[STM32F1] lwip-1.4.1数据传输
1557|1
 楼主| luwan1987 发表于 2015-12-14 14:42 | 显示全部楼层 |阅读模式
需要上传94k的数据,怎么处理?
static err_t My_http_recv(void *arg, struct tcp_pcb *pcb, struct pbuf *p, err_t err)
  int i, j;
  char *data;
  float adc_data = 0;
  char fname[40];
  struct fs_file file = {0, 0};
  struct http_state *hs;
  hs = arg;
  if (err == ERR_OK && p != NULL)
    /* Inform TCP that we have taken the data. tot_len最大值由lwipopts。h中PBUF_POOL_BUFSIZE决定*/
    tcp_recved(pcb, p->tot_len);
        printf("\r\n p->tot_len is 0x%X\r\n", p->tot_len);
        printf("\r\n p->tot_len数据为:%s \r\n", p->payload);
    if (hs->file == NULL)
      data = p->payload;
       if (strncmp(data, "GET /jquery.js", 14) == 0)
                  hs->left =  0x0176c0;
            for(i = 0; i < 0x18; i++)
                        pbuf_free(p);
                SPI_FLASH_BufferRead(USART_Buffer_Tx, (0x0ff000+(i<<12)), 0x1000);
                        hs->file = USART_Buffer_Tx;
                        hs->left =  0x1000;
                send_data(pcb, hs);
                        tcp_write(pcb,USART_Buffer_Tx,0x1000,TCP_WRITE_FLAG_COPY);        //                  TCP_WRITE_FLAG_COPY
                        tcp_output(pcb);
                            // tcp_sent(pcb, http_sent);
      else close_conn(pcb, hs);
    else   pbuf_free(p);
  if (err == ERR_OK && p == NULL)close_conn(pcb, hs);
  return ERR_OK;
上面程序只能上传5K左右的数据
 楼主| luwan1987 发表于 2015-12-15 16:45 | 显示全部楼层
求大神帮助
