[DemoCode下载] 新唐M451系列USBD_HID_Keyboard
3661|5
 楼主| YWBIN 发表于 2015-10-26 13:37 | 显示全部楼层 |阅读模式
该Demo相对原BSD包中的Demo增加了键盘上LED灯状态相应数据的接收与处理。
 楼主| YWBIN 发表于 2015-10-26 13:38 | 显示全部楼层
程序
Usb_Keyboard.rar
1.1 MB, 下载次数: 49
734774645 发表于 2015-10-26 17:28 | 显示全部楼层
我来贴出来:
* @file     main.c
* @brief
*           Show how to implement a USB keyboard device.
*           This sample code supports to use GPIO to simulate key input.
* @note
* Copyright (C) 2014~2015 Nuvoton Technology Corp. All rights reserved.
#include <stdio.h>
#include "M451Series.h"
#include "hid_kb.h"
uint8_t volatile g_u8EP2Ready = 0;
uint8_t g_u8InitialBuffer = 0;
void SYS_Init(void)
    /* Init System Clock        */
    /* Enable Internal RC 22.1184 MHz clock */
    CLK_EnableXtalRC(CLK_PWRCTL_HIRCEN_Msk);
    /* Waiting for Internal RC clock ready */
    CLK_WaitClockReady(CLK_STATUS_HIRCSTB_Msk);
    /* Switch HCLK clock source to Internal RC and HCLK source divide 1 */
    CLK_SetHCLK(CLK_CLKSEL0_HCLKSEL_HIRC, CLK_CLKDIV0_HCLK(1));
    /* Enable external XTAL 12 MHz clock */
    CLK_EnableXtalRC(CLK_PWRCTL_HXTEN_Msk);
    /* Waiting for external XTAL clock ready */
    CLK_WaitClockReady(CLK_STATUS_HXTSTB_Msk);
    /* Set Flash Access Delay */
    FMC->FTCTL |= FMC_FTCTL_FOM_Msk;
    /* Set core clock */
    CLK_SetCoreClock(72000000);
    /* Enable module clock */
    CLK_EnableModuleClock(UART0_MODULE);
    CLK_EnableModuleClock(USBD_MODULE);
    /* Select module clock source */
    CLK_SetModuleClock(UART0_MODULE, CLK_CLKSEL1_UARTSEL_HXT, CLK_CLKDIV0_UART(1));
    CLK_SetModuleClock(USBD_MODULE, 0, CLK_CLKDIV0_USB(3));
    /* Enable USB LDO33 */
    SYS->USBPHY = SYS_USBPHY_LDO33EN_Msk;
    /* Init I/O Multi-function        */
    /* Set GPD multi-function pins for UART0 RXD, TXD and clock output */
    SYS->GPD_MFPL = SYS_GPD_MFPL_PD0MFP_UART0_RXD | SYS_GPD_MFPL_PD1MFP_UART0_TXD | SYS_GPD_MFPL_PD6MFP_CLKO;
    /* Enable CLKO (PD.6) for monitor HCLK. CLKO = HCLK/8 Hz */
    CLK_EnableCKO(CLK_CLKSEL1_CLKOSEL_HCLK, 2, 0);
void UART0_Init(void)
    /* Init UART        */
    /* Reset IP */
    SYS_ResetModule(UART0_RST);
    /* Configure UART0 and set UART0 Baudrate */
    UART_Open(UART0, 115200);
void HID_UpdateKbData(void)
    int32_t i;
    uint8_t *buf;
    uint32_t key = 0xF;
    static uint32_t preKey;
    if(g_u8EP2Ready)
        buf = (uint8_t *)(USBD_BUF_BASE + USBD_GET_EP_BUF_ADDR(EP2));
        /* If PB.5 = 0, just report it is key 'a' */
        key = (PB->PIN & (1 << 5)) ? 0 : 1;
        if(key == 0)
            if(g_u8InitialBuffer == 0)
                for(i = 0; i < 8; i++)
                    buf = 0;
                g_u8InitialBuffer = 1;
            else
                buf[2] = 0x0;
            if(key != preKey)
                /* Trigger to note key release */
                USBD_SET_PAYLOAD_LEN(EP2, 8);
        else
            preKey = key;
            buf[2] = 0x04; /* Key A */
/*  Main Function        */
int32_t main(void)
    /* Unlock protected registers */
    SYS_UnlockReg();
    SYS_Init();
    UART0_Init();
    printf("\n");
    printf("+--------------------------------------------------------+\n");
    printf("|          NuMicro USB HID Keyboard Sample Code          |\n");
    printf("If PB.5 = 0, just report it is key 'a'.\n");
    USBD_Open(&gsInfo, HID_ClassRequest, NULL);
    /* Endpoint configuration */
    HID_Init();
    USBD_Start();
    NVIC_EnableIRQ(USBD_IRQn);
    /* start to IN data */
    g_u8EP2Ready = 1;
    while(1)
        HID_UpdateKbData();
/*** (C) COPYRIGHT 2014~2015 Nuvoton Technology Corp. ***/
734774645 发表于 2015-10-26 17:29 | 显示全部楼层
* @file     hid_kb.c
* @brief    M451 series USBD HID keyboard sample file
* @note
* Copyright (C) 2013~2015 Nuvoton Technology Corp. All rights reserved.
