus(TIM3, TIM_IT_CC1) != RESET)
       TIM_ClearITPendingBit(TIM3, TIM_IT_CC1);
     savetime_2+=1;
     if(savetime_2>100)
       savetime_2=0;
       savetime_3+=1;
       if(savetime_3>100)
         savetime_3=0;
         CCR1_Val++;
        if(CCR1_Val>60000)
          CCR1_Val=511;
        GPIO_SetBits(GPIOF, GPIO_Pin_9); //关LED4
        GPIO_ResetBits(GPIOF, GPIO_Pin_8);  //关LED5
        GPIO_SetBits(GPIOF, GPIO_Pin_7); //关LED6
        GPIO_ResetBits(GPIOF, GPIO_Pin_6);  //关LED7
  else if (TIM_GetITStatus(TIM3, TIM_IT_Update) != RESET)
    TIM_ClearITPendingBit(TIM3, TIM_IT_Update);
    savetime_4+=1;
     if(savetime_4>100)
       savetime_4=0;
       savetime_1+=1;
       if(savetime_1>100)
         savetime_1=0;
         CCR2_Val++;
        if(CCR2_Val>32768)
          CCR2_Val=511;
        GPIO_ResetBits(GPIOF, GPIO_Pin_9); //关LED4
        GPIO_SetBits(GPIOF, GPIO_Pin_8);  //关LED5
        GPIO_ResetBits(GPIOF, GPIO_Pin_7); //关LED6
        GPIO_SetBits(GPIOF, GPIO_Pin_6);  //关LED7
 楼主| LPcfANS 发表于 2009-1-7 13:42 | 显示全部楼层
是不是还有那些地方没设置对?????
香水城 发表于 2009-1-7 14:20 | 显示全部楼层
请先解释一下这是什么程序?
哪些语句是做什么事情的?
 楼主| LPcfANS 发表于 2009-1-7 14:28 | 显示全部楼层
我想在TIM3中断改变他的占空比...
这个程序在TIM3输出PWM没问题,中断也可以进去.(我在中断中记数,在LCD显示,中断可以进去)
香水城 发表于 2009-1-7 15:28 | 显示全部楼层
请说清楚TIM3的几个通道是如何用的?
TIM3的中断是什么中断?
 楼主| LPcfANS 发表于 2009-1-7 17:23 | 显示全部楼层
都输出PWM...中断设置如下:谢谢...
 楼主| LPcfANS 发表于 2009-1-8 11:39 | 显示全部楼层
顶.....
期待斑竹给讲讲.谢谢..
需要设置的地方太多了...
 楼主| LPcfANS 发表于 2009-1-8 13:49 | 显示全部楼层
这样就可以了。谢谢斑竹,参考了一个网友的例子.
void SysTickHandler(void)
 static unsigned char j=0;
  savetime++;
  if (savetime >100)
     savetime = 0;
     savetime1++;
     if(savetime1>100)
       savetime1=0;
     //TIM3_Configuration();
      j++;
      TIM3->CCR1=sindata[j];
      TIM3->CCR2=sindata[j];
      TIM3->CCR3=sindata[j];
      TIM3->CCR4=sindata[j];
      if(j>7)j=0;
