[AVR单片机] AVR AT90USB1287, ADC 寄存器写不进去
989|6
 楼主| lin196@21cn.com 发表于 2015-12-18 15:06 | 显示全部楼层 |阅读模式
AVR AT90USB1287, ADC 寄存器写不进去, 读出来全是0; 仿真时,在电脑软件上看不到这些寄存器有变化,发现AVR STUDIO 软件上的I/O viwe 里面的Address 是写着'na', 但不知道是什么意思;下面是ADC 寄存器图:
你们遇到过这情况吗,
#define BatDete_GetStatus                                 Get_Bit(PINF,0)
#define BatDete_Internal_SetOut                Set_Bit(DDRF,0)
#define BatDete_Internal_SetIN                Clr_Bit(DDRF,0)
#define ADC_channal_0 0
unsigned int adc_result=0;
unsigned char Btemp;
void Battery_ADC_init();
       BatDete_Internal_SetIN;                        //will IO set input
        ADCSRA = 0b10000100;                                //enable ADC power, stop adc, single conversion, adc interrupt no used, ADC prescaler 16
        ADCH = 0x00;
        ADCL = 0x00;
        ADCSRB = 0x00;
        DIDR0 = 0b00000001;                        //ADC0D set 1
        ADMUX = 0b00000000;                                        //selection external AREF, adc result right, selection ADC0 channel
void ADC_start_or_stop(unsigned char StartOrStop);
        if(StartOrStop)
                ADCSRA = (1<<ADSC);        // Start ADC Conversion
        else
                ADCSRA = (0<<ADSC);        // Stop ADC Conversion
unsigned int ADC_StartConversion(unsigned char ADC_channal);
        unsigned char i;
        unsigned int temp;
        adc_result=0;
        ADCSRA = (1<<ADEN);                         //enable ADC
        switch(ADC_channal)                                //selection channal
                case 0:
                        ADMUX        = (0<<MUX4)|(0<<MUX3)|(0<<MUX2)|(0<<MUX1)|(0<<MUX0);                                //selection ADC channal 0
                 break;
                case 1:
                        ADMUX        = (0<<MUX4)|(0<<MUX3)|(0<<MUX2)|(0<<MUX1)|(1<<MUX0);                                //selection ADC channal 1
                 break;
                case 2:
                        ADMUX        = (0<<MUX4)|(0<<MUX3)|(0<<MUX2)|(1<<MUX1)|(0<<MUX0);                                //selection ADC channal 2
                 break;
                case 3:
                        ADMUX        = (0<<MUX4)|(0<<MUX3)|(0<<MUX2)|(1<<MUX1)|(1<<MUX0);                                //selection ADC channal 3
                 break;
                case 4:
                        ADMUX        = (0<<MUX4)|(0<<MUX3)|(1<<MUX2)|(0<<MUX1)|(0<<MUX0);                                //selection ADC channal 4
                 break;
                case 5:
                        ADMUX        = (0<<MUX4)|(0<<MUX3)|(1<<MUX2)|(0<<MUX1)|(1<<MUX0);                                //selection ADC channal 5
                 break;
                case 6:
                        ADMUX        = (0<<MUX4)|(0<<MUX3)|(1<<MUX2)|(1<<MUX1)|(0<<MUX0);                                //selection ADC channal 6
                 break;
                case 7:
                        ADMUX        = (0<<MUX4)|(0<<MUX3)|(1<<MUX2)|(1<<MUX1)|(1<<MUX0);                                //selection ADC channal 7
                 break;
        for(i=0;i<100;i++)                                //adc enable need time
        ADC_start_or_stop(1);
        i = 0;
        while((!ADIF)&&(i<254))
                i++;
        temp        =        ADCH;
        adc_result        =        temp<<8;
        adc_result |=        ADCL;
        return         0;
 楼主| lin196@21cn.com 发表于 2015-12-18 17:05 | 显示全部楼层
顶一下.....................
 楼主| lin196@21cn.com 发表于 2015-12-21 11:07 | 显示全部楼层
JY-DX-JY 发表于 2015-12-21 11:28 | 显示全部楼层
主程序呢?是不是主程序忘了初始化了?
 楼主| lin196@21cn.com 发表于 2015-12-22 09:44 | 显示全部楼层
int main()
        DelayMs(200);
        Init();
        LCD_Init();
        Key_Scan();
        RCC_ini();
        CLOCK_init();
        DelayMs(50);
        CLOCK_FreqOutput(1);
        Battery_ADC_init();
        while(1)
                wdt_reset();
                if(EnKeyScan==1||timer2Hz==1)
                        Key_Scan();
                        Display();
                        ADC_StartConversion        (0);
我有初始化,暂时测试每500ms启动一次ADC,昨天我也打开了ADC 中断,也进不去中断;
不知道是什么原因为呢?
还有AVR studio 软件上在线仿真的ADC的寄存器的地址有 na 字样,如一楼我发的图片!
shaoziyang 发表于 2015-12-22 11:00 | 显示全部楼层
这个型号比较少见啊。
 楼主| lin196@21cn.com 发表于 2015-12-22 13:06 | 显示全部楼层
查出来了,PRR0=0b10101100; Bit 0 - PRADC: Power Reduction ADC,  原来在这里把这个ADC部分关闭了,打开了就可以了,第一次用,没看出来。。。。。
