分享最近一个JAVA项目:基本功能
865|0
keer_zu|  楼主 | 2015-11-6 15:03 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
JAVA, ST, ge, TE, TI
import java.io.BufferedReader;
import java.io.BufferedWriter;
import java.io.File;
import java.io.FileNotFoundException;
import java.io.FileReader;
import java.io.FileWriter;
import java.io.IOException;
import java.io.InputStream;
import java.nio.ByteBuffer;
import java.nio.CharBuffer;
import java.nio.charset.Charset;
import java.nio.charset.CharsetDecoder;
import java.util.regex.Matcher;
import java.util.regex.Pattern;
public class SysTools{
        public SysTools(String path){
        public static String InputStream2String(InputStream in)throws IOException   {
                StringBuffer out = new StringBuffer();
        byte[] b = new byte[4096];
        for (int n;(n = in.read(b)) != -1;){
             out.append(new String(b,0,n));
        return out.toString();
        public static String MountAndModifyPath(char[] chNewSrcFile,int srcLen,String strNewStrFile){
                return strNewStrFile;
        public static int GetPdfPageNum(String file){
                int page_num;
                Process exe;
                Process test;
                try {
                        String[] cmd = new String[]{"/bin/sh","-c","./pdf2swf -I " + file + " | grep -c 'page'"};
                        exe = Runtime.getRuntime().exec(cmd);
                InputStream inputStream = exe.getInputStream();
                String outInf = InputStream2String(inputStream);
                System.out.println("******* outInf:" + outInf);
                outInf = outInf.replaceAll("\r|\n", "");
                page_num = Integer.parseInt(outInf);
        } catch (IOException e) {
            e.printStackTrace();
            page_num = -1;
                return page_num;
        public static String GetFileName(String path){
                int index = path.lastIndexOf("/");
                //将字符串转为字符数组
                char[] ch = path.toCharArray();
                //根据 copyValueOf(char[] data, int offset, int count) 取得最后一个字符串
                String fileName = String.copyValueOf(ch, index + 1, ch.length - index - 1);
                return fileName;
         * Java文件操作 获取文件扩展名
         *  Created on: 2011-8-2
         *      Author: blueeagle
        public static String GetExtensionName(String filename) {
                if ((filename != null) && (filename.length() > 0)) {
                        int dot = filename.lastIndexOf('.');
                        if ((dot >-1) && (dot < (filename.length() - 1))) {
                                return filename.substring(dot + 1);
                return filename;
         * Java文件操作 获取不带扩展名的文件名
         *      Author: blueeagle
        public static String GetFileNameNoEx(String filename) {
                                if ((dot >-1) && (dot < (filename.length()))) {
                                        return filename.substring(0, dot);
                return filename;
        public static void CheckAndBuildTargetFoleder(String targetFoleder){
                File file = new File(targetFoleder);
                //判断文件夹是否存在,如果不存在则创建文件夹
                if (!file.exists()) {
                        file.mkdir();
        public static String ByteBuffToString(ByteBuffer buffer){
                Charset charset = null;
                CharsetDecoder decoder = null;
                CharBuffer charBuffer = null;
                try{
                        charset = Charset.forName("UTF-8");
                        decoder = charset.newDecoder();
            // charBuffer = decoder.decode(buffer);//用这个的话,只能输出来一次结果,第二次显示为空
            charBuffer = decoder.decode(buffer.asReadOnlyBuffer());
            return charBuffer.toString();
        } catch (Exception ex) {
            ex.printStackTrace();
            return "";
        public static String GetFilePath(String path){
                String filePath = path.replaceAll(GetFileName(path), "");
                return filePath;
     * 删除单个文件
     * @param   sPath    被删除文件的文件名
     * @return 单个文件删除成功返回true,否则返回false
    public static boolean deleteFile(String sPath) {
        boolean flag = false;
        File file = new File(sPath);
        // 路径为文件且不为空则进行删除
        if (file.isFile() && file.exists()) {
            file.delete();
            flag = true;
        return flag;
     * 删除目录(文件夹)以及目录下的文件
     * @param   sPath 被删除目录的文件路径
     * @return  目录删除成功返回true,否则返回false
    public static boolean deleteDirectory(String sPath) {
        //如果sPath不以文件分隔符结尾,自动添加文件分隔符
        if (!sPath.endsWith(File.separator)) {
            sPath = sPath + File.separator;
        File dirFile = new File(sPath);
        //如果dir对应的文件不存在,或者不是一个目录,则退出
        if (!dirFile.exists() || !dirFile.isDirectory()) {
            return false;
        boolean flag = true;
        //删除文件夹下的所有文件(包括子目录)
        File[] files = dirFile.listFiles();
        for (int i = 0; i < files.length; i++) {
            //删除子文件
            if (files.isFile()) {
                flag = deleteFile(files.getAbsolutePath());
                if (!flag) break;
            } //删除子目录
            else {
                flag = deleteDirectory(files.getAbsolutePath());
                if (!flag) break;
        if (!flag) return false;
        //删除当前目录
        if (dirFile.delete()) {
            return true;
        } else {
            return false;
        public static Boolean CreateNewFile(String target,String totalPage){
                FileWriter fwr = null;
        BufferedWriter bwr = null;
                File file = new File(target);
                if(file.exists()){
                        System.out.println("file:" + target + "exists");
                         if (file.isFile()) {  // 为文件时调用删除文件方法
                                 file.delete();
//                            if(deleteFile(target) == false)
//                                    return false;
                        } else {  // 为目录时调用删除目录方法
                                if(deleteDirectory(target) == false)
                                        return false;
                try {
            if (file.createNewFile()) {
                System.out.println("Create file: " + target + " sucess!");
                //return true;
            } else {
