21534的休眠问题
2721|2
 楼主| xxs 发表于 2008-7-10 17:02 | 显示全部楼层 |阅读模式
DM, sd, AN, TE, TI
现在我设计的按键有8个,系统时钟为2.7V/12MHz,测量的电流为4mA,然后我设置64HZ的休眠后,为什么电流还是没怎么降下去啊?难道还要别的设置吗,请高人指点。
程序如下:
#include <m8c.h>        // part specific constants and macros
#include "PSoCAPI.h"    // PSoC API definitions for all User Modules
#pragma interrupt_handler  Sleep_Timer_ISR
void Sleep_Timer_ISR(void);
struct Info
  BYTE  data0;
  BYTE  data1;
  BYTE  data2;
  BYTE  data3;
  BYTE  data4;
  BYTE  key1;
}myInfo;
void  CSD_SCAN(void);
void  main()
       int i,j;
      M8C_EnableGInt;
      CSD_Start();
      CSD_SetDefaultFingerThresholds();
      CSD_InitializeBaselines();
      CSD_baBtnFThreshold[2] = 70;
      CSD_baBtnFThreshold[3] = 70;
      CSD_baBtnFThreshold[4] = 70;
      CSD_baBtnFThreshold[5] = 70;
      CSD_baBtnFThreshold[6] = 70;
      CSD_baBtnFThreshold[7] = 70;
     for (i=0; i< 25000; i++)
      j=1;                      //Delay long enough for title and version to be displayed
     for (i=0; i< 25000; i++);
      j=1;
      while(1)
       CSD_ScanAllSensors();
       CSD_UpdateAllBaselines();
       CSD_SCAN();
            PRT0DM0 = 0x00;
            PRT0DM1 = 0xFF;
            PRT0DM2 = 0xFF;
            PRT1DM0 = 0x00;
            PRT1DM1 = 0xFF;
            PRT1DM2 = 0xFF;
            PRT2DM0 = 0x00;
            PRT2DM1 = 0xFF;
            PRT2DM2 = 0xFF;
            M8C_EnableIntMask(INT_MSK0, INT_MSK0_SLEEP);
            M8C_Sleep;
void Sleep_Timer_ISR()
    M8C_ClearWDTAndSleep;
    PRT0DM0 = 0x00;
    PRT0DM1 = 0xFF;
    PRT0DM2 = 0xFF;
    PRT1DM0 = 0x60;
    PRT1DM1 = 0x9F;
    PRT1DM2 = 0xDF;
    PRT2DM0 = 0x20;
    PRT2DM1 = 0xDF;
    PRT2DM2 = 0xDF;
PSoC_Rock 发表于 2008-7-10 17:32 | 显示全部楼层
Sleep之前用把CSD模块关掉
用CSD_Stop();
1210 发表于 2009-7-23 09:24 | 显示全部楼层
xxs
