[国产单片机] HC-SR04超声波测距模块,在LCD602上显示
2120|7
 楼主| 明眸 发表于 2015-10-23 15:58 | 显示全部楼层 |阅读模式
,结果只显示上电的那个距离,然后移动模块,距离不自动更新!求赐教!程序如下:
#include <STC12C5A60S2.h>
#include <intrins.h>
#define LCD1602_DB  P0
//sfr AUXE=0x8E;//1T
sbit Trig=P3^2;
sbit Echo=P3^3;
sbit LCD1602_RS = P1^0;
sbit LCD1602_RW = P1^1;
sbit LCD1602_E  = P1^5;
unsigned char code str1[]={"Ready..."};
unsigned char code str2[]={"Beyond range!"};
unsigned char code str3[]={"Measuring:"};
//unsigned char code ASCII[15] =    {'0','1','2','3','4','5','6','7','8','9'};
unsigned char str5[6]={"CM"};
unsigned int time;
unsigned long distance;
bit flag=0;
/*等待液晶准备好*/
void lcdwaitready()
        unsigned char sta;
        LCD1602_DB=0xFF;//单片机读,先写入1
        LCD1602_RS=0;
        LCD1602_RW=1;
        do
                LCD1602_E=1;
                sta=LCD1602_DB;
                LCD1602_E=0;
        }while(sta&0x80);
/*向LCD液晶写命令*/
void lcdwritecmd(unsigned char cmd)
         lcdwaitready();
         LCD1602_RS=0;
         LCD1602_RW=0;
         LCD1602_DB=cmd;
         LCD1602_E=1;
         LCD1602_E=0;
/*向LCD液晶写数据*/
void lcdwritedat(unsigned char dat)
         lcdwaitready();
         LCD1602_RS=1;
         LCD1602_RW=0;
         LCD1602_DB=dat;
         LCD1602_E=1;
         LCD1602_E=0;
/*设置起始坐标*/
void lcdsetcursor(unsigned char x,unsigned char y)                //形参是局部变量,可以与其他冲突
        unsigned char addr;
        if(y==0)
                addr=0x00+x;
        else
                addr=0x40+x;
        lcdwritecmd(addr|0x80);                 //设置数据地址指针         0x80+addr
/*void lcdshowchar(unsigned char x,unsigned char y,unsigned char dat)                //形参是局部变量,可以与其他冲突
        unsigned char addr;
        if(y==0)
                addr=0x00+x;
        else
                addr=0x40+x;
        lcdwritedat(dat);
/*在液晶上显示字符串*/
void lcdshowstr(unsigned char x,unsigned char y,unsigned char *str)
        lcdsetcursor(x,y);
        while(*str!='\0')
                lcdwritedat(*str++);
/*LCD初始化*/
void lcdinit()
        lcdwritecmd(0x38);  //16*2显示,5*7点阵,8位数据接口
    lcdwritecmd(0x0C);  //显示器开,光标关闭
    lcdwritecmd(0x06);  //文字不动,地址自动+1
    lcdwritecmd(0x01);  //清屏
void DELAY_MS (unsigned int a){
        unsigned int i;
        while( a-- != 0){
                for(i = 0; i < 600; i++);
void Count()
        unsigned char str4[10];
           time=TH0*256+TL0;
        TH0=0;
        TL0=0;
        distance=(time*1.72)/100;//单位为CM
        if(distance>700||flag==1)
                flag=0;
                lcdshowstr(0,0,str2);
        else
                str4[0]=distance/100%10+'0';
                str4[1]=distance/10%10+'0';
                str4[2]=distance%10+'0';
                lcdshowstr(0,0,str3);
                lcdshowstr(0,1,str4);
                lcdshowstr(3,1,str5);
void interrupttimer0() interrupt 1
        flag=1;
void starmodul()
                Trig=1;                                             //启动一次模块
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          _nop_();
          Trig=0;
void main()
        lcdinit();
        DELAY_MS(1000);
        lcdshowstr(0,0,str1);
        DELAY_MS(2000);
        Trig=0;//首先拉低输入脉冲引脚
        TMOD&=0xF0;
        TMOD|=0x01;
        TH0=0;
        TL0=0;
        ET0=1;
        EA=1;
        while(1)
                starmodul();
                while(!Echo);
                TR0=1;
                while(Echo);
                TR0=0;
                Count();
                Echo=1;
 楼主| 明眸 发表于 2015-10-23 16:51 | 显示全部楼层
JY-DX-JY 发表于 2015-10-25 13:45 | 显示全部楼层
是不是卡在哪儿啦?
 楼主| 明眸 发表于 2015-10-26 09:39 | 显示全部楼层
是不是卡在哪儿啦?
就是不知道嘛
JY-DX-JY 发表于 2015-10-26 09:55 | 显示全部楼层
调试一下呀
lisituo 发表于 2015-11-12 11:18 | 显示全部楼层
主函数 while循环最后一句 ECHO = 1.估计多余了。把他去了试试。
ghost2 发表于 2015-11-18 23:34 来自手机 | 显示全部楼层
中断里改写并在本中断外使用的变量,必须加volatile修饰符
yuanquan12345 发表于 2016-1-18 15:20 | 显示全部楼层
请问楼主,现在运行的怎样。我的出现数据跳变,不稳定,测试正常,到现场就出现不稳定,我用在测水位上。
