[STM32F1] USB包长的问题
854|1
 楼主| JY-DX-JY 发表于 2015-11-28 12:04 | 显示全部楼层 |阅读模式
USB, TE, se, TI, IO
我在学STM32的USB。用的自定义设备。
部分程序如下:
void CustomHID_Reset(void)
  /* Set Joystick_DEVICE as not configured */
  pInformation->Current_Configuration = 0;
  pInformation->Current_Interface = 0;/*the default Interface*/
  /* Current Feature initialization */
  pInformation->Current_Feature = CustomHID_ConfigDescriptor[7];
  SetBTABLE(BTABLE_ADDRESS);
  /* Initialize Endpoint 0 */
  SetEPType(ENDP0, EP_CONTROL);
  SetEPTxStatus(ENDP0, EP_TX_STALL);
  SetEPRxAddr(ENDP0, ENDP0_RXADDR);
  SetEPTxAddr(ENDP0, ENDP0_TXADDR);
  Clear_Status_Out(ENDP0);
  SetEPRxCount(ENDP0, Device_Property.MaxPacketSize);
  SetEPRxValid(ENDP0);
  /* Initialize Endpoint 1 */
  SetEPType(ENDP1, EP_INTERRUPT);
  SetEPTxAddr(ENDP1, ENDP1_TXADDR);
  SetEPRxAddr(ENDP1, ENDP1_RXADDR);
SetEPTxCount(ENDP1, 2);
  SetEPRxCount(ENDP1, 2);
  SetEPRxStatus(ENDP1, EP_RX_VALID);
  SetEPTxStatus(ENDP1, EP_TX_NAK);
  bDeviceState = ATTACHED;
  /* Set this device to response on default address */
  SetDeviceAddress(0);
/******************** Descriptor of Custom HID endpoints ******************/
    /* 27 */
    0x07,          /* bLength: Endpoint Descriptor size */
    USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType: */
    0x81,          /* bEndpointAddress: Endpoint Address (IN) */
    0x03,          /* bmAttributes: Interrupt endpoint */
    0x02,          /* wMaxPacketSize: 2 Bytes max */
    0x00,
    0x01,          /* bInterval: Polling Interval (32 ms) */
    /* 34 */
                        /*        Endpoint descriptor type */
    0x01,        /* bEndpointAddress: */
                        /*        Endpoint Address (OUT) */
    0x00,
    0x01,        /* bInterval: Polling Interval (20 ms) */
    /* 41 */
/* Private typedef -----------------------------------------------------------*/
/* Private define ------------------------------------------------------------*/
/* Private macro -------------------------------------------------------------*/
/* Private variables ---------------------------------------------------------*/
u8 Receive_Buffer[2];
u8 temp;
/* Private function prototypes -----------------------------------------------*/
/* Private functions ---------------------------------------------------------*/
* Function Name  : EP1_OUT_Callback.
* Description    : EP1 OUT Callback Routine.
* Input          : None.
* Output         : None.
* Return         : None.
void EP1_OUT_Callback(void)
  BitAction Led_State;
  PMAToUserBufferCopy(Receive_Buffer, ENDP1_RXADDR, 2);
  temp=Receive_Buffer[1];
        if(temp!=0x55)
                GPIO_SetBits(GPIOC, GPIO_Pin_12 );
        else
                GPIO_ResetBits(GPIOC, GPIO_Pin_12 );
#define nReportCnt 2
unsigned long int TimeCount=0;
u8 Transi_Buffer[nReportCnt];
u8 USB_Receive标志寄存器;
u8 flag=0;
u8 i=0;
/* Extern variables ----------------------------------------------------------*/
void Delay(vu32 nCount);
void USB_SendString(void)
                 Transi_Buffer[0] = 0x07;
                 for(i=1;i<nReportCnt;i++)
                //i++;
                        Transi_Buffer=i;
     UserToPMABufferCopy(Transi_Buffer, ENDP1_TXADDR, nReportCnt);
    SetEPTxCount(ENDP1, nReportCnt);
    SetEPTxValid(ENDP1);
USB_Init();
        //USB_SendString();
  while (1)
                                if ( TimeCount >= 3000000 ) //收到后上位机的数据后,将1S发送一次数据给PC
             USB_SendString();
             TimeCount = 0x00;
                                 TimeCount++;
用bus_hound监视截图如下:
 楼主| JY-DX-JY 发表于 2015-11-28 12:09 | 显示全部楼层
每次发送两个数据。
我想要每次发送三个数据的效果:修改程序如下:
  SetEPTxCount(ENDP1, 3);
/* 27 */
    0x03,          /* wMaxPacketSize: 2 Bytes max */
    0x00,
    /* 34 */
#define nReportCnt 3
u8 flag=0;
u8 i=0;
                //i++;
                        Transi_Buffer=i;
用bus hound监视截图如下:
感觉乱掉了。请问高手,哪里改的不对?谢谢!
个人签名:晴天响霹雳,平地一声雷。
245