/*!<Includes */
#include <string.h>
#include "usbd.h"
#include "hid_kb.h"
unsigned char Led_Status[8];
void USBD_IRQHandler(void)
    uint32_t u32IntSts = USBD_GET_INT_FLAG();
    uint32_t u32State = USBD_GET_BUS_STATE();
    if(u32IntSts & USBD_INTSTS_FLDET)
        // Floating detect
        USBD_CLR_INT_FLAG(USBD_INTSTS_FLDET);
        if(USBD_IS_ATTACHED())
            /* USB Plug In */
            USBD_ENABLE_USB();
        else
            /* USB Un-plug */
            USBD_DISABLE_USB();
    if(u32IntSts & USBD_INTSTS_BUS)
        /* Clear event flag */
        USBD_CLR_INT_FLAG(USBD_INTSTS_BUS);
        if(u32State & USBD_STATE_USBRST)
            /* Bus reset */
            USBD_ENABLE_USB();
            USBD_SwReset();
        if(u32State & USBD_STATE_SUSPEND)
            /* Enable USB but disable PHY */
            USBD_DISABLE_PHY();
        if(u32State & USBD_STATE_RESUME)
            /* Enable USB and enable PHY */
            USBD_ENABLE_USB();
    if(u32IntSts & USBD_INTSTS_USB)
        // USB event
        if(u32IntSts & USBD_INTSTS_SETUP)
            // Setup packet
            USBD_CLR_INT_FLAG(USBD_INTSTS_SETUP);
            /* Clear the data IN/OUT ready flag of control end-points */
            USBD_STOP_TRANSACTION(EP0);
            USBD_STOP_TRANSACTION(EP1);
            USBD_ProcessSetupPacket();
        // EP events
        if(u32IntSts & USBD_INTSTS_EP0)
            USBD_CLR_INT_FLAG(USBD_INTSTS_EP0);
            // control IN
            USBD_CtrlIn();
        if(u32IntSts & USBD_INTSTS_EP1)
            USBD_CLR_INT_FLAG(USBD_INTSTS_EP1);
            // control OUT
            USBD_CtrlOut();
        if(u32IntSts & USBD_INTSTS_EP2)
            USBD_CLR_INT_FLAG(USBD_INTSTS_EP2);
            // Interrupt IN
            EP2_Handler();
        if(u32IntSts & USBD_INTSTS_EP3)
            USBD_CLR_INT_FLAG(USBD_INTSTS_EP3);
        if(u32IntSts & USBD_INTSTS_EP4)
            USBD_CLR_INT_FLAG(USBD_INTSTS_EP4);
        if(u32IntSts & USBD_INTSTS_EP5)
            USBD_CLR_INT_FLAG(USBD_INTSTS_EP5);
        if(u32IntSts & USBD_INTSTS_EP6)
            USBD_CLR_INT_FLAG(USBD_INTSTS_EP6);
        if(u32IntSts & USBD_INTSTS_EP7)
            USBD_CLR_INT_FLAG(USBD_INTSTS_EP7);
    /* clear unknown event */
    USBD_CLR_INT_FLAG(u32IntSts);
void EP2_Handler(void)  /* Interrupt IN handler */
    g_u8EP2Ready = 1;
  * @brief  USBD Endpoint Config.
  * @param  None.
  * @retval None.
