大家帮忙看看,为什么can调试不通
2817|1
 楼主| licky 发表于 2009-2-24 16:42 | 显示全部楼层 |阅读模式
各位,小弟刚刚开始学习STM32,现在正在调试STM103VBT6上的CAN接口,我把ST的库中的CAN例子放在自己的板子上验证了一下,测试通过。我自己的板子上使用的CAN端口被映射到D0,D1上了,我把CAN通信模式从Loopback模式修改成normal,用示波器在CANRX(PD0,已经与CAN收发器断开了)和CANTX(PD1,已经与CAN收发器断开了)引脚上查看了,结果CANTX引脚电平为0,CANRX引脚为3.3V,CAN通信模式换成原来的Loopback模式,在CANTX引脚上仍然看不到任何东西,请大家帮忙分析一下我的问题出来哪里了。
下面时我的代码
int main(void)
#ifdef DEBUG
  debug();
#endif
  /* System Clocks Configuration */
  RCC_Configuration();
  /* NVIC Configuration */
  NVIC_Configuration();
  /* GPIO ports pins Configuration */
  GPIO_Configuration();
  while (1)
      /* CAN transmit at 100Kb/s and receive by polling in loopback mode */
    TestRx = CAN_Polling();
    if (TestRx == FAILED)
      /* Turn on led  */
      GPIO_SetBits(GPIOE, GPIO_Pin_2);
    else
      /* Turn on led */
      GPIO_SetBits(GPIOE, GPIO_Pin_3);
* Function Name  : RCC_Configuration
* Description    : Configures the different system clocks.
* Input          : None
* Output         : None
* Return         : None
void RCC_Configuration(void)
  /* RCC system reset(for debug purpose) */
  RCC_DeInit();
  /* Enable HSE */
  RCC_HSEConfig(RCC_HSE_ON);
  /* Wait till HSE is ready */
  HSEStartUpStatus = RCC_WaitForHSEStartUp();
  if(HSEStartUpStatus == SUCCESS)
    /* Enable Prefetch Buffer */
    FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
    /* Flash 2 wait state */
    FLASH_SetLatency(FLASH_Latency_2);
    /* HCLK = SYSCLK */
    RCC_HCLKConfig(RCC_SYSCLK_Div1);
    /* PCLK2 = HCLK */
    RCC_PCLK2Config(RCC_HCLK_Div1);
    /* PCLK1 = HCLK/2 */
    RCC_PCLK1Config(RCC_HCLK_Div2);
    /* PLLCLK = 8MHz * 9 = 72 MHz */
    RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
    /* Enable PLL */
    RCC_PLLCmd(ENABLE);
    /* Wait till PLL is ready */
    while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
    /* Select PLL as system clock source */
    RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
    /* Wait till PLL is used as system clock source */
    while(RCC_GetSYSCLKSource() != 0x08)
   /* CAN Periph clock enable */
  // Enable GPIOD clock
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOD, ENABLE);
  RCC_APB1PeriphClockCmd(RCC_APB1Periph_CAN, ENABLE);
  RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);      // 必要么
* Function Name  : GPIO_Configuration
* Description    : Configures the different GPIO ports.
* Input          : None
* Output         : None
* Return         : None
void GPIO_Configuration(void)
  GPIO_InitTypeDef GPIO_InitStructure;
  // Configure LED pin PE.02 -- PE.03 as Output push-pull
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2 | GPIO_Pin_3;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_Init(GPIOE, &GPIO_InitStructure);
  // Configure CAN pin: RX
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IPU;
  GPIO_Init(GPIOD, &GPIO_InitStructure);
  // Configure CAN pin: TX
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_1;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;
  // CAN pin remap to PD0/PD1
  GPIO_PinRemapConfig(GPIO_Remap2_CAN,ENABLE);
* Function Name  : CAN_Polling
* Description    : Configures the CAN, transmit and receive by polling
* Input          : None
* Output         : None
* Return         : PASSED if the reception is well done, FAILED in other case
TestStatus CAN_Polling(void)
  CAN_InitTypeDef        CAN_InitStructure;
  CAN_FilterInitTypeDef  CAN_FilterInitStructure;
  CanTxMsg TxMessage;
  CanRxMsg RxMessage;
  u32 i = 0;
  u8 TransmitMailbox = 0;
  /* CAN register init */
  CAN_DeInit();
  CAN_StructInit(&CAN_InitStructure);
  /* CAN cell init */
  CAN_InitStructure.CAN_TTCM=DISABLE;
  CAN_InitStructure.CAN_ABOM=DISABLE;
  CAN_InitStructure.CAN_AWUM=DISABLE;
  CAN_InitStructure.CAN_NART=DISABLE;
  CAN_InitStructure.CAN_RFLM=DISABLE;
  CAN_InitStructure.CAN_TXFP=DISABLE;
//  CAN_InitStructure.CAN_Mode=CAN_Mode_LoopBack;
  CAN_InitStructure.CAN_Mode=CAN_Mode_Normal;
  CAN_InitStructure.CAN_SJW=CAN_SJW_1tq;
  CAN_InitStructure.CAN_BS1=CAN_BS1_8tq;
  CAN_InitStructure.CAN_BS2=CAN_BS2_7tq;
  CAN_InitStructure.CAN_Prescaler=5;
  CAN_Init(&CAN_InitStructure);
  /* CAN filter init */
  CAN_FilterInitStructure.CAN_FilterNumber=0;
  CAN_FilterInitStructure.CAN_FilterMode=CAN_FilterMode_IdMask;
  CAN_FilterInitStructure.CAN_FilterScale=CAN_FilterScale_32bit;
  CAN_FilterInitStructure.CAN_FilterIdHigh=0x0000;
  CAN_FilterInitStructure.CAN_FilterIdLow=0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdHigh=0x0000;
  CAN_FilterInitStructure.CAN_FilterMaskIdLow=0x0000;
  CAN_FilterInitStructure.CAN_FilterFIFOAssignment=0;
  CAN_FilterInitStructure.CAN_FilterActivation=ENABLE;
  CAN_FilterInit(&CAN_FilterInitStructure);
  /* transmit */
  TxMessage.StdId=0x11;
  TxMessage.RTR=CAN_RTR_DATA;
  TxMessage.IDE=CAN_ID_STD;
  TxMessage.DLC=2;
  TxMessage.Data[0]=0xCA;
  TxMessage.Data[1]=0xFE;
  TransmitMailbox=CAN_Transmit(&TxMessage);
  i = 0;
  while((CAN_TransmitStatus(TransmitMailbox) != CANTXOK) && (i != 0xFF))
    i++;
  i = 0;
  while((CAN_MessagePending(CAN_FIFO0) < 1) && (i != 0xFF))
    i++;
  /* receive */
  RxMessage.StdId=0x00;
  RxMessage.IDE=CAN_ID_STD;
  RxMessage.DLC=0;
  RxMessage.Data[0]=0x00;
  RxMessage.Data[1]=0x00;
  CAN_Receive(CAN_FIFO0, &RxMessage);
  if (RxMessage.StdId!=0x11)
    return FAILED;
  if (RxMessage.IDE!=CAN_ID_STD)
    return FAILED;
  if (RxMessage.DLC!=2)
    return FAILED;
  if ((RxMessage.Data[0]<<8|RxMessage.Data[1])!=0xCAFE)
    return FAILED;
  return PASSED; /* Test Passed */
 楼主| licky 发表于 2009-2-24 17:32 | 显示全部楼层
问题出了缺少Speed定义上
问题找到了,初始化的时候端口速度必须要定义, 否则不行
