我自己读配置文件的JAVA代码(单例模式)
842|0
keer_zu|  楼主 | 2015-10-28 09:42 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
import com.sun.star.io.IOException;
public class ConfigEnv {
        private String envDsIp;
        private int envDsPort;
        private int envServerId;
        private String envOfficeHome;
        private int envConvertImpPort;
        private static class ConfigEnvHolder {
//                try{
                        private static final ConfigEnv INSTANCE = new ConfigEnv();
//                } catch (IOException e){
        public int GetConvertImpPort(){
                return this.envConvertImpPort;
        public String GetDsIp(){
                return this.envDsIp;
        public int GetDsPort(){
                return this.envDsPort;
        public int GetServerId(){
                return this.envServerId;
        public String GetOfficeHome(){
                return this.envOfficeHome;
        private ConfigEnv (){
                IniReader iniReader = null;
                try {
                        iniReader = new IniReader("./fileconver_config.ini");
                        System.out.println("ioexception 1.");
                        e.printStackTrace();
                        return;
                } catch (java.io.IOException e) {
                        // TODO Auto-generated catch block
                        System.out.println("ioexception 2.");
                        return;
            String str = iniReader.getValue("config", "ConvertImpPort");
               this.envConvertImpPort = Integer.parseInt(str);
              this.envOfficeHome = iniReader.getValue("config", "OFFICE_HOME");
              this.envDsIp = iniReader.getValue("config", "IP");
              this.envDsPort = Integer.parseInt(iniReader.getValue("config", "Port"));
              this.envServerId = Integer.parseInt(iniReader.getValue("config", "ID"));
        public static final ConfigEnv getInstance() {
                        return ConfigEnvHolder.INSTANCE;
