求帮忙看下这个程序怎么只发生一次中断?
2526|4
 楼主| ATmega32L 发表于 2008-5-12 15:33 | 显示全部楼层 |阅读模式
AC, hz, dc, TI, timer
用JTAG调试,TIMERA1_VECTOR中断只发生一次,就不发生了,问题出来哪里?
#include  <msp430x20x2.h>
#include "VLO_Library.h"
#include "intrinsics.h"
unsigned int dco_delta;
unsigned long F_VLOCLK;
unsigned int TACCR0_INIT;
int main(void)
  WDTCTL = WDTPW +WDTHOLD;                  // Stop Watchdog Timer
  P1DIR |= 0x11;                            // P1.0,1,4 outputs
  P1SEL |= 0x10;                            // P1.4 = SMCLK
  BCSCTL3 |= LFXT1S_2;                      // ACLK = VLO
  BCSCTL1 = CALBC1_8MHZ;                    // 8MHz cal value
  DCOCTL = CALDCO_8MHZ;                     // 8MHz cal value
  __delay_cycles(100);
  dco_delta = TI_measureVLO();              // dco delta = number of
                                            // 1MHz cycles in 8 ACLK cycles
  F_VLOCLK=8000000UL / dco_delta;            //VLO时钟频率
  TACCR0_INIT=F_VLOCLK/100-1;
  //TACCTL0 = CCIE;
  TACCR0 = TACCR0_INIT;
  TACTL = TASSEL_1 + MC_1  + TAIE;    //ACLK作为时钟源,不分频,开TIMERA1中断
  P1OUT = 0x01;
  __enable_interrupt();
  while(1);
#pragma vector=TIMERA1_VECTOR
__interrupt void Timer_A(void)
if(TAIV==10)
  P1OUT ^= 0x01;                            // 50HZ输出??
TPtzj 发表于 2008-5-14 09:09 | 显示全部楼层
"VLO_Library.h"怎么用
请问楼主,"VLO_Library.h"这个头文件怎么用?为什么我的IAR没有办法调用??
hotpower 发表于 2008-5-28 01:51 | 显示全部楼层
楼主搞的什么好玩意???
 楼主| ATmega32L 发表于 2008-5-28 17:46 | 显示全部楼层
VLO库
Using the VLO Library
The very low oscillator (VLO) is a clock source included in the 2xx family of devices. This library provides a method of measuring the speed of the VLO without using any external components such as a 32-kHz crystal. Once measured, the VLO can be used to trigger periodic interrupts with greater accuracy. Measuring the VLO also allows for setting the DCO to a specific frequency using a software FLL.
http://focus.ti.com/general/docs/techdocsabstract.tsp?abstractName=slaa340
hotpower 发表于 2008-5-28 22:26 | 显示全部楼层
原来TI_measureVLO()是汇编的
