[技术问答] spi loader 中关于cache的用法,不解
1987|2
 楼主| 温sir 发表于 2015-12-18 10:26 | 显示全部楼层 |阅读模式
  1. <blockquote>/*<font color="#ff0000" size="7"> </font><font color="#ff0000" size="6">急!!!</font>
int main(void)
        unsigned int startBlock;
        unsigned int endBlock;
        unsigned int fileLen;
        unsigned int executeAddr;
        int count, i;
        void        (*fw_func)(void);
        spuDacOnLoader(2);
#ifndef __No_RTC__
        outp32(AER,0x0000a965);
        while(1)
                if((inp32(AER) & 0x10000) ==0x10000)
                        break;
        outp32(PWRON, 0x60005);            /* Press Power Key during 6 sec to Power off (0x'6'0005) */
          outp32(RIIR,0x4);
#endif
        init();
#ifdef _S605_   // support S605 chip
    S605_init_gpio();
    S605_power_on();
#endif
#ifdef __DAC_ON__
        sysprintf("DAC On\n");
        outp32(REG_AHBCLK, inp32(REG_AHBCLK) | ADO_CKE | SPU_CKE | HCLK4_CKE);                // enable SPU engine clock
        /* Initial SPU in advance for linux set volume issue */
        spuOpen(eDRVSPU_FREQ_8000);
//        spuIoctl(SPU_IOCTL_SET_VOLUME, 60, 60);
#endif
#ifndef __No_LCM__
        initVPostShow**();
#endif
        imagebuf = (UINT8 *)((UINT32)image_buffer | 0x80000000);///:dizzy::dizzy::dizzy:
        pImageList=((unsigned int *)(((unsigned int)image_buffer)|0x80000000));// :dizzy::dizzy::dizzy::dizzy:
        /* Initial DMAC and NAND interface */
        SPI_OpenSPI();
        memset(imagebuf, 0, 1024);
        sysprintf("Load Image ");
        /* read image information */
        SPIReadFast(0, 63*1024, 1024, (UINT32*)imagebuf);  /* offset, len, address */
        if (((*(pImageList+0)) == 0xAA554257) && ((*(pImageList+3)) == 0x63594257))
                count = *(pImageList+1);
                pImageList=((unsigned int*)(((unsigned int)image_buffer)|0x80000000));
                startBlock = endBlock = fileLen = executeAddr = 0;
                /* load ** first */
                pImageList = pImageList+4;
                for (i=0; i<count; i++)
                        if (((*(pImageList) >> 16) & 0xffff) == 4)        // **
                                startBlock = *(pImageList + 1) & 0xffff;
                                endBlock = (*(pImageList + 1) & 0xffff0000) >> 16;
                                executeAddr = *(pImageList + 2);
                                fileLen = *(pImageList + 3);
                                SPIReadFast(0, startBlock * 0x10000, fileLen, (UINT32*)executeAddr);
                                break;
                        /* pointer to next image */
                        pImageList = pImageList+12;
                pImageList=((unsigned int*)(((unsigned int)image_buffer)|0x80000000)); // :dizzy::dizzy::dizzy::dizzy::dizzy::dizzy::dizzy::dizzy::dizzy::dizzy::dizzy::dizzy::dizzy::dizzy::dizzy:
                /* load romfs file */
                        if (((*(pImageList) >> 16) & 0xffff) == 2)        // RomFS
                                tag_flag = 1;
                                tagaddr = executeAddr;
                                tagsize = fileLen;
                                break;
                /* load execution file */
                        if (((*(pImageList) >> 16) & 0xffff) == 1)        // execute
                                sysSetGlobalInterrupt(DISABLE_ALL_INTERRUPTS);
                                sysSetLocalInterrupt(DISABLE_FIQ_IRQ);
                                // Invalid and disable cache
                                sysDisableCache();// :dizzy::dizzy::dizzy:
                                sysInvalidCache();//
                                if(tag_flag)
                                        sysprintf("Create Tag - Address 0x%08X, Size 0x%08X\n",tagaddr,tagsize );
                                        TAG_create(tagaddr,tagsize);
                                // JUMP to kernel
                                sysprintf("Jump to kernel\n");
                                //lcmFill2Dark((char *)(FB_ADDR | 0x80000000));
                                outp32(REG_AHBIPRST, JPGRST | SICRST |UDCRST | EDMARST);
                                outp32(REG_AHBIPRST, 0);
                                outp32(REG_APBIPRST, UART1RST | UART0RST | TMR1RST | TMR0RST );
                                outp32(REG_APBIPRST, 0);
                                sysFlushCache(I_D_CACHE);  // 不懂什么意思
                                fw_func = (void(*)(void))(executeAddr);
                                fw_func();
                                break;
        return(0); // avoid compilation warning
low仔 发表于 2015-12-18 23:06 | 显示全部楼层
 楼主| 温sir 发表于 2015-12-19 10:34 | 显示全部楼层
昨天发帖时候,还显示正常的呢??   这编辑器有问题!
这段代码是 N32903 的 spiloader。 cache类型,writethrough。
问题:
1)sysInvalidCache(); 到底有什么用啊?
2)pImageList=((unsigned int*)(((unsigned int)image_buffer)|0x80000000));
或上0x 80000000 之后的指针指向哪里? 是 cache,还是RAM?
