Panel resolution (HxV): 960x240 Double gate driver with 480 sources and 480 gates
8-bit resolution, 256 gray scale with dithering (7bits DAC + 1 bit FRC)
Display control and function selection by 3-wire SPI interface.
Support 8-bit RGB, 8-bit Dummy RGB, Parallel RGB, CCIR601 and CCIR656 input.
Build-in DC-DC control circuit, charge pump, VCOM with programmable adjustment
Built-in R-DAC gamma correction
Line/Column inversion selectable
Right/Left shift, Up and Down scan function selectable
Build-In PWM circuit for LED Back-light
Power for digital circuit (VDD): 2.7V~ 3.6V
Power for analog circuit (AVDD): VDD/VINT1
Power for Interface circuit (VDDIO): 1.65V ~ 3.6V
就是个SPI接口锕