                System.out.println("Create file: " + target + " fail!");
                return false;
            System.out.println("error:" + target + "!" + e.getMessage());
            return false;
        try{
                fwr = new FileWriter(file);
                bwr = new BufferedWriter(fwr);
                bwr.write(totalPage);
            bwr.newLine();//换行
            bwr.flush();
        } catch (FileNotFoundException e) {
        }catch (IOException e) {
        }finally{
            try {
                bwr.close();
                fwr.close();
                return true;
                return true;
        public static Boolean convert_pdf2swf(RecvMessage msg){
                //File file = new File(msg.getFile());
                //if(! file.isDirectory()){
                //        System.out.println("file:" + msg.getFile() + "is not exist!");
                //        return -1;
                String formatcmd;
                String cmd;
                Process exe;
                String file = msg.getFile();
            String fileName = SysTools.GetFileName(file);
            String fileNameNoEx = SysTools.GetFileNameNoEx(fileName);
                //String pdfFileName = msg.getPrefix() + '.' + fileNameNoEx + ".pdf";
                int pagecount = GetPdfPageNum(msg.getTargetfolder() + "/" + msg.getPrefix() + '.' + fileNameNoEx + ".pdf");
                if(pagecount == -1){
                        System.out.println("GetPdfPageNum :" + msg.getTargetfolder() + "/" + msg.getPrefix() + '.' + fileNameNoEx + ".pdf" + "error!");
                        return false;
                System.out.println("GetPdfPageNum");
                CheckAndBuildTargetFoleder(msg.getTargetfolder());
                 String tpfilename = msg.getTargetfolder() + "/totalpage.txt";
                 System.out.println("tpfilename:" + tpfilename);
                 Boolean ret = CreateNewFile(tpfilename,"" + pagecount);
                 if(ret == false){
                         return ret;
                 System.out.println("CreateNewFile->totalpage.txt  pagecount:" + pagecount);
                 // TODO: write tpfile
                 for(int i = 0;i < pagecount;i ++){
                         if(msg.getPrefix().equals(""))
                                 formatcmd = "./pdf2swf -p %d %s -o %s/%d.swf";
                 cmd = String.format(formatcmd,i + 1,msg.getTargetfolder() + "/" + msg.getPrefix() + '.' + fileNameNoEx + ".pdf",msg.getTargetfolder(),i);
                 System.out.println("++++ cmd:" + cmd);
             else
                 formatcmd = "./pdf2swf -p %d %s -o %s/%s%d.swf";
                 cmd = String.format(formatcmd,i + 1,msg.getTargetfolder() + "/" + msg.getPrefix() + '.' + fileNameNoEx + ".pdf",msg.getTargetfolder(),msg.getPrefix() + '.',i);
                 System.out.println("*++++++++ cmd:" + cmd + "   i:" + i);
                 //cmd = CommonTool::format_string(formatcmd.c_str(), i+1, filename.c_str(), pTransitionRequest->GetTargetFoleder().c_str(),(pTransitionRequest->GetPrefix()+".").c_str(), i);
                                try {
                                        //exe = Runtime.getRuntime().exec(new String[]{"/bin/sh","-c","/root/workspace/openoffice/pdf2swf -I " + file + " | grep -c 'page'"});
                                if(outInf.indexOf("Writing SWF file") >= 0){
                                        // TODO: CommonTool::write_emptyimg
                                        System.out.println("CommonTool::write_emptyimg");
                                        //return false;
                            // TODO:
                return true;
        public static boolean SetIniFile(String file,String section,String variable,String value)throws IOException {
                String fileContent, allLine,strLine, newLine, remarkStr;
                String getValue;
                BufferedReader bufferedReader = new BufferedReader(new FileReader(file));
                boolean isInSection = false;
                fileContent = "";
                try {
                        while ((allLine = bufferedReader.readLine()) != null) {
                                allLine = allLine.trim();
                                if (allLine.split("[;]").length > 1)
                                        remarkStr = ";" + allLine.split(";")[1];
                                else
                                        remarkStr = "";
                                strLine = allLine.split(";")[0];
                                Pattern p;
                                Matcher m;
                                p = Pattern.compile("[s*.*s*]");
                                m = p.matcher((strLine));
                                if (m.matches()) {
                                        p = Pattern.compile("[s*" + section + "s*]");
                                        m = p.matcher(strLine);
                                        if (m.matches()) {
                                                isInSection = true;
                                        } else {
                                if (isInSection == true) {
                                        strLine = strLine.trim();
                                        String[] strArray = strLine.split("=");
                                        getValue = strArray[0].trim();
                                        if (getValue.equalsIgnoreCase(variable)) {
                                                newLine = getValue + " = " + value + " " + remarkStr;
                                                fileContent += newLine + " ";
                                                        fileContent += allLine + " ";
                                                bufferedReader.close();
                                                BufferedWriter bufferedWriter = new BufferedWriter(new FileWriter(file, false));
                                                bufferedWriter.write(fileContent);
                                                bufferedWriter.flush();
                                                bufferedWriter.close();
                                                return true;
                }catch(IOException ex){
                        throw ex;
                } finally {
                return false;