void HID_Init(void)
    /* Init setup packet buffer */
    /* Buffer range for setup packet -> [0 ~ 0x7] */
    USBD->STBUFSEG = SETUP_BUF_BASE;
    /* EP0 ==> control IN endpoint, address 0 */
    USBD_CONFIG_EP(EP0, USBD_CFG_CSTALL | USBD_CFG_EPMODE_IN | 0);
    /* Buffer range for EP0 */
    USBD_SET_EP_BUF_ADDR(EP0, EP0_BUF_BASE);
    /* EP1 ==> control OUT endpoint, address 0 */
    USBD_CONFIG_EP(EP1, USBD_CFG_CSTALL | USBD_CFG_EPMODE_OUT | 0);
    /* Buffer range for EP1 */
    USBD_SET_EP_BUF_ADDR(EP1, EP1_BUF_BASE);
    /* EP2 ==> Interrupt IN endpoint, address 1 */
    USBD_CONFIG_EP(EP2, USBD_CFG_EPMODE_IN | INT_IN_EP_NUM);
    /* Buffer range for EP2 */
    USBD_SET_EP_BUF_ADDR(EP2, EP2_BUF_BASE);
void HID_ClassRequest(void)
    uint8_t buf[8];
    USBD_GetSetupPacket(buf);
    if(buf[0] & 0x80)    /* request data transfer direction */
        // Device to host
        switch(buf[1])
            case GET_REPORT:
//                 break;
            case GET_IDLE:
//                 break;
            case GET_PROTOCOL:
//                break;
            default:
                /* Setup error, stall the device */
                USBD_SetStall(EP0);
                USBD_SetStall(EP1);
                break;
    else
        // Host to device
        switch(buf[1])
            case SET_REPORT:
                if(buf[3] == 2)
                    /* Request Type = Output */
                    USBD_SET_DATA1(EP1);
                    USBD_SET_PAYLOAD_LEN(EP1, buf[6]);
                    /* Status stage */
                    USBD_PrepareCtrlIn(0, 0);
        USBD_PrepareCtrlOut(Led_Status, buf[6]);
                break;
            case SET_IDLE:
                /* Status stage */
                USBD_SET_DATA1(EP0);
                USBD_SET_PAYLOAD_LEN(EP0, 0);
                break;
            case SET_PROTOCOL:
//                 break;
            default:
                // Stall
                USBD_SetStall(EP0);
                USBD_SetStall(EP1);
                break;
734774645 发表于 2015-10-26 17:30 | 显示全部楼层
* @file     descriptors.c
* @brief    M451 series USBD descriptor
* @note
/*!<Includes */
#include "hid_kb.h"
/*!<USB HID Report Descriptor */
const uint8_t HID_KeyboardReportDescriptor[] =
    0x05, 0x01,     /* Usage Page(Generic Desktop Controls) */
    0x09, 0x06,     /* Usage(Keyboard) */
    0xA1, 0x01,     /* Collection(Application) */
    0x05, 0x07,     /* Usage Page(Keyboard/Keypad) */
    0x19, 0xE0,     /* Usage Minimum(0xE0) */
    0x29, 0xE7,     /* Usage Maximum(0xE7) */
    0x15, 0x00,     /* Logical Minimum(0x0) */
    0x25, 0x01,     /* Logical Maximum(0x1) */
    0x75, 0x01,     /* Report Size(0x1) */
    0x95, 0x08,     /* Report Count(0x8) */
    0x81, 0x02,     /* Input (Data) => Modifier byte */
    0x95, 0x01,     /* Report Count(0x1) */
    0x75, 0x08,     /* Report Size(0x8) */
    0x81, 0x01,     /* Input (Constant) => Reserved byte */
    0x95, 0x05,     /* Report Count(0x5) */
    0x05, 0x08,     /* Usage Page(LEDs) */
    0x19, 0x01,     /* Usage Minimum(0x1) */
    0x29, 0x05,     /* Usage Maximum(0x5) */
    0x91, 0x02,     /* Output (Data) => LED report */
    0x75, 0x03,     /* Report Size(0x3) */
    0x91, 0x01,     /* Output (Constant) => LED report padding */
    0x95, 0x06,     /* Report Count(0x6) */
    0x25, 0x65,     /* Logical Maximum(0x65) */
    0x19, 0x00,     /* Usage Minimum(0x0) */
    0x29, 0x65,     /* Usage Maximum(0x65) */
    0x81, 0x00,     /* Input (Data) */
    0xC0            /* End Collection */
/*!<USB Device Descriptor */
const uint8_t gu8DeviceDescriptor[] =
    LEN_DEVICE,     /* bLength */
    DESC_DEVICE,    /* bDescriptorType */
    0x10, 0x01,     /* bcdUSB */
    0x00,           /* bDeviceClass */
