[应用相关] USART1在stm32 103ze里调试通过,搬到101C8里死活不进中断,香主
3050|1
 楼主| zusen 发表于 2009-2-20 12:02 | 显示全部楼层 |阅读模式
直接搬到101C8,不知有什么要注意
void SetupUSART (void)  {
    USART_InitTypeDef USART_InitStructure;
    GPIO_InitTypeDef GPIO_InitStructure;
    USART_NVIC();
    RCC_APB2PeriphClockCmd (RCC_APB2Periph_USART1 | RCC_APB2Periph_GPIOA| RCC_APB2Periph_AFIO, ENABLE);
    /* Configure USART1 USART2 Rx (PA10) as input floating                             */
    GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_10;
    GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_IN_FLOATING;
    GPIO_Init(GPIOA, &GPIO_InitStructure);
    /* Configure USART1 USART2 Tx (PA9) as alternate function push-pull                */
    GPIO_InitStructure.GPIO_Pin   = GPIO_Pin_9;
    GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
    GPIO_InitStructure.GPIO_Mode  = GPIO_Mode_AF_PP;
    USART_InitStructure.USART_BaudRate            = 9600;
    USART_InitStructure.USART_WordLength          = USART_WordLength_8b;
    USART_InitStructure.USART_StopBits            = USART_StopBits_1;
    USART_InitStructure.USART_Parity              = USART_Parity_No ;//USART_Parity_Odd
    USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;
    USART_InitStructure.USART_Mode                = USART_Mode_Rx | USART_Mode_Tx;
    USART_Init(USART1, &USART_InitStructure);
    /* Enable the USART Receive interrupt: this interrupt is generated when the
       USART1 receive data register is not empty */
    USART_ITConfig(USART1, USART_IT_RXNE, ENABLE);
    /* Enable USART1 */
    USART_Cmd(USART1, ENABLE);
 * Function Name  : NVIC_Configuration
 * Description    : Configures the nested vectored interrupt controller.
 * Input          : None
 * Output         : None
 * Return         : None
void USART_NVIC(void)
    NVIC_InitTypeDef NVIC_InitStructure;
    /* Enable the USART1 Interrupt */
    NVIC_InitStructure.NVIC_IRQChannel = USART1_IRQChannel;
    NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelSubPriority = 0;
    NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
    NVIC_Init(&NVIC_InitStructure);
香水城 发表于 2009-2-20 12:22 | 显示全部楼层
检查一下硬件的管脚是否对应,供电是否合适
另外,使用普通I/O方式检查一下,对应的管脚是否能够正常输出0或1,排除硬件损坏的情况。
