[ARM9、LPC] ARM板自带ADC声音采集波形问题
1481|6
 楼主| 小虾m米i 发表于 2015-12-11 10:22 | 显示全部楼层 |阅读模式
用TQ2440开发板ADC做声音采集,AD转换频率是0.5MHz,AD转换时间是10us,采样频率是25KHz,采样点数是1024。采集数据写入文件,之后用Matlab画出采样点数和数值的波形,图1和图2分别是单频率音乐和拍掌一次声音波形,采集数据代码如下:AD转换时间为5个时钟周期,t=5*(99+1)/50 MHz=10us
(在上层应用ioctl()控制ADC通道切换,四通道引脚悬空或接地或接3.3V时数据均能够正常显示,但是在接入麦克风之后出现波形如图所示那样,跪求大神指导)
#define  DEVICE_NAME "/dev/sample"
#define COUNT 1024
int main ()
FILE *fp0, *fp1, *fp2, *fp3;
int count = 0;
int fd, ret, value;
char buffer[30];
float temp;
char channel;
//        unsigned long arg = 0x63;
fd = open(DEVICE_NAME, 0);
fp0 = fopen("sample1.txt", "w");
fp1 = fopen("sample2.txt", "w");
fp2 = fopen("sample3.txt", "w");
fp3 = fopen("sample4.txt", "w");
if(fp0 == NULL || fp1 == NULL || fp2 == NULL || fp3 == NULL)
printf("Open file error!\n");
exit(1);
printf("open fd = %d\n", fd);
if(fd < 0)
perror("Open ADC Device Failed!\n");
exit(1);
while(1)
if(count < COUNT)
count++;
for(channel = 0; channel < 4; channel++)
ioctl(fd, channel, 1);
memset(buffer, 0, 30);
ret = read(fd, buffer, sizeof(buffer) - 1);
if(ret > 0)
buffer[ret] = '\0';
sscanf(buffer, "%d\n", &value);
temp =((float)value*3.3)/1024.0;
switch(channel)
        case 0: fprintf(fp0, "%f\n", temp);
break;
        case 1: fprintf(fp1, "%f\n", temp);
break;
        case 2: fprintf(fp2, "%f\n", temp);
break;
        case 3: fprintf(fp3, "%f\n", temp);
break;
//        printf("ADC AIN[%d]:voltage:%4.2f Value: %d\n", channel, temp, value);
else
perror("read ADC device!\n");
exit(1);
else
printf("The count of number is OK!\n");
break;
//        sleep(1);
fclose(fp0);
fclose(fp1);
fclose(fp2);
fclose(fp3);
close(fd);
return 0;
 楼主| 小虾m米i 发表于 2015-12-11 10:23 | 显示全部楼层
此问题困扰了我许久,小弟在这里先谢谢了!:)
dichi 发表于 2015-12-11 16:24 | 显示全部楼层
你自己看看这帖子,背景是红色的,你说还想看你的代码?
 楼主| 小虾m米i 发表于 2015-12-11 22:46 | 显示全部楼层
#define COUNT 1024
int main ()
int count = 0;
int fd, ret, value;
char buffer[30];
float temp;
char channel;
exit(1);
if(fd < 0)
exit(1);
while(1)
if(count < COUNT)
count++;
if(ret > 0)
buffer[ret] = '\0';
switch(channel)
break;
break;
break;
break;
else
exit(1);
else
break;
//        sleep(1);
fclose(fp0);
fclose(fp1);
fclose(fp2);
fclose(fp3);
close(fd);
return 0;
阿南 发表于 2015-12-15 09:11 | 显示全部楼层
 楼主| 小虾m米i 发表于 2015-12-16 10:39 | 显示全部楼层
问题很少有人问答啊:'(
阿南 发表于 2015-12-16 13:52 | 显示全部楼层
问题很少有人问答啊
你这个问题,需要亲自做过才好回答:)
