一个网友发给俺的信,用仿真器老弹出窗口
3164|5
 楼主| ni_labview 发表于 2008-5-7 22:57 | 显示全部楼层 |阅读模式
我没法看出程序出了什么问题,像仿真器的问题,大家帮忙瞧瞧怎么解决?先替那兄弟谢过大家,附件中有显示的错误信息图片
下面贴下主要程序:
这个是主程序:
; Assembly main line
include "m8c.inc"       ; part specific constants and macros
include "memory.inc"    ; Constants & macros for SMM/LMM and Compiler
include "PSoCAPI.inc"   ; PSoC API definitions for all User Modules
export _main
export outputV
export timernum
area   bss(RAM)
outputV : blk 1
timernum : blk 6
area   text(ROM,REL)
_main:
   M8C_EnableGInt
   call PWM8_1_Start
   call Timer8_1_EnableInt
   call Timer8_1_Start
   call LCD_1_Start
   mov  [timernum],ffffffh
   mov  [outputV],02h
   mov  A,00h
   mov  X,[outputV]
   call LCD_1_Position
   mov  A,>THE_STR
   mov  X,<THE_STR
   call LCD_1_PrCString
.terminate:
      jmp .terminate
  .LITERAL
 THE_STR:
   DS  " HUI GE SHIT!"
   DB  00h
   .ENDLITERAL
这个是定时器中断里的程序:
_Timer8_1_ISR:
   ;@PSoC_UserCode_BODY@ (Do not change this line.)
   ; Insert your custom code below this banner
   ;   NOTE: interrupt service routines must preserve
   ;   the values of the A and X CPU registers.
   push  A
   dec  [timernum]
   mov  A,[timernum]
   jnz  branch1
   mov  A,00h
   mov  X,[outputV]
   call LCD_1_Position
   mov  A,>THE_STR1
   mov  X,<THE_STR1
  .LITERAL
 THE_STR1:
   DS  " HUI GE SHIT!"
   DB  00h
   .ENDLITERAL
   dec  [outputV]
   mov   A,[outputV]
   jnz   branch1
   mov   [outputV],0eh
 branch1:
   pop   A
    ; Insert your main assembly code here.
   ; Insert your custom code above this banner
   ;@PSoC_UserCode_END@ (Do not change this line.)
   reti
相关链接:https://bbs.21ic.com/upfiles/img/20076/200762223129345.rar
hotpower 发表于 2008-5-9 22:16 | 显示全部楼层
哈哈~~~搞不明白楼上的连接没出来~~~
shilei1014 发表于 2008-5-9 22:27 | 显示全部楼层
shilei1014 发表于 2008-5-9 22:29 | 显示全部楼层
请问
NI大哥,上面的程序有几个CALL的函数调用指令,这几条指令都是PSOC designer产生的API么?还是自己定义编写的?
 楼主| ni_labview 发表于 2008-5-10 13:31 | 显示全部楼层
PSOC designer自己产生的API
qiuming 发表于 2008-5-11 23:31 | 显示全部楼层
解决了吗
我也想知道答案.
