[STM32F0] STM32F030F4使用内部时钟不工作的问题
9065|9
 楼主| huzhiyang 发表于 2015-11-22 10:31 | 显示全部楼层 |阅读模式
之前使用的是外部时钟,但遇到一个问题,用对讲机在旁边通话的时候,芯片就死掉了,我在里面加了开门狗,连看门狗都不起作用了,问了下FAE,说改成片内晶振看看,我修改如下:
void SystemInit (void)
  RCC->CR |= (uint32_t)0x00000001;    /*HSI振荡器开启*/
  /* Reset SW[1:0], HPRE[3:0], PPRE[2:0], ADCPRE, MCOSEL[2:0], MCOPRE[2:0] and PLLNODIV bits */
  RCC->CFGR &= (uint32_t)0x08FFB80C;
  /* Reset HSEON, CSSON and PLLON bits */
  RCC->CR &= (uint32_t)0xFEF6FFFF;
  /* Reset HSEBYP bit */
  RCC->CR &= (uint32_t)0xFFFBFFFF;
  /* Reset PLLSRC, PLLXTPRE and PLLMUL[3:0] bits */
  RCC->CFGR &= (uint32_t)0xFFC0FFFF;
  /* Reset PREDIV1[3:0] bits */
  RCC->CFGR2 &= (uint32_t)0xFFFFFFF0;
  /* Reset USARTSW[1:0], I2CSW, CECSW and ADCSW bits */
  RCC->CFGR3 &= (uint32_t)0xFFFFFEAC;
  /* Reset HSI14 bit */
  RCC->CR2 &= (uint32_t)0xFFFFFFFE;
  /* Disable all interrupts */
  RCC->CIR = 0x00000000;
  /* Configure the System clock frequency, AHB/APBx prescalers and Flash settings */
  SetSysClock();
static void SetSysClock(void)
    __IO uint32_t StartUpCounter = 0, HSEStatus = 0;
    /* Enable Prefetch Buffer and set Flash Latency */
    FLASH->ACR = FLASH_ACR_PRFTBE | FLASH_ACR_LATENCY;
    /* HCLK = SYSCLK/4 */
    RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV4;
    /* PCLK = HCLK/4 */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE_DIV4;
    /* PLL configuration */
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSI_DIV2 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL6);
    /* Enable PLL */
    RCC->CR |= RCC_CR_PLLON;
    /* Wait till PLL is ready */
    while((RCC->CR & RCC_CR_PLLRDY) == 0)
    /* Select PLL as system clock source */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_SW));
    RCC->CFGR |= (uint32_t)RCC_CFGR_SW_PLL;
    /* Wait till PLL is used as system clock source */
    while ((RCC->CFGR & (uint32_t)RCC_CFGR_SWS) != (uint32_t)RCC_CFGR_SWS_PLL)
但这样修改之后,烧到芯片里面去,拿掉之前8M的晶振,芯片怎么都不工作,需要拿掉晶振脚上的电容吗?
还请高手指点下!
it_yrj 发表于 2015-12-20 12:30 | 显示全部楼层
首先确认下技术支持给的方案有没有道理
再次确认初始化内部晶振是否正确,建议还是再捋下代码
it_yrj 发表于 2015-12-28 22:28 | 显示全部楼层
今天试了下内部晶振,发现死在了
不知是什么原因?楼主解决了没
289947679 发表于 2016-1-20 09:34 | 显示全部楼层
我也试过用内部时钟,可以做到,只改static void SetSysClock(void)
289947679 发表于 2016-1-20 09:36 | 显示全部楼层
  /* SYSCLK, HCLK, PCLK configuration ----------------------------------------*/
  /* Enable HSE */
  RCC->CR |= ((uint32_t)RCC_CR_HSEON);
        //RCC->CR |= ((uint32_t)RCC_CR_HSION);//使用内部8M时钟
  /* Wait till HSE is ready and if Time out is reached exit */
  do
    HSEStatus = RCC->CR & RCC_CR_HSERDY;
                //HSEStatus = RCC->CR & RCC_CR_HSIRDY;//
    StartUpCounter++;
        //while((HSEStatus == 0) && (StartUpCounter != HSI_STARTUP_TIMEOUT));
        while((HSEStatus == 0) && (StartUpCounter != HSE_STARTUP_TIMEOUT));
  if ((RCC->CR & RCC_CR_HSERDY) != RESET)
        //if ((RCC->CR & RCC_CR_HSIRDY) != RESET)
    HSEStatus = (uint32_t)0x01;
  else
    HSEStatus = (uint32_t)0x00;
  if (HSEStatus == (uint32_t)0x01)
    /* HCLK = SYSCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_HPRE_DIV1;
    /* PCLK = HCLK */
    RCC->CFGR |= (uint32_t)RCC_CFGR_PPRE_DIV1;
    /* PLL configuration = HSE * 6 = 48 MHz */
    RCC->CFGR &= (uint32_t)((uint32_t)~(RCC_CFGR_PLLSRC | RCC_CFGR_PLLXTPRE | RCC_CFGR_PLLMULL));
    RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL6);
                //RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_PREDIV1 | RCC_CFGR_PLLXTPRE_PREDIV1_Div2 | RCC_CFGR_PLLMULL9);
                //RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSI_DIV2 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL12);
            有//的是内部8M
小明飞飞飞 发表于 2017-6-7 09:24 来自手机 | 显示全部楼层
5楼,你这setsysclok()函数是设置HSI内部时钟做systemclock
小明飞飞飞 发表于 2017-6-7 09:28 来自手机 | 显示全部楼层
5楼,你这setsysclok()函数是设置HSI内部时钟做systemclock时钟吗?倍频之后的sysclock是多少M的呢?如何调用到usart,设置波特率呢??
viseng 发表于 2017-6-7 10:24 | 显示全部楼层
//RCC->CFGR |= (uint32_t)(RCC_CFGR_PLLSRC_HSI_DIV2 | RCC_CFGR_PLLXTPRE_PREDIV1 | RCC_CFGR_PLLMULL12);这个使用HSI使PLL输入,RCC_CFGR_PLLXTPRE_PREDIV1似乎可以不用吧?
viseng 发表于 2017-6-7 10:25 | 显示全部楼层
楼主,问题解决了吗?能分享下使用外部晶振死掉是因为干扰原因?有解决干扰问题吗?
viseng 发表于 2017-6-7 10:34 | 显示全部楼层
楼主如果可以接受内部时钟源,其实可以做个自动跳转的,如果HSE不稳定,再可以跳转到HSI
在  if (HSEStatus == (uint32_t)0x01)块中加else处理,在else中去打末HSI,这样是个两全的方案
当然如果设计要求上如果HSI精度满足不了,至少可以给出故障提示,或通过串口给出故障提示码
