[Atmel] 模拟爱好者的完美的时钟
834|2
 楼主| ddllxxrr 发表于 2015-12-3 19:48 | 显示全部楼层 |阅读模式
创客团队Awkward Engineer最近制作了一款电压计闹钟,为模拟迷们量身打造!电压计闹钟分别采用两个模拟仪来显示时钟和分钟,分别像一个电压表和一个电流表,仿佛让你回到了学生时代的物理课
With the holiday shopping season officially underway, do you find yourself wondering what to get the electrical engineer in your life? How about a Voltmeter Alarm Clock?
Developed by Awkward Engineer, the device strikes an uncanny resemblance to an old-school analog voltmeter, except that it displays hours and minutes instead of volts and amps.
“Think of the clock as replacing digital LCDs with analog readouts. Instead of seeing 04:57, the hours meter will point to the 4 and the minutes meter will point to 57. Just like a clock rolls over at midnight and noon, the time meters rolls over zero,” its creators explain.
The stylish yet functional gadget initially appeared on Kickstarter last year, where it successfully garnered $36,000. The Massachusetts-based startup has since enhanced its original design with an alarm function, which is set using a toggle switch on its side.
Built around an ATtiny44, the Voltmeter Alarm Clock features an AM/PM indicator LED, an optional backlight on its display and mode-select knobs on top. Unlike its predecessor, the latest iteration is powered by USB, which can be plugged into a standard wall outlet using a “wall wart” adapter.
If you’re looking for an industrial-chic way to wake up in the morning, the Awkward Engineer team has the perfect thing for you. The Voltmeter Alarm Clock’s sheet metal exterior comes in two different colors — olive drab and grey — and expects to begin shipping next spring.
王栋春 发表于 2015-12-3 20:18 | 显示全部楼层
这个有相关的原理图吗?感觉不错呀
coody 发表于 2015-12-3 20:33 | 显示全部楼层
一个MCU输出两个PWM接两个电压表即可。
个人签名:http://shop34182318.taobao.com/ http://shop562064536.taobao.com
2404
