max13487接收问题请教
15592|32
ningling_21 发表于 2017-12-4 16:12 | 显示全部楼层
zyj9490 发表于 2017-12-4 13:09
按昭现在的电路,只能一直处在发送模式下,也就是一直占据总线。
怎么会呢,不应该的
zyj9490 发表于 2017-12-4 18:38 | 显示全部楼层
怎么会呢,不应该的
控制脚一直是高电平,处在发送状态。
ningling_21 发表于 2017-12-5 08:07 | 显示全部楼层
控制脚一直是高电平,处在发送状态。
那个脚不是控制脚
rode83 发表于 2017-12-15 09:56 | 显示全部楼层
用这个芯片遇到问题的,绝对是买到假货了。之前在淘宝就买到过一批假的。用普通485打标成13487来卖,害死人了。
dragonland 发表于 2018-4-23 18:04 | 显示全部楼层
AutoDirection Circuitry
Internal circuitry in the MAX13487E/MAX13488E, in
conjunction with an external pullup resistor on A and
pulldown resistor on B (see Typical Application Circuit),
act to automatically disable or enable the driver and
receiver to keep the bus in the correct state. This
AutoDirection circuitry consists of a state machine and
an additional receive comparator that determines
whether this device is trying to drive the bus, or another
node on the network is driving the bus.
The internal state machine has two inputs:
• DI
• The current state of A-B (determined by a dedicated
differential comparator)
The state machine also has two outputs:
• DRIVER_ENABLE—Internal signal that enables and
disables the driver
• RECEIVER_ENABLE—Internal signal that is the
inverse of the DRIVER_ENABLE signal, but it can be
overridden by an external pin
When DI is low, the device always drives the bus low.
When DI is high, the device drives the bus for a short
time, then disables the driver and allows the external
pullup/pulldown resistors to hold the bus in the high
state (A-B > 200mV). During each low-to-high transition
of DI, the driver stays enabled until (A-B) > VDT, and
then disables the driver, letting the pullup/pulldown
resistors hold the A and B lines in the correct state.
失格 发表于 2019-10-23 08:27 | 显示全部楼层
MAX 13487是自动切换首发的只要RE 和DE都为高电平就能工作  手册里有
zyj9490 发表于 2019-10-23 09:25 | 显示全部楼层
不是,控制脚必须被发送电平控制,当低电平时,控制脚处在发送状态,当高电平时,处在接收状态,通过上下拉电阻产生的差压把1发送出去,而不是挂一个高电平(电源)到控制脚。
有的芯片是自动控制收发方向的  发表于 2020-1-9 19:03
guitianxia 发表于 2019-10-23 09:51 | 显示全部楼层
半双工RS - 485- / RS - 422收发器,具有自动方向控制的
guitianxia 发表于 2019-11-17 09:21 | 显示全部楼层
[url=]MAX13487E、MAX13488E典型电路图给你参考下[/url]
[url=][/url]
feixiangli1234 发表于 2020-6-5 11:16 | 显示全部楼层
楼主,问题最后怎么解决的,分享一下谢谢
我最帅! 发表于 2021-1-26 10:02 | 显示全部楼层
最后咋解决的呢?
