[文档下载] NuEdu-UNO (Arduino IDE 开发工具包)
9678|30
cnb12345 发表于 2016-4-25 09:32 | 显示全部楼层
xsq 发表于 2016-9-28 09:58 | 显示全部楼层
有人用arduino摆弄这个成功了吗?我怎么就不能呢?
xsq 发表于 2016-9-28 21:38 | 显示全部楼层
哪里可以找到用arduino开发新唐mo的相关教程啊?
xsq 发表于 2016-9-29 08:02 | 显示全部楼层
Arduino:1.6.10 (Windows 7), 开发板:"NuMaker UNO"
In file included from D:\arduino-1.6.10\portable\packages\nuvoton\hardware\nuvoton\1.6.10\cores\nuvoton/Arduino.h:26:0,
                 from sketch\send.ino.cpp:1:
D:\arduino-1.6.10\portable\packages\nuvoton\hardware\nuvoton\1.6.10\system/NUC131/Device/Nuvoton/NUC131/Include/NUC131.h:11065:29: error: expected identifier before '(' token
#define CAN                 ((CAN_T *) CAN0_BASE)
D:\arduino-1.6.10\portable\packages\nuvoton\hardware\nuvoton\1.6.10\libraries\CAN_BUS/can_.h:13:7: note: in expansion of macro 'CAN'
class CAN
D:\arduino-1.6.10\portable\packages\nuvoton\hardware\nuvoton\1.6.10\system/NUC131/Device/Nuvoton/NUC131/Include/NUC131.h:11065:37: error: expected ')' before '*' token
class CAN
class CAN
D:\arduino-1.6.10\portable\packages\nuvoton\hardware\nuvoton\1.6.10\libraries\CAN_BUS\examples\send\send.ino:5:1: note: in expansion of macro 'CAN'
CAN CAN_0;
CAN CAN_0;
D:\arduino-1.6.10\portable\packages\nuvoton\hardware\nuvoton\1.6.10\libraries\CAN_BUS\examples\send\send.ino: In function 'void setup()':
send:13: error: 'CAN_0' was not declared in this scope
     if(CAN_OK == CAN_0.begin(CAN_500KBPS))                   // init can bus : baudrate = 500k
D:\arduino-1.6.10\portable\packages\nuvoton\hardware\nuvoton\1.6.10\libraries\CAN_BUS\examples\send\send.ino: In function 'void loop()':
send:30: error: 'CAN_0' was not declared in this scope
     CAN_0.sendMsgBuf(0x00, 0, 8, stmp);
exit status 1
Using proxy DIRECT
Using proxy DIRECT
Using proxy DIRECT
Using proxy DIRECT
Using proxy DIRECT
在文件 -> 首选项开启
“编译过程中显示详细输出”选项
这份报告会包含更多信息。
这是编译can例子返回的信息,该怎样处理?
xsq 发表于 2016-10-2 21:10 | 显示全部楼层
难道没有用这个吗?
syokujinau 发表于 2016-11-12 15:27 | 显示全部楼层
頂~~~!!
cgd 发表于 2017-1-18 12:17 | 显示全部楼层
xixi2017 发表于 2019-8-10 10:41 来自手机 | 显示全部楼层
jiekou001 发表于 2019-8-16 20:38 来自手机 | 显示全部楼层
頂一下
小明的同学 发表于 2019-8-18 00:40 | 显示全部楼层
可以用Arduino搞?
