SSD1351 display driver library[size=1.4]The SSD1351 display controller is supported by the RAMTEX SSD1339 display driver library package.
Full GUI display driver C source code. Processor and C compiler independent.[size=1.3]Graphic library for SSD1351
SSD1351 display controller characteristicsBelow is a brief introduction to the main characteristics for the SSD1351 RGBdisplay controller (seen from a software driver design viewpoint). For information about the SSD1351 driver software support please go to the library description. SSD1351 device type- COG RGB color display controller for use in small embedded systems with on-chip frame buffer and OLED screen driver .
- The SSD1351 supports OLED screens with a size up to 128 x 128 pixels (WxH)
- On-chip OLED driver with voltage generator and software controlled intensity regulation.
Frame buffer- RGB pixel resolution (bits per pixel): 16-bit, 18-bit.
- SSD1351 frame buffer organization: 128 RGB pixels on scan line, 128 lines.
Processor interfaces on SSD1351- SSD1351 parallel bus interface
- Parallel bus types: 8080 bus type and 6800 bus type
- Parallel bus size: 8-bit, 16-bit, 18 (32)-bit.
- Addressing concept: Indexed bus interface (1 chip select pin + 1 address bit pin (Data/Command))
- Serial bus interfaces on SSD1351
- SPI bus: 4-wire: /CS, DC, SDIN, SCLK
- SPI bus: 3-wire: /CS, SDIN, SCLK
- In SPI bus there is no read-back of frame buffer memory
- The bus interfaces are all supported by the SSD1351 display driver software package.
Special SSD1351 hardware features:- 0-180 degree frame buffer rotation with hardware support
- Support for screen driver intensity (contrast) requlation in hardware.
- Full driver software support.
