Freescale 发布用于自动化方面的ARM11处理器
2153|1
 楼主| wenming 发表于 2009-3-4 11:36 | 显示全部楼层 |阅读模式
<br />Freescale&nbsp;lists&nbsp;specs&nbsp;for&nbsp;the&nbsp;new&nbsp;i.MX353&nbsp;and&nbsp;i.MX357&nbsp;as&nbsp;follows:<br />Processor:&nbsp;ARM1136JF-S&nbsp;at&nbsp;532MHz<br /><br />Cache:&nbsp;16K&nbsp;I/D&nbsp;L1,&nbsp;128KB&nbsp;L2<br /><br />Memory:&nbsp;interfaces&nbsp;to&nbsp;SDRAM,&nbsp;Mobile&nbsp;DDR&nbsp;and&nbsp;DDR2,&nbsp;SLC&nbsp;and&nbsp;MLC&nbsp;NAND&nbsp;flash,&nbsp;NOR&nbsp;flash&nbsp;and&nbsp;SRAM<br /><br />Graphics:<br />LCD&nbsp;Controller<br /><br />OpenVG&nbsp;1.1&nbsp;GPU&nbsp;(i.MX357&nbsp;only)<br />Storage:&nbsp;PATA/CEATA&nbsp;interface<br />I/O:<br />1&nbsp;x&nbsp;10/100&nbsp;Ethernet<br /><br />2&nbsp;x&nbsp;CAN<br /><br />USB:<br />480Mbps&nbsp;OTG&nbsp;(&quot;on&nbsp;the&nbsp;go&quot;)<br /><br />480Mbps&nbsp;host<br />3&nbsp;x&nbsp;I2C<br /><br />2&nbsp;x&nbsp;SSI/I2S<br /><br />3&nbsp;x&nbsp;UART<br /><br />2&nbsp;x&nbsp;SPI<br />Expansion:&nbsp;SD/SDIO/MMC<br /><br />Package:&nbsp;17&nbsp;x&nbsp;17&nbsp;BGA&nbsp;0.8mm&nbsp;400&nbsp;ball<br /><br />Operating&nbsp;temp:<br />532MHz:&nbsp;-20&nbsp;to&nbsp;+70&nbsp;degC<br /><br />400MHz:&nbsp;-40&nbsp;to&nbsp;+85&nbsp;degC
bjc125 发表于 2009-3-5 18:25 | 显示全部楼层
灌水中
