请教大家推荐一个类似UC3842的DC/DC的IC
2457|1
 楼主| code 发表于 2009-5-22 17:10 | 显示全部楼层 |阅读模式
,要求工作电压是10--24V,其他参数不做要求
UC3842只能工作在16V以上,所以不适合,看了数据手册,一知半解
也不能说UC3842不适合,我也不知道UC3842是否适合,
看了UC3842的数据手册,望文生义,请问下面图片红线当中的开始阀值电压和最少工作电压,两个参数有什么不同??
还有下面是对收据手册进行翻译,16V开 10V关,那么12V的时候,是开还是关??
Differences between members of this family are the
这个系列当中,各个成员之间的区别是低压阀值锁死,和最大周期范围,
under-voltage lockout thresholds and maximum
duty cycle ranges.
 The UC3842 and UC3844 have
UVLO thresholds of 16V (on) and 10V (off), ideally
UC3842和UC3844有低压阀值,16V开 10V关
suited off-line applications
很好的适合离线应用
 The corresponding
thresholds for the UC3843 and UC3845 are 8.5 V
and 7.9 V. The UC3842 and UC3843 can operate
to duty cycles approaching 100%. A range of the
zero to < 50 % is obtained by the UC3844 and
UC3845by the additionof aninternal toggleflip flop
which blanks the output off every other clock cycle.
thf2008 发表于 2009-6-4 00:31 | 显示全部楼层