    0x00,           /* bDeviceSubClass */
    0x00,           /* bDeviceProtocol */
    EP0_MAX_PKT_SIZE,   /* bMaxPacketSize0 */
    /* idVendor */
    USBD_VID & 0x00FF,
    (USBD_VID & 0xFF00) >> 8,
    /* idProduct */
    USBD_PID & 0x00FF,
    (USBD_PID & 0xFF00) >> 8,
    0x00, 0x00,     /* bcdDevice */
    0x01,           /* iManufacture */
    0x02,           /* iProduct */
    0x03,           /* iSerialNumber - no serial */
    0x01            /* bNumConfigurations */
/*!<USB Configure Descriptor */
const uint8_t gu8ConfigDescriptor[] =
    LEN_CONFIG,     /* bLength */
    DESC_CONFIG,    /* bDescriptorType */
    /* wTotalLength */
    LEN_CONFIG_AND_SUBORDINATE & 0x00FF,
    (LEN_CONFIG_AND_SUBORDINATE & 0xFF00) >> 8,
    0x01,           /* bNumInterfaces */
    0x01,           /* bConfigurationValue */
    0x00,           /* iConfiguration */
    0x80 | (USBD_SELF_POWERED << 6) | (USBD_REMOTE_WAKEUP << 5),/* bmAttributes */
    USBD_MAX_POWER,         /* MaxPower */
    /* I/F descr: HID */
    LEN_INTERFACE,  /* bLength */
    DESC_INTERFACE, /* bDescriptorType */
    0x00,           /* bInterfaceNumber */
    0x00,           /* bAlternateSetting */
    0x01,           /* bNumEndpoints */
    0x03,           /* bInterfaceClass */
    0x01,           /* bInterfaceSubClass */
    HID_KEYBOARD,   /* bInterfaceProtocol */
    0x00,           /* iInterface */
    /* HID Descriptor */
    LEN_HID,        /* Size of this descriptor in UINT8s. */
    DESC_HID,       /* HID descriptor type. */
    0x10, 0x01,     /* HID Class Spec. release number. */
    0x00,           /* H/W target country. */
    0x01,           /* Number of HID class descriptors to follow. */
    DESC_HID_RPT,   /* Descriptor type. */
    /* Total length of report descriptor. */
    sizeof(HID_KeyboardReportDescriptor) & 0x00FF,
    (sizeof(HID_KeyboardReportDescriptor) & 0xFF00) >> 8,
    /* EP Descriptor: interrupt in. */
    LEN_ENDPOINT,   /* bLength */
    DESC_ENDPOINT,  /* bDescriptorType */
    (INT_IN_EP_NUM | EP_INPUT), /* bEndpointAddress */
    EP_INT,         /* bmAttributes */
    /* wMaxPacketSize */
    EP2_MAX_PKT_SIZE & 0x00FF,
    (EP2_MAX_PKT_SIZE & 0xFF00) >> 8,
    HID_DEFAULT_INT_IN_INTERVAL     /* bInterval */
/*!<USB Language String Descriptor */
const uint8_t gu8StringLang[4] =
    4,              /* bLength */
    DESC_STRING,    /* bDescriptorType */
    0x09, 0x04
/*!<USB Vendor String Descriptor */
const uint8_t gu8VendorStringDesc[] =
    16,
    DESC_STRING,
    'N', 0, 'u', 0, 'v', 0, 'o', 0, 't', 0, 'o', 0, 'n', 0
/*!<USB Product String Descriptor */
const uint8_t gu8ProductStringDesc[] =
    26,
    DESC_STRING,
    'H', 0, 'I', 0, 'D', 0, ' ', 0, 'K', 0, 'e', 0, 'y', 0, 'b', 0, 'o', 0, 'a', 0, 'r', 0, 'd', 0
const uint8_t gu8StringSerial[26] =
    26,             // bLength
    DESC_STRING,    // bDescriptorType
    'A', 0, '0', 0, '2', 0, '0', 0, '1', 0, '4', 0, '0', 0, '9', 0, '0', 0, '3', 0, '0', 0, '2', 0
const uint8_t *gpu8UsbString[4] =
    gu8StringLang,
    gu8VendorStringDesc,
    gu8ProductStringDesc,
    gu8StringSerial
const uint8_t *gpu8UsbHidReport[3] =
    HID_KeyboardReportDescriptor,
    NULL,
    NULL
const uint32_t gu32UsbHidReportLen[3] = {
    sizeof(HID_KeyboardReportDescriptor),
    0,
const uint32_t gu32ConfigHidDescIdx[3] = {
    (LEN_CONFIG+LEN_INTERFACE),
    0,
const S_USBD_INFO_T gsInfo =
    gu8DeviceDescriptor,
    gu8ConfigDescriptor,
    gpu8UsbString,
    gpu8UsbHidReport,
    gu32UsbHidReportLen,
643757107 发表于 2015-10-27 09:31 | 显示全部楼层
NuTiny-SDK-M451软硬件开发环境,方便客户于IAR EWARM 和Keil™ RVMDK开发环境下,利用M451全系列开发新产品。客户可利用新唐提供之专属 ISP(In System Program)、IAP(In Application Program) 或 ICP(In Circuit Program),透过在线或脱机烧录,直接对系统在线更新,增加生产的灵活度与设计的便利性。
